查看: 3114|回复: 8
[OpenDCL] 求助:AutoCAD如何启动CAD时自动加载OpenDCL的arx支持文件
发表于 2024-9-12 09:25:49 | 显示全部楼层 |阅读模式
各位大师
AutoCAD如何在启动CAD时让其自动判断CAD版本,并自动加载OpenDCL的arx支持文件呢?
发表于 2024-9-12 10:09:41 | 显示全部楼层
        (setq TE (GETENV "PROCESSOR_ARCHITECTURE" ))
        (setq PO nil)
        (setq PO (VL-STRING-SEARCH "64" TE ))
        (setq VER (GETVAR "acadver" ))
        (setq VER (SUBSTR VER 1 2 ))
                        (if (/= PO nil )
                                (PROGN   (setq TE (STRCAT "C:\\OpenDCL.x64." VER ".arx" )) )
                                (PROGN   (setq TE (STRCAT "C:\\OpenDCL." VER ".arx" )) )
        (ARXLOAD TE )
 楼主| 发表于 2024-9-12 10:12:50 | 显示全部楼层
        (setq PO nil)
        (setq PO (VL-STRING-SEARCH "64" TE ) ...
如果有单独的openDcl文件包,可以实现自动加载这个文件的arx吗
发表于 2024-9-12 10:13:36 | 显示全部楼层
就是单独加载的
 楼主| 发表于 2024-9-12 10:15:31 | 显示全部楼层
函数取消呢,加载进去
发表于 2024-9-12 10:25:55 | 显示全部楼层
(DEFUN LOAD_ARX()
        (setq ACAD (SUBSTR (GETVAR "ACADVER" ) 1 2 ))
        (setq PROC (= "AMD64" (GETENV "PROCESSOR_ARCHITECTURE" )))
  (if (= FOL_PATH nil );路径,如"C:/"
                (PROGN
                        (if PROC
                                (PROGN (setq FNAME (STRCAT "C:/DOSLib" ACAD "x64.arx" )))
                                (PROGN (setq FNAME (STRCAT "C:/DOSLib" ACAD ".arx" )))
                (PROGN
                        (if PROC
                                (PROGN (setq FNAME (STRCAT FOL_PATH "DOSLib" ACAD "x64.arx" )))
                                (PROGN (setq FNAME (STRCAT FOL_PATH "DOSLib" ACAD ".arx" )))
        (if (FINDFILE FNAME )
                (PROGN
                        (setq JIAZAI (ARXLOAD FNAME nil ))
                        (if (/= JIAZAI nil )
                                (PROGN (PROMPT (STRCAT "\n" FNAME "文件加载成功!" )))
                                (PROGN (PROMPT (STRCAT "\n" FNAME "文件加载失败!" )))
                (PROGN (PROMPT (STRCAT "\n" FNAME "文件没有找到!" )))
        (setq ODCLREG (STRCAT "HKEY_LOCAL_MACHINE\\" (vlax-product-key ) "\\Applications\\OpenDCL" ))
  (if (setq  PHD (VL-REGISTRY-READ ODCLREG "Loader" ))
                (PROGN
                        (ARXLOAD PHD nil )
                        (PROMPT (STRCAT "\n" PHD "文件加载成功!" ))
                        (setq ODCLREG nil)
                        (setq PHD nil)
                (PROGN
                        (setq PO nil)
                                (PROGN
                                        (if (/= PO nil )
                                                (PROGN (setq TE (STRCAT "C:/OpenDCL.x64." VER ".arx" )))
                                                (PROGN (setq TE (STRCAT "C:/OpenDCL." VER ".arx" )))
                                (PROGN
                                        (if (/= PO nil )
                                                (PROGN (setq TE (STRCAT FOL_PATH "OpenDCL.x64." VER ".arx" )))
                                                (PROGN (setq TE (STRCAT FOL_PATH "OpenDCL." VER ".arx" )))
                        (if (FINDFILE TE )
                                (PROGN
                                        (setq JIAZAI (ARXLOAD TE nil ))
                                                (PROGN (PROMPT (STRCAT "\n" TE "文件加载成功!" )))
                                                (PROGN (PROMPT (STRCAT "\n" TE "文件加载失败!" )))
                                (PROGN (PROMPT (STRCAT "\n" TE "文件没有找到!" )))
        (PRINC )
发表于 2024-9-12 10:27:03 | 显示全部楼层
ajunseo 发表于 2024-9-12 10:15
函数取消呢,加载进去
取消干啥?都加载了 肯定是打开odcl面板了
发表于 2024-9-12 10:28:06 | 显示全部楼层
土土木木人 发表于 2024-9-12 10:25
(DEFUN LOAD_ARX()
        (setq PROC (= "AMD64" (GETENV "P ...
这里可以判断是否安装了 opendcl软件,并自动加载
 楼主| 发表于 2024-9-12 10:31:37 | 显示全部楼层
我是把arx文件放在一个独立的文件夹内
GMT+8, 2025-5-20 10:51 , Processed in 0.172029 second(s), 22 queries , Gzip On.
