查看: 3178|回复: 3
dxf格式中Entities段中lwpolyline中的组码70代表什么?
发表于 2004-4-5 20:17:00 | 显示全部楼层 |阅读模式
看了帮助也还是不太懂,
我的dxf文件中组码70后出现了129可帮助文档里没有这个值呀?
发表于 2004-6-2 11:53:00 | 显示全部楼层
好像是顶点数吧
发表于 2005-6-15 09:01:00 | 显示全部楼层
0表示不闭合,1表示闭合。
发表于 2013-9-2 15:14:47 | 显示全部楼层
Vertex flags:
1 = Extra vertex created by curve-fitting
2 = Curve-fit tangent defined for this vertex. A curve-fit tangent direction of 0 may be omitted from DXF output but is significant if this bit is set
4 = Not used
8 = Spline vertex created by spline-fitting
16 = Spline frame control point
32 = 3D polyline vertex
64 = 3D polygon mesh
128 = Polyface mesh vertex
129=1+128
GMT+8, 2025-5-1 12:50 , Processed in 0.174695 second(s), 25 queries , Gzip On.
