查看: 991|回复: 4
在CAD中使用分段标注多段线线长它标注出来带小数50.00我不要带小数要整数50这样
发表于 2024-8-1 11:20:20 | 显示全部楼层 |阅读模式
在CAD中使用分段标注多段线线长它标注出来带小数50.00我不要带小数要整数50这样一下是代码麻烦哪位大神能帮我修改一下谢谢。
;;;分段标注线长
(defun c:PPP (/ zg ss obj lst n l lst lst1 lst2 lst3 obj1 obj2)
  (prompt "\n请选择需要标注的线:")
(setq zg 6);;; 字高可自定义
  (if (setq ss (ssget ":S:E" '((0 . "LWPOLYLINE"))))
      (setq obj        (vlax-ename->vla-object (ssname ss 0))
            lst        nil
            n        -1
      (while (setq l (vlax-curve-getDistAtParam obj (setq n (1+ n))))
        (setq lst (cons l lst))
      (setq lst         (reverse lst)
            lst1 (mapcar '(lambda (a b) (- b a)) lst (cdr lst))
      (setq
        lst2 (mapcar '(lambda (x) (vlax-curve-getPointAtDist obj x))
                     (mapcar '(lambda (a b) (+ a (* 0.5 b))) lst lst1)
      (setq lst3
                        (setq
                          ang (angle
                                (mapcar        '+
                                        (vlax-curve-getFirstDeriv
                                          obj
                                          (vlax-curve-getParamAtPoint obj x)
                        (if (< (* 0.5 pi) ang (* 1.5 pi))
                          (- ang pi)
                          ang
                     lst2
      (setq obj1 (car (vlax-safearray->list
                        (vlax-variant-value (vla-offset obj zg))
            obj2 (car (vlax-safearray->list
                        (vlax-variant-value (vla-offset obj (- zg)))
      (or (> (vla-get-Length obj1) (vla-get-Length obj2))
          (vla-Delete obj1)
          (setq        obj1 obj2
                obj2 nil
      (and obj2 (vla-Delete obj2))
      (setq lst2
             (mapcar '(lambda (x) (vlax-curve-getClosestPointTo obj1 x))
                     lst2
      (vla-Delete obj1)
      (mapcar '(lambda (a b c)
                 (entmake (list        '(0 . "TEXT")
                                (cons 1 (rtos a 2 2))
                                (cons 10 b)
                                (cons 40 zg)
                                (cons 11 b)
                                '(72 . 1)
                                '(73 . 2)
                                (cons 50 c)
              lst1
              lst2
              lst3
发表于 2024-8-1 11:25:01 | 显示全部楼层
改成 (cons 1 (rtos a 2 0))试下
 楼主| 发表于 2024-8-1 14:04:02 | 显示全部楼层
谢谢你大神改好了,你好还的麻烦你一下在怎么改标注文字数字总在多段线上方,现在标注的数字在多段线下方数字还是反,标注的数字跟画多段线的方向转动。
发表于 2024-8-1 16:39:35 | 显示全部楼层
不保留小数位
发表于 2024-8-1 17:14:33 | 显示全部楼层
万事如意 发表于 2024-8-1 14:04
谢谢你大神改好了,你好还的麻烦你一下在怎么改标注文字数字总在多段线上方,现在标注的数字在多段线下方 ...
改标注文字数字总在多段线上方
GMT+8, 2025-5-1 14:22 , Processed in 0.158606 second(s), 24 queries , Gzip On.
