查看: 926|回复: 2
求扩充求合程序
发表于 2024-5-29 18:49:10 | 显示全部楼层 |阅读模式
12明经币
(DEFUN C:DF (/ SS N X AA ENT1 LST NUM FNUM SNUM)
  (setq SS (SSGET '((0 . "text"))))
  (setq N (SSLENGTH SS))
  (setq X 0)
  (setq AA 0)
  (setq SNUM 0)
  (REPEAT N
    (setq ENT1 (cdr (ASSOC 1 (ENTGET (SSNAME SS X)))))
    (setq LST (APPEND (LIST ENT1) LST))
    (setq X (1+ X))
  (if (OR (APPLY 'AND (MAPCAR '(LAMBDA (X) (WCMATCH X "*U")) LST))
          (APPLY 'AND (MAPCAR '(LAMBDA (X) (GXL-STRISNUM X)) LST))
    (PROGN
      (if (APPLY 'AND (MAPCAR '(LAMBDA (X) (WCMATCH X "*U")) LST))
        (PROGN
          (REPEAT (LENGTH LST)
            (setq NUM (READ (VL-STRING-RIGHT-TRIM "U" (NTH AA LST))))
            (setq FNUM NUM)
            (setq SNUM (+ SNUM FNUM))
            (setq AA (1+ AA))
          (ALERT (STRCAT "所统计开关总模数为" (RTOS SNUM 2 1) "U"))
        (PROGN (APPLY 'AND (MAPCAR '(LAMBDA (X) (GXL-STRISNUM X)) LST))
                 (setq NUM (READ (NTH AA LST)))
                 (setq FNUM NUM)
                 (setq AA (1+ AA))
               (ALERT (STRCAT "所统计总功率为" (RTOS SNUM 2 1) "kW"))
    (PROGN (ALERT "选择有误,包含非模数或非数字文字"))
  (PROMPT "\n 程序执行成功")
  (PRIN1)
以上为源代码,想增加统计E 和M 分别求合,能否输入命令后比如S,弹出对话框可输入限制U,M,E值(不输入S即为默认值)。U,M,E值分别默认为10.5U,36E,72E。当框选大于(等于不算)默认或设定值后,弹出对话框提示:所选模数过多,请重新选择。附上所有币,谢谢。
发表于 2024-5-29 21:51:15 | 显示全部楼层
不是同行,完全看不懂是啥
 楼主| 发表于 2024-5-30 11:32:33 | 显示全部楼层
xj6019 发表于 2024-5-29 21:51
不是同行,完全看不懂是啥
谢谢。大佬是什么专业
GMT+8, 2025-5-1 03:22 , Processed in 0.155461 second(s), 20 queries , Gzip On.
