楼主: langjs
[源码] 《块属性输出到excel》
发表于 2024-3-7 23:18:12 | 显示全部楼层
大师,请教您一个问题,我有一个将CAD里面通过xyz坐标将文字导出到excel, excel文字导出到CAD的程序,现在可以从CAD导出,但是目前没法导入。请教大神该如何修改呢。其实最佳的方式是将文件导出到已经打开excel中,然后在excel中修改后再导回CAD中。不知道能否实现呢。
(defun c:EXTCSV (/ ss i f ename text pos)
  (setq ss (ssget "X" '((0 . "TEXT,MTEXT"))))
  (if ss
      (setq f (open "D:/autocad_text.csv" "w"))
      (if f
          (write-line "TextString,X,Y,Z" f)
          (setq i -1)
          (repeat (sslength ss)
            (setq i (1+ i))
            (setq ename (ssname ss i))
            (setq text (cdr (assoc 1 (entget ename))))
            (setq pos (cdr (assoc 10 (entget ename))))
            (write-line (strcat text "," (rtos (car pos)) "," (rtos (cadr pos)) "," (rtos (caddr pos))) f)
          (close f)
          (princ "\nText has been exported to D:/autocad_text.csv")
        (princ "\nFailed to open file for writing.")
    (princ "\nNo text found in the drawing.")
(defun c:IMTCSV (/ f line fields text pos)
  (setq f (open "D:/autocad_text.csv" "r"))
  (if f
      (read-line f) ; Skip the header line
      (while (setq line (read-line f))
        (setq fields (strtok line ","))
        (setq text (nth 0 fields))
        (setq pos (list (atof (nth 1 fields)) (atof (nth 2 fields)) (atof (nth 3 fields))))
        (command "TEXT" pos "" "" text)
      (close f)
      (princ "\nText has been imported from D:/autocad_text.csv")
    (princ "\nFailed to open file for reading.")
我最近发的程序里有EXCEL导到CAD的程序,你可以参考下  发表于 2024-3-8 08:49
发表于 2024-3-7 23:36:50 | 显示全部楼层
这些都是超级实用的小程序,感谢分享
发表于 2024-3-7 23:59:22 | 显示全部楼层
单纯的罗列数据虽有意义,但感觉不如把同类项数量相加,汇总到一起意义更大
发表于 2024-3-8 00:08:44 | 显示全部楼层
发表于 2024-3-8 08:13:16 | 显示全部楼层
郎大师,此时此刻,我只想唱一首,《ONLY YOU》。不知是否可以?
发表于 2024-3-8 11:30:36 | 显示全部楼层
保存下了,感谢大师分享
发表于 2024-3-8 14:11:57 | 显示全部楼层
帮忙看下,报错
发表于 2024-3-8 14:19:54 | 显示全部楼层
附件如下,框选后出错
发表于 2024-3-8 14:22:32 | 显示全部楼层
好像选择过程不能空格,空格就会出错
GMT+8, 2025-12-12 08:45 , Processed in 0.169019 second(s), 21 queries , Gzip On.
