- 积分
- 6102
- 明经币
- 个
- 注册时间
- 2022-9-23
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2025-1-20 12:53:15
显示全部楼层
(defun c:zd ()
(vl-load-com) ; 加载 Visual LISP 扩展功能
(regapp "SOUTH")
(regapp "NAME")
(regapp "CODE")
(regapp "TIME")
(setq TIME (list "TIME" (cons 1000 (menucmd "M=$(edtime,$(getvar,date),YYYY-MO-DD-HH:MM:SS)"))))
(setq osm (getvar "osmode")) ; 保存当前捕捉模式
(setvar "osmode" 0) ; 设置为无捕捉模式
(vl-cmdf ".undo" "be") ; 开始撤销标记
(setq blc (getint "\n请输入比例尺1:"))
(setvar 'userr1 blc) ; 设置比例尺
(setq zg (* 0.002 blc)) ; 字高
(setq scale (* 0.001 blc)) ; 缩放比例
(setq xswsa 3) ; 固定高程小数位数为3
(setq ff (open (getfiled "请选择要展点的数据文件" "" "dat" 2) "r")) ; 打开数据文件
(while (setq zb (read-line ff))
(while (vl-string-search "," zb) (setq zb (vl-string-subst " " "," zb))) ; 用空格替换逗号
(setq zb (read (strcat "(" zb ")"))
id (nth 0 zb)
(if (= (length zb) 5)
(setq zpt (list (nth 2 zb) (nth 3 zb) (nth 4 zb))) ; 高程与点号的插入点
(setq zpt (list (nth 1 zb) (nth 2 zb) (nth 3 zb)))
(setq p2 (polar zpt (* 0.25 pi) (* 1.5 zg))) ; 点号注记的插入点
(entmake (list '(0 . "POINT") (cons 10 zpt) '(8 . "ZDH")
(list -3 (list "NAME" (cons 1000 (vl-princ-to-string (nth 0 zb))))
(list "CODE" (cons 1000 (vl-princ-to-string (nth 1 zb)))) TIME
(entmake (list '(0 . "TEXT") (cons 1 (vl-princ-to-string id)) (cons 10 p2) '(7 . "HZ") '(8 . "ZDH") (cons 40 zg) '(41 . 0.8))) ; 点号注记
(gxl-cs:gcd zpt (caddr zpt) scale 2 (list "NAME" (cons 1000 (vl-princ-to-string (nth 0 zb)))
) ; 展高程点
(close ff)
(command "undo" "e") ; 结束撤销标记
(setvar "osmode" osm) ; 恢复原来的捕捉模式
(princ "展点完成")
(defun gxl-cs:gcd (inspt height scale xsws name / pt blkdef obj)
(setvar "CMDECHO" 0)
(command "layer" "m" "GCD" "c" "1" "" "L" "CONTINUOUS" "" "")
(if height
(setq height (rtos height 2 xswsa)) ; 格式化高程值为3位小数
(setq height "")
(regapp "SOUTH")
; 检查字体 "HZ" 是否存在
(if (not (tblobjname "style" "HZ"))
(command "style" "HZ" "rs.shx,hztxt.shx" 0 1 0 "" "" "")
; 检查是否存在高程点图块定义
(if (not (tblobjname "block" "GC200"))
(setq blkdef (vla-Add (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object))) (vlax-3D-point '(0 0 0)) "GC200"))
(setq obj
(vla-AddPolyline
blkdef
(vlax-make-variant
(vlax-safearray-fill
(vlax-make-safearray vlax-vbdouble (cons 0 5))
'(-0.2 0 0 0.2 0 0)
(vla-SetBulge obj 0 1) (vla-SetBulge obj 1 1)
(vla-put-Closed obj :vlax-true)
(vla-put-ConstantWidth obj 0.4)
; 插入块
(entmake (list
'(0 . "INSERT")
'(100 . "AcDbEntity")
'(100 . "AcDbBlockReference")
'(66 . 1) ; 属性跟随标志,1跟随,0不跟随
(cons 2 "GC200")
(cons 10 inspt)
(cons 41 scale)
(cons 42 scale)
(cons 43 scale)
(list -3 '("SOUTH" (1000 . "202101")) NAME TIME)
; 插入属性
(entmake (list
'(0 . "ATTRIB")
'(100 . "AcDbText")
(cons 10 (setq pt (polar inspt 0 (* 1.2 scale))))
(cons 40 (* 2.0 scale))
(cons 50 0)
(cons 41 0.8)
(cons 51 0)
(cons 1 height)
(cons 7 "HZ")
(cons 72 0)
(cons 11 pt)
'(100 . "AcDbAttribute")
(cons 2 "height")
(cons 70 0)
(cons 74 2)
; 结束标志
(entmake '((0 . "SEQEND")))
