楼主: ThinkerHua
[资源] 发个自制的假表格导出到Excel的插件
发表于 2025-3-30 18:25:57 | 显示全部楼层
借花献佛,分享在楼主源码基础上修改的导出csv的源码,感谢楼主的思路分享
public static class CsvExporter
     public static void ExportToCsv(string excelFilePath)
         try
             // 检查文件是否存在
             if (!File.Exists(excelFilePath))
                 MessageBox.Show("Excel文件不存在!", "错误", MessageBoxButtons.OK, MessageBoxIcon.Error);
                 return;
             // 确定CSV文件路径
             string csvFilePath = Path.ChangeExtension(excelFilePath, ".csv");
             // 读取Excel文件
             using (FileStream fs = new FileStream(excelFilePath, FileMode.Open, FileAccess.Read))
                 HSSFWorkbook workbook = new HSSFWorkbook(fs);
                 ISheet sheet = workbook.GetSheetAt(0); // 获取第一个工作表
                 // 创建StringBuilder来构建CSV内容
                 StringBuilder csvContent = new StringBuilder();
                 // 遍历每一行
                 for (int rowIndex = 0; rowIndex <= sheet.LastRowNum; rowIndex++)
                     IRow row = sheet.GetRow(rowIndex);
                     if (row == null) continue;
                     List<string> rowData = new List<string>();
                     // 遍历每一列
                     for (int colIndex = 0; colIndex < row.LastCellNum; colIndex++)
                         ICell cell = row.GetCell(colIndex);
                         rowData.Add(GetCellValue(cell));
                     // 将行数据转换为CSV格式
                     csvContent.AppendLine(string.Join(",", rowData.ToArray()));
                 // 写入CSV文件
                 string csvContentStr = csvContent.ToString();
                 byte[] bytes = Encoding.Default.GetBytes(csvContentStr);
                 csvContentStr = Encoding.Default.GetString(bytes);
                 File.WriteAllText(csvFilePath, csvContentStr, Encoding.Default);
                 MessageBox.Show($"CSV文件已成功导出到:\n{csvFilePath}", "成功",
                     MessageBoxButtons.OK, MessageBoxIcon.Information);
         catch (Exception ex)
             MessageBox.Show($"导出CSV文件时出错:\n{ex.Message}", "错误",
     private static string GetCellValue(ICell cell)
         if (cell == null) return "";
         switch (cell.CellType)
             case CellType.String:
                 return EscapeCsvValue(cell.StringCellValue);
             case CellType.Numeric:
                 return cell.NumericCellValue.ToString();
             case CellType.Boolean:
                 return cell.BooleanCellValue.ToString();
             case CellType.Formula:
                 return GetCellValue(cell);
             default:
                 return "";
     private static string EscapeCsvValue(string value)
         if (value.Contains(",") || value.Contains("\"") || value.Contains("\n"))
             return $"\"{value.Replace("\"", "\"\"")}\"";
         return value;
发表于 2025-4-2 13:19:47 | 显示全部楼层
很不错,导出效果很完美,如果楼主把4个选项做成对话框窗体就好了,输出路径最好默认打开DWG路径。还增加一个输出到当前使用的文档就好。
GMT+8, 2025-5-1 09:06 , Processed in 0.162336 second(s), 17 queries , Gzip On.
