楼主: 啵浪鼓
[提问] 表提重复
发表于 2024-7-3 09:26:39 | 显示全部楼层
应该搞一个竞赛,看谁能用最短的代码实现。当前是lijiao的
(SETQ LL '((10 20) (5 40) (10 30) (20 40) (10 40)) l nil)
(VL-REMOVE-IF-not '(lambda(x) (if (not (member (cadr x) l)) (setq l (cons (cadr x) l)))) ll)
发表于 2024-7-4 03:10:53 | 显示全部楼层
(SETQ LL '((10 20) (5 40) (10 30) (20 40) (1 ...
最快才有意义
 楼主| 发表于 2024-7-13 21:15:55 来自手机 | 显示全部楼层
((10 20 2) (20 30 3) (10 20 5) (20 30 1) (20 30 2))
满足x和y坐标相同条件,求xy相同组成一块返回
( ((10 20 2)  (10 20 5))  ((20 30 3) (20 30 1) (20 30 2)) )
发表于 2024-7-15 16:35:44 | 显示全部楼层
(setq qq '((10 20 2) (20 30 3) (10 20 5) (20 30 1) (20 30 2) (10 500 4) (90 500 10) (100 500 400)))
(reverse (SORT-SAME-XY qq))
(((10 20 2) (10 20 5)) ((20 30 3) (20 30 1) (20 30 2)) ((10 500 4)) ((90 500 10)) ((100 500 400)))
(defun sort-same-xy (l / lst l1 a)
   (while l
     (setq a   (car l)
     l   (cdr l)
           l1  (vl-remove-if '(lambda (e) (or (/= (car e)(car a)) (/= (cadr e)(cadr a))) ) l)
     lst (cons (cons a l1) lst)
     l1 nil
     l  (vl-remove-if '(lambda (e) (and (= (car e)(car a)) (= (cadr e)(cadr a)) ) ) l)
  lst)
GMT+8, 2025-10-21 18:06 , Processed in 0.180640 second(s), 19 queries , Gzip On.
