查看: 2397|回复: 2
[图元] 多线段的Normal不是0,0,1如何改成0,0,1
发表于 2024-9-27 14:09:22 | 显示全部楼层 |阅读模式
 楼主| 发表于 2024-9-28 14:34:18 | 显示全部楼层
Dim oldPoint As Point3d = Curve.Ecs.CoordinateSystem3d.Origin
Dim oldx As Vector3d = Curve.Ecs.CoordinateSystem3d.Xaxis
Dim oldy As Vector3d = Curve.Ecs.CoordinateSystem3d.Yaxis
Dim oldz As Vector3d = Curve.Ecs.CoordinateSystem3d.Zaxis
Dim mm As Matrix3d = Matrix3d.AlignCoordinateSystem(oldPoint, oldx, oldy, oldz, Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis)
Curve.TransformBy(mm)
这样转换后ECS和Normal都正常了,但图形的位置变动了,不知道后面怎么转换
发表于 2024-10-1 15:03:41 | 显示全部楼层
法向量反转了,需要基变换
GMT+8, 2025-5-1 03:35 , Processed in 0.177241 second(s), 22 queries , Gzip On.
