- 积分
- 74315
- 明经币
- 个
- 注册时间
- 2001-6-7
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - Sub Att2Table()
- On Error Resume Next
- Dim Ent As AcadEntity
- Dim Pnt As Variant
- Do
- ThisDrawing.Utility.GetEntity Ent, Pnt, vbCrLf & "请选择要提取属性的块:"
- If Err.Number <> 0 Then Exit Sub
- If Ent.ObjectName = "AcDbBlockReference" Then
- If Ent.HasAttributes = True Then
- Exit Do
- End If
- End If
- Loop
- Dim BlkRef As AcadBlockReference
- Set BlkRef = Ent
- Dim BlkName As String
- BlkName = BlkRef.Name
- Dim SS As AcadSelectionSet
- Set SS = CreatSSet
- Dim FilterType As Variant
- Dim FilterData As Variant
- Dim FType(2) As Integer
- Dim FData(2) As Variant
- FType(0) = 0
- FData(0) = "INSERT" '图元名
- FType(1) = 66
- FData(1) = 1 '带属性
- FType(2) = 2
- FData(2) = BlkName '图块名
- FilterType = FType
- FilterData = FData
- SS.Select acSelectionSetAll, , , FilterType, FilterData
- Dim i As Integer
- Dim j As Integer
- Dim Blk As AcadBlock
- Dim Att As AcadAttribute
- Dim AttRef As AcadAttributeReference
- Dim AttRefs As Variant
- Dim Rows As Double
- Dim Cols As Double
- Dim Table As AcadTable
- For i = 0 To SS.Count - 1
- Set BlkRef = SS(i)
- AttRefs = BlkRef.GetAttributes
- If i = 0 Then
- Cols = UBound(AttRefs) + 1
- Rows = SS.Count
- Set Table = AddBlkTable(Cols, Rows)
- Set Blk = ThisDrawing.Blocks(BlkRef.Name)
- For Each Ent In Blk
- If Ent.ObjectName = "AcDbAttributeDefinition" Then
- Set Att = Ent
- Table.SetText 0, j, Att.PromptString
- j = j + 1
- End If
- Next
- End If
- For j = 0 To UBound(AttRefs)
- Set AttRef = AttRefs(j)
- Table.SetText i + 1, j, AttRef.TextString
- Next
- Next
- End Sub
- Function AddBlkTable(TableColCount As Double, TableRowCount As Double)
- Dim InsertionPoint As Variant
- InsertionPoint = ThisDrawing.Utility.GetPoint(, vbCrLf & "请选择表格插入点:")
- Dim RowHeight As Double, Colwidth As Double
- RowHeight = 8: Colwidth = 70 '行高及列宽
- Set Table = ThisDrawing.ModelSpace.AddTable _
- (InsertionPoint, TableRowCount + 1, TableColCount, RowHeight, Colwidth)
- Table.HeaderSuppressed = True
- '取消原先表格格式中的首行合并
- Table.UnmergeCells 0, 0, 0, TableColCount - 1 '按顺序为合并的起始行号、结束行号、起始列号、结束列号
- Table.SetTextHeight 7, 7
- 'Table.SetAlignment 3, 5
- Set AddBlkTable = Table
- 'Debug.Print Table.Rows
- End Function
