查看: 2605|回复: 7
块改色插件
发表于 2024-2-26 11:10:18 | 显示全部楼层 |阅读模式
选择颜色能不能改成,下面这种直接输入色号的方式
(defun c:gk (/ ChBlkColor SS blks I Obj BnLst)
  (defun ChBlkColor (Blks Obj Color / BlkName oName)
    (if (and (= (vla-get-ObjectName obj) "AcDbBlockReference")
             (= (vla-get-HasAttributes obj) :vlax-true)
      (foreach x (vlax-invoke obj 'getattributes)
        (vla-put-color x Color)
    (setq BlkName (vla-get-name obj))
    (if (not (member BlkName bnlst))
        (setq bnlst (cons BlkName BnLst))
        (vlax-for X (vla-item Blks BlkName)
          (setq oName (vla-get-ObjectName X))
          (cond ((wcmatch oName "*Dimension,AcDbLeader,AcDbFcf")
                 (vla-put-DimensionLineColor X Color)
                 (if (wcmatch oName "*Dimension")
                     (vla-put-ExtensionLineColor X Color)
                     (if (setq BlkName (assoc 2 (entget (vlax-vla-object->ename X))))
                       (vlax-for X (vla-item Blks (cdr BlkName))
                         (vla-put-color X Color)
                 (if (wcmatch oName "*Dimension,AcDbFcf")
                   (vla-put-TextColor X Color)
                ((= oName "AcDbBlockReference")
                 (ChBlkColor Blks X Color)
    (vla-UpDate obj)
  (if (and (setq ss (ssget '((0 . "insert"))))
           (or $ChBlkColor$ (setq $ChBlkColor$ 7))
           (setq $ChBlkColor$ (acad_colordlg $ChBlkColor$))
      (setq blks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
      (repeat (setq i (sslength ss))
        (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
        (ChBlkColor Blks Obj $ChBlkColor$)
发表于 2024-2-26 13:26:27 | 显示全部楼层
  1. (defun c:gk (/ ChBlkColor SS blks I Obj BnLst)
  2.   (defun ChBlkColor (Blks Obj Color / BlkName oName)
  3.     (if (and (= (vla-get-ObjectName obj) "AcDbBlockReference")
  4.                                         (= (vla-get-HasAttributes obj) :vlax-true)
  5.         )
  6.       (foreach x (vlax-invoke obj 'getattributes)
  7.         (vla-put-color x Color)
  8.       )
  9.     )
  10.     (setq BlkName (vla-get-name obj))
  11.     (if (not (member BlkName bnlst))
  12.       (progn
  13.         (setq bnlst (cons BlkName BnLst))
  14.         (vlax-for X (vla-item Blks BlkName)
  15.           (setq oName (vla-get-ObjectName X))
  16.           (cond ((wcmatch oName "*Dimension,AcDbLeader,AcDbFcf")
  17.        (vla-put-DimensionLineColor X Color)
  18.        (if (wcmatch oName "*Dimension")
  19.        (progn
  20.        (vla-put-ExtensionLineColor X Color)
  21.        (if (setq BlkName (assoc 2 (entget (vlax-vla-object->ename X))))
  22.        (vlax-for X (vla-item Blks (cdr BlkName))
  23.        (vla-put-color X Color)
  24.        )
  25.        )
  26.        )
  27.        )
  28.        (if (wcmatch oName "*Dimension,AcDbFcf")
  29.        (vla-put-TextColor X Color)
  30.        )
  31.                 )
  32.                                                 ((= oName "AcDbBlockReference")
  33.                                                         (ChBlkColor Blks X Color)
  34.                                                 )
  35.           )
  36.           (vla-put-color X Color)
  37.         )
  38.       )
  39.     )
  40.     (vla-UpDate obj)
  41.   )
  42.   (if (and
  43.                                 (setq ss (ssget '((0 . "insert"))))
  44.                                 (or $ChBlkColor0$ (setq $ChBlkColor0$ 7))
  45.                         )
  46.     (progn
  47.                         (setq $ChBlkColor$ (getint (strcat "\n请输入颜色号(1-255)<" (itoa $ChBlkColor0$) ">:")))
  48.                         (if (null $ChBlkColor$)
  49.                                 (setq $ChBlkColor$ $ChBlkColor0$)
  50.                                 (setq $ChBlkColor0$ $ChBlkColor$)
  51.                         )
  52.                         (setq blks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
  53.       (repeat (setq i (sslength ss))
  54.         (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
  55.         (ChBlkColor Blks Obj $ChBlkColor$)
  56.       )
  57.     )
  58.   )
  59.   (princ)
  60. )
 楼主| 发表于 2024-2-26 11:12:42 | 显示全部楼层
 楼主| 发表于 2024-2-26 13:55:30 | 显示全部楼层
非常感谢 非常感谢
发表于 2024-2-26 23:48:34 | 显示全部楼层
不错插件谢谢分享
发表于 2024-3-12 09:32:03 | 显示全部楼层
发表于 2024-4-7 10:27:00 | 显示全部楼层
感谢大神的热心分享,点赞
发表于 2024-6-3 19:56:19 | 显示全部楼层
未知名称: ExtensionLineColor
GMT+8, 2025-5-1 04:21 , Processed in 0.184986 second(s), 25 queries , Gzip On.
