查看: 1150|回复: 0
VBA代码隐藏不需要的图层
发表于 2024-5-14 21:10:26 | 显示全部楼层 |阅读模式
以下是用在中望CAD的VBA代码,用于实现隐藏不需要的图层,程序能正常运行,但是无法隐藏指定的图层,求大神指点
Option Explicit
Sub XXX()
Application.ScreenUpdating = False       '
Dim password As Variant
password = ThisWorkbook.Sheets("INPUT").Range("P2")
If password = "369" Then
    Dim ZcadApp As ZcadApplication
    Dim ZcadDoc As ZcadDocument
    With ThisWorkbook.Sheets("Input")
    If .Range("S8") <> "调试" Then
        Dim wjmc As String
        If .Range("S7") = "当前文件夹" Then
            wjmc = ThisWorkbook.Path & "\" & .Range("S4") & ".dwg"
        Else
            wjmc = .Range("S7") & "\" & .Range("S4") & ".dwg"
        End If
        FileCopy .Range("S6") & "\" & .Range("S5") & ".dwg", wjmc
    End If
    On Error Resume Next    '判断语句是否出错
    Set ZcadApp = GetObject(, "ZWcad.application")
    If Err Then
        Err.Clear
        Set ZcadApp = CreateObject("ZWcad.application")
        If Err Then
        MsgBox Err.Description  '报错
        Exit Sub
        End If
    End If
    ZcadApp.Visible = True             '
    ZcadApp.WindowState = zcMax
        ZcadApp.Documents.Open wjmc
    Else
        ZcadApp.Documents.Open .Range("S6") & "\" & .Range("S5") & ".dwg"
    End If
    Set ZcadDoc = ZcadApp.ActiveDocument
    Dim mxzdyd As String, mxzded As String, mcd As String, ncd As String
    Dim i As Integer, n As Integer, mbgzb As String
    Dim m As Integer
    mbgzb = .Range("S5")
    End With
    With ThisWorkbook.Sheets(mbgzb)
      Dim dz1 As ZcadLayer '隐藏图层
    n = .Range("AC65536").End(xlUp).Row
    For i = 3 To n
        Set dz1 = ZcadDoc.Layers(.Range("AC" & i))
        dz1.LayerOn = .Range("AD" & i)
     End With
    Set ZcadApp = Nothing
    Set ZcadDoc = Nothing
End If
Application.ScreenUpdating = True
End Sub
GMT+8, 2025-5-23 12:14 , Processed in 0.174272 second(s), 23 queries , Gzip On.
