楼主: 664571221
[提问] 各位大神看一下,求一个复制并放大的功能
 楼主| 发表于 2024-4-12 09:16:23 | 显示全部楼层
木头人的(defun c:TT ()
  (setq ss (ssget))
  (if (not ss)
      (princ "\n未选择任何实体。")
      (exit)
  (setq pt0 (getpoint "\n选择基点:"))
  (setq pt1 (getpoint pt0 "\n选择终点:"))
  (command "_.copy" ss "" pt0 pt1)
  (setq ss1 entlast)
  (command "_.scale" "_l" "" pt1 10)
  (setq last_text (entlast)) ; 获取最后创建的实体的实体名
  (setq ob (vlax-ename->vla-object last_text)) ; 将最后创建的实体转换为 VLA 对象
  (vlax-put-property ob 'StyleName "宋体")
 楼主| 发表于 2024-4-12 09:17:28 | 显示全部楼层
664571221 发表于 2024-4-12 09:16
(defun c:TT ()
  (setq ss (ssget))
  (if (not ss)
小星的(defun c:FZFD (/ ss pt0 pt1 ss1)
  (setq ss (ssget))
  (if (not ss)
      (exit)
  (setq ss1 (entlast))
        (command "CHANGE" ss1 "" "p" "c" "1" "")
 楼主| 发表于 2024-4-14 10:41:18 | 显示全部楼层
  (setq ss (ssget))
  (if (not ss)
(defun c:TT (/ ss pt0 pt1 ss1)
(vl-load-com)
  (setq ThisDrawing(vla-get-activedocument (vlax-get-acad-object)))
  (Setq TextStyles(vla-get-TextStyles ThisDrawing))
  (Setq TextStyle(vla-add TextStyles "新文字样式"))
  (vla-SetFont TextStyle "宋体" :vlax-false :vlax-false 1 0)
  (setq ss (ssget))
  (if (not ss)
      (exit)
  (command "_.scale" "_l" "" pt1 2)
 楼主| 发表于 2024-5-4 22:12:10 | 显示全部楼层
(vl-load-com)
  (setq ThisDrawing(vla-get-activedocument (vlax ...
Z大的代码
(defun c:TT ()
(setq ss (ssget))
(if (not ss) (progn
  (exit)
; (setq ss1 entlast)
(vlax-put-property ob 'Color "1")
发表于 2025-5-12 22:25:33 | 显示全部楼层
谢谢分享,学习一下。
GMT+8, 2026-1-27 06:56 , Processed in 0.519705 second(s), 19 queries , Gzip On.
