查看: 514|回复: 0
你好各位大神CAD插件文本数字分类求和怎么在CAD2025里不好用
发表于 2024-8-20 08:22:00 | 显示全部楼层 |阅读模式
你好各位大神CAD插件文本数字分类求和怎么在CAD2025里不好用,选完回车指定插入点就出现这种情况,指定插入点:; 错误: no function definition: XXEXP求给位大神帮忙修改一下谢谢。
;;--------------------------------------------正则表达式----------------------------------------------------;;
(defun xxexp (pat str key / end)
  ;(princ "\n ★"一刀屠文"(xxexp)(xxexpr) = 对字符串进行正则表达式测试及替换-by 梁雄啸.2007.7")
  (vl-load-com)
  (if (not *xxvbsexp)
    (setq *xxvbsexp (vlax-get-or-create-object "VBScript.RegExp"))
  (vlax-put *xxvbsexp 'Pattern pat)
  (if (not key)(setq key ""))
  (setq key (strcase key))
  (setq keys '(("I"  "IgnoreCase")("G"  "Global")("M"  "Multiline")))
  (mapcar '(lambda(x)
       (if (wcmatch key (strcat "*" (car x) "*"))
         (vlax-put *xxvbsexp (read(cadr x)) 0)
         (vlax-put *xxvbsexp (read(cadr x)) -1)
    keys)
  (setq matches (vlax-invoke *xxvbsexp 'Execute str))
  (vlax-for x matches (setq end (cons (vla-get-value x) end)))
  (reverse end)
;;--------------------------------------------end----------------------------------------------------;;
;|功能:分类统计求和,如:大叶女贞C 7 大叶女贞B 8大叶女贞C 10,会统计出大叶女贞C 17 大叶女贞B 8
        作者:杨春柳 2017.11.10
(defun c:gfsum ( / acaddocument acadobject ent n name namelst newtext num pt sss text textlst txth x)
  (setq AcadObject(vlax-get-acad-object)
      AcadDocument(vla-get-ActiveDocument AcadObject)
  (setvar "cmdecho" 0)
  (vla-StartUndoMark AcadDocument)
  (princ "功能:分类统计求和。作者:孤帆")
  (setq sss (ssget "" (list '(0 . "text"))))
  (setq pt (getpoint "\n指定插入点:"))
  (if (and sss pt)
      (setq namelst '() textlst '())
      (setq ent (cdr (entget (ssname  sss 0))))
      (setq txth (cdr (assoc 40 ent)))
      (repeat (setq n (sslength sss))
            (setq namelst (cons (vlax-ename->vla-object(ssname  sss (setq n (1- n)))) namelst)))
      (setq namelst (mapcar '(lambda (x) (xxexp "[\\-,\\d,\\.]+|[^\\-,\\d,\\.]+" (vla-get-TextString x) "")) namelst))
      (foreach name namelst
              (if (setq text (assoc (car name) textlst))
                              (if (and (= 2 (vl-list-length name)) (numberp (setq num (read (cadr name)))))
                                              (setq num (+ num (read (cadr text))))
                                              (setq newtext (list (car text) (vl-princ-to-string num)))
                                              (setq textlst (subst newtext text textlst))
                                      (setq textlst (cons name  textlst))
      (foreach text textlst
              (setq text (apply 'strcat text))
              (setq ent (subst (cons 1 text)(assoc 1 ent)ent)
                ent (subst (cons 10 pt)(assoc 10 ent)ent)
                ent (subst (cons 11 pt)(assoc 11 ent)ent))
              (entmake ent)
              (setq pt (polar pt (* 1.5 pi) (* 1.3 txth)))
(vla-EndUndoMark AcadDocument)
(setvar "CMDECHO" 1)
GMT+8, 2025-5-1 10:42 , Processed in 0.164100 second(s), 23 queries , Gzip On.
