查看: 2485|回复: 23
[提问] 【求助】求大佬给完善代码
发表于 2024-12-29 18:16:48 | 显示全部楼层 |阅读模式
5明经币
现有一份在封闭曲线内绘制方格网的代码,求大佬给完善代码
需求:
1.绘制的方格网每隔4条线设置为一条黄色实线,中间4条设置为灰色虚线;
2.方格网左侧、下侧每隔4条线设置一个数字,数字以手动选取的交点为(0,0)原点。
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
看你这个比较简单,练手顺手写了个糙的,可以实现你需要的功能,有币的话就给我吧,缺币中...
xj6019 + 1 淡定
发表于 2024-12-29 18:16:49 | 显示全部楼层
  1. (defun c:tt (/ d xnum ynum pt0 x0 y0 m n x1 y1 x2 y2 pt3 x3 y3 x4 y4)
  2.   (setq d    (getreal "请输入网格间距")
  3.         xnum (getint "请输入列数\n")
  4.         ynum (getint "请输入行数\n")
  5.         pt0  (getpoint "请选取左下角点\n")
  6.         x0   (car pt0)
  7.         y0   (cadr pt0)
  8.         m    (* xnum 5)
  9.         n    (* ynum 5)
  10.         x1   (+ x0 (* d m))
  11.         y1   (+ y0 (* d n))
  12.         x2   (+ x0 d)
  13.         y2   (+ y0 d)
  14.   )
  15.   (entmake (list '(0 . "LINE") '(62 . 2) (append '(10) pt0) (list 11 x0 y1 0)))
  16.   (entmake (list '(0 . "LINE") '(62 . 2) (append '(10) pt0) (list 11 x1 y0 0)))
  17.   (repeat m
  18.     (if (/= 0 (rem (- x2 x0) (* 5 d)))
  19.       (entmake
  20.         (list '(0 . "LINE")
  21.               '(62 . 8)
  22.               '(6 . "DASH")
  23.               (list 10 x2 y0 0)
  24.               (list 11 x2 y1 0)
  25.         )
  26.       )
  27.       (entmake (list '(0 . "LINE") '(62 . 2) (list 10 x2 y0 0) (list 11 x2 y1 0)))
  28.     )
  29.     (setq x2 (+ d x2))
  30.   )
  31.   (repeat n
  32.     (if (/= 0 (rem (- y2 y0) (* 5 d)))
  33.       (entmake
  34.         (list '(0 . "LINE")
  35.               '(62 . 8)
  36.               '(6 . "DASH")
  37.               (list 10 x0 y2 0)
  38.               (list 11 x1 y2 0)
  39.         )
  40.       )
  41.       (entmake (list '(0 . "LINE") '(62 . 2) (list 10 x0 y2 0) (list 11 x1 y2 0)))
  42.     )
  43.     (setq y2 (+ d y2))
  44.   )
  45.   (setq pt3     (getpoint "请选择原点\n")
  46.         x3      (car pt3)
  47.         y3      (cadr pt3)
  48.         x4      x0
  49.         y4      y0
  50.   )
  51.   (repeat (1+ xnum)
  52.     (entmake
  53.       (list '(0 . "TEXT")
  54.             '(10 0.0 0.0 0.0)
  55.             (cons 40 d)
  56.             (cons 1 (rtos (* 5 (/ (- x4 x3) d))))
  57.             '(71 . 0)
  58.             '(72 . 4)
  59.             (list 11 x4 (- y0 d) 0.0)
  60.       )
  61.     )
  62.     (setq x4 (+ x4 (* 5 d)))
  63.   )
  64.   (repeat (1+ ynum)
  65.     (entmake
  66.       (list '(0 . "TEXT")
  67.             '(10 0.0 0.0 0.0)
  68.             (cons 40 d)
  69.             (cons 1 (rtos (* 5 (/ (- y4 y3) d))))
  70.             '(71 . 0)
  71.             '(72 . 4)
  72.             (list 11 (- x0 d) y4 0.0)
  73.       )
  74.     )
  75.     (setq y4 (+ y4 (* 5 d)))
  76.   )
  77.   (entmake (list '(0 . "LINE") '(62 . 3) (list 10 x3 y0 0) (list 11 x3 y1 0)))
  78.   (entmake (list '(0 . "LINE") '(62 . 3) (list 10 x0 y3 0) (list 11 x1 y3 0)))
  79.   (princ)
  80. )
参与人数 3明经币 +2 金钱 +5 收起 理由
lee50310 + 1 赞一个!
yangpingjun + 5 赞一个!
xj6019 + 1 缺币,就加
发表于 2024-12-29 21:22:11 | 显示全部楼层
你直接到'e派工具箱'院长的群里求助更快更直接……
发表于 2024-12-30 10:39:43 | 显示全部楼层
大佬,使用你的代码,我的是这样的。没有中间纵横的四条灰线?
发表于 2024-12-30 10:44:02 | 显示全部楼层
纳尼?你生成一个然后把dwg发上来看看呢,我反复测试了都没问题
发表于 2024-12-30 11:09:57 | 显示全部楼层
好用不好用币都不要给我,我就是凑热闹的,把币留给需要的人
很有高度!3270的明经币→妥妥的富有!  发表于 2025-1-5 11:29
发表于 2024-12-30 11:11:46 | 显示全部楼层
感谢分享,学习学习。
发表于 2024-12-30 11:12:42 | 显示全部楼层
他没加载 DASH线型,你的代码里没自动判断加载的,所以就是他那样了  没别的
发表于 2024-12-30 12:04:32 | 显示全部楼层
原来如此,确实没想过这个,也暂时不会,如果是这样,把线型组码删了能将就用用
发表于 2024-12-30 12:58:17 | 显示全部楼层
大佬,你的插件加载报错是咋回事呢,CAD2021
GMT+8, 2025-5-21 07:53 , Processed in 0.200490 second(s), 25 queries , Gzip On.
