查看: 1922|回复: 16
如何定义指定尺寸的矩形?
发表于 2024-3-5 16:48:54 | 显示全部楼层 |阅读模式
  • 如何优化下列代码,一步完成任意尺寸矩形的绘制?基点改为左上方,如图所示
    • (defun c:j()
    •   (prompt "\n j:矩形")
    • (setq cmd (getvar "cmdecho"))
    • (setvar "cmdecho" 0)
    • (setq pa (getpoint "\n请指定基点:"))
    • (setq ww (getdist "\n宽度:"))
    • (setq hh (getdist "\n高度:"))
    • (setq pb (polar pa 0 ww))
    • (setq pc (polar pb (/ pi 2) hh))
    • (setq pd (polar pc pi ww))
    • (setq osm (getvar "osmode"))
    • (setvar "osmode" 0)
    • (command "_pline" pa pb pc pd "c")
    • (setvar "osmode" osm)
    • (setvar "cmdecho" cmd)
    • (princ)
2.怎么把下面基点改为下中、右下?
  • (defun c:x4 (/ h p p pt w)
  •       (prompt "\n X4:矩形--左下")
  •   (if (and (or #BT-WWWWWWWWWWW (setq #BT-WWWWWWWWWWW 100))
  •         (or #BT-HHHHHHHHHH (setq #BT-HHHHHHHHHH 100))
  •         (or (and (setq w (getdist (strcat "\n宽度:<"(rtos #BT-WWWWWWWWWWW 2 2)">")))
  •               (setq #BT-WWWWWWWWWWW w)
  •           #BT-WWWWWWWWWWW
  •         (or (and (setq h (getdist (strcat "\n高度:<"(rtos #BT-HHHHHHHHHH 2 2)">")))
  •               (setq #BT-HHHHHHHHHH h)
  •           #BT-HHHHHHHHHH
  •         (setq p (getpoint "\n 基点:"))
  •         (setq pt (mapcar '+ p (list #BT-WWWWWWWWWWW #BT-HHHHHHHHHH 0)))
  •     (progn
  •       (setvar "CMDECHO" 0)
  •       (command "RECTANG" "non" p "non" pt)
  •       (setvar "CMDECHO" 1)
3.怎么把下面这些代码赋以记性功能?
  • ;;;矩形--上中【X21】
  • (defun c:X21(/ pt ck c_k c k pt1 j)
  •   (prompt "\n X21:矩形--上中")
  •   (command "UNDO" "be")
  •   (setq pt(getpoint "\n 指定基点(矩形上方中点)") ck(getstring "\n长,宽(英文下逗号)"))
  •   (setq c_k (split ck ","))
  •   (setq c(car c_k) k(cadr c_k))
  •   (setq pt1(polar pt pi (/ (abs (atof c)) 2)))
  •   (setq j(strcat "@" (rtos(abs(atof c))) ",-" (rtos(abs(atof k)))))
  •   (command "RECTANG" pt1 j)
  •   (command "UNDO" "e")
  •   (princ)
  • (defun split (s p / r);分割字符串
  •   (setq r (vlax-create-object "vbscript.regexp"))
  •   (vlax-put-property r 'Global 1)
  •   (vlax-put-property r 'Pattern p)
  •   (read (strcat "(\"" (vlax-invoke r 'Replace s "\" \"") "\")"))
  • (princ)
发表于 2024-3-6 10:57:21 | 显示全部楼层
zilong136 发表于 2024-3-6 10:51
能否跟我第二个代码一样,带记忆功能?
忘记了弄全局变量了 把这三个删掉就可以记忆了
 楼主| 发表于 2024-3-6 11:23:26 | 显示全部楼层
怎么把下面基点改为下中、右下?
          #BT-WWWWWWWWWWW
          #BT-HHHHHHHHHH
发表于 2024-3-5 19:14:09 | 显示全部楼层
  1. (defun c:j()
  2.   (prompt "\n j:矩形")
  3.         (setq cmd (getvar "cmdecho"))
  4.         (setvar "cmdecho" 0)
  5.         (setq pa (getpoint "\n请指定基点:"))
  6.         (setq ww (getdist "\n宽度:"))
  7.         (setq hh (getdist "\n高度:"))
  8.         (setq pb (polar pa 0 ww))
  9.         (setq pc (polar pb (* pi 1.5) hh))
  10.         (setq pd (polar pc pi ww))
  11.         (setq osm (getvar "osmode"))
  12.         (setvar "osmode" 0)
  13.         (command "_pline" pa pb pc pd "c")
  14.         (setvar "osmode" osm)
  15.         (setvar "cmdecho" cmd)
  16.         (princ)
  17. )
 楼主| 发表于 2024-3-5 20:28:23 | 显示全部楼层
可以,怎么写一个函数,就是可以把矩形的几个特征点作为基点可以切换,基点为左上、上中、上右、下左、下中、下右六个基点?
发表于 2024-3-5 22:16:56 | 显示全部楼层
可以弄个关键词来进行基点的切换 可以配合cond用 但是这样代码就复杂了 简单的就是计算好那六个点 画完了用 move移动
 楼主| 发表于 2024-3-5 22:45:55 | 显示全部楼层
飞雪神光 发表于 2024-3-5 22:16
可以弄个关键词来进行基点的切换 可以配合cond用 但是这样代码就复杂了 简单的就是计算好那六个点 画完了用 ...
帮我把下面那串代码改下
发表于 2024-3-6 08:17:42 | 显示全部楼层
谢谢分享谢谢分享谢谢分享
发表于 2024-3-6 08:57:23 | 显示全部楼层
发表于 2024-3-6 09:08:18 | 显示全部楼层
”RECTANG““X长度”“,”"Y长度"
RECTANG
指定第一个角点或 [倒角(C)/标高(E)/圆角(F)/厚度(T)/宽度(W)]:
指定另一个角点或 [面积(A)/尺寸(D)/旋转(R)]: @-5,6
 楼主| 发表于 2024-3-6 10:51:58 | 显示全部楼层
能否跟我第二个代码一样,带记忆功能?
GMT+8, 2025-5-1 12:31 , Processed in 0.171843 second(s), 25 queries , Gzip On.
