查看: 1454|回复: 0
Teigha报错求助大神
发表于 2025-1-12 00:14:48 | 显示全部楼层 |阅读模式
c#编了一段复制模板到目标图的代码。GC进程总是报错        System.AccessViolationException。
protected unsafe override void DeleteUnmanagedObject()
                OdRxObject* impObj = GetImpObj();
                ((delegate* unmanaged[Thiscall, Thiscall]<IntPtr, void>)(int)(*(uint*)(*(int*)impObj + 20)))((nint)impObj);
就是这段代码报错。
下面是我的代码,求大神帮忙分析一下到底哪里有问题,该怎么改。万分感谢
        private bool GenerateDwgFiles(Dictionary<string, List<List<(string Weihehao, string Shebeiguandaohao, List<(string Jianhao, string Daima, string Mingcheng, string Guige, string Cailiao, string Shuliang, string Beizhu)>)>>> dataByAnzhuangtuhao, string outputFile)
            if (File.Exists(outputFile))
                File.Delete(outputFile);
            double offsetX = 0;
            double offsetY = 0;
            int columns = 4;
            double sheetWidth = 210;
            double sheetHeight = 297;
            double horizontalSpacing = 10;
            double verticalSpacing = 10;
            int globalIndex = 0; // 全局序号
            string fname = "D:\\output\\file0.dwg";
            using (Services svc = new Services())
                using (Database db = new Database(false, false))
                    db.ReadDwgFile(fname, FileShare.Read, false, null);
                    foreach (var kvp in dataByAnzhuangtuhao)
                        string anzhuangtuhao = kvp.Key;
                        string templateFile = Path.Combine(templatePath, anzhuangtuhao + ".dwg");
                        List<List<(string Weihehao, string Shebeiguandaohao, List<(string Jianhao, string Daima, string Mingcheng, string Guige, string Cailiao, string Shuliang, string Beizhu)>)>> pages = kvp.Value;
                        if (!File.Exists(templateFile))
                            MessageBox.Show($"模板文件未找到: {templateFile}");
                            continue;
                        int totalPages = pages.Count;
                        int rows = (int)Math.Ceiling((double)totalPages / columns);
                        for (int row = 0; row < rows; row++)
                            for (int col = 0; col < columns; col++)
                                int pageIndex = row * columns + col;
                                if (pageIndex >= totalPages) break;
                                CopyTemplateToDestDB(db, templateFile, ref offsetX, ref offsetY, row, col, sheetWidth, sheetHeight, horizontalSpacing, verticalSpacing);
                    db.SaveAs(outputFile, DwgVersion.Current);
                    db.Dispose();
            return true;
        /// <summary>
        /// 复制模板内容到目标数据库
        /// </summary>
        private void CopyTemplateToDestDB(Database destDB, string templateFile, ref double offsetX, ref double offsetY, int row, int col, double sheetWidth, double sheetHeight, double horizontalSpacing, double verticalSpacing)
            using (Database srcDB = new Database(false, false))
                srcDB.ReadDwgFile(templateFile, System.IO.FileShare.Read, false, null);
                using (Transaction srcTrans = srcDB.TransactionManager.StartTransaction())
                    BlockTable blockTable = srcTrans.GetObject(srcDB.BlockTableId, OpenMode.ForRead) as BlockTable;
                    BlockTableRecord modelSpace = srcTrans.GetObject(blockTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                    // 计算偏移量
                    offsetX = col * (sheetWidth + horizontalSpacing);
                    offsetY = -row * (sheetHeight + verticalSpacing);
                    // 获取模型空间中的所有对象
                    ObjectIdCollection pObjIDsColl = new ObjectIdCollection();
                    foreach (ObjectId objId in modelSpace)
                        pObjIDsColl.Add(objId);
                    // 对每个对象进行平移
                    foreach (ObjectId objId in pObjIDsColl)
                        Entity entity = srcTrans.GetObject(objId, OpenMode.ForWrite) as Entity;
                        if (entity != null)
                            Matrix3d translation = Matrix3d.Displacement(new Vector3d(offsetX, offsetY, 0));
                            entity.TransformBy(translation);
                    srcTrans.Commit();
                    // 将模板文件中的内容复制到目标数据库
                    using (Transaction destTrans = destDB.TransactionManager.StartTransaction())
                        BlockTable destBTable = destTrans.GetObject(destDB.BlockTableId, OpenMode.ForRead) as BlockTable;
                        ObjectId destModelSpaceId = destBTable[BlockTableRecord.ModelSpace];
                        IdMapping pIdMap = new IdMapping();
                        // 克隆对象到目标数据库
                        srcDB.WblockCloneObjects(pObjIDsColl, destModelSpaceId, pIdMap, DuplicateRecordCloning.Replace, false);
                        destTrans.Commit();
GMT+8, 2025-7-3 16:30 , Processed in 0.166895 second(s), 22 queries , Gzip On.
