查看: 1390|回复: 3
测量距离的插件
发表于 2024-1-26 11:06:33 | 显示全部楼层 |阅读模式
有没有那种测量距离的插件,可以显示距离长度的那种
发表于 2024-1-26 13:45:30 | 显示全部楼层
命令: dist
指定第一点:  指定第二点:
距离 = 77.5275,XY 平面中的倾角 = 30,  与 XY 平面的夹角 = 0
X 增量 = 67.4007,  Y 增量 = 38.3102,   Z 增量 = 0.0000
CAD 自带命令
发表于 2024-1-26 13:55:02 | 显示全部楼层
;*****************************按图层标注边长*******************************************
(DEFUN C:bc ()
(setvar "cmdecho" 0)
(COMMAND "-osnap" "")
(COMMAND "-layer" "s" "0" "")
  (setq TUCHENG (getstring "\n 请输入要注记的图层< 建筑 > : "))
     (if (or (= TUCHENG nil) (= TUCHENG ""))
        (setq TUCHENG "建筑")
  (setq hei (getreal "\n 输入字高 < 1> :"))
     (if (= hei nil)
       (setq hei 1)
   (setq zjws (getint "\n 输入小数点后保留的位数 < 2 > : "))
      (if (or (= zjws nil) (= zjws ""))
       (setq zjws 2)
  (setq BILICHI (getreal "\n 输入图形范围 : "))
     (if (= BILICHI nil)
       (setq BILICHI 500.0)
   (command "layer" "make" "中土边长" "c"  "51" "中土边长" "");
   (setq bilixishu (/ BILICHI 1000.0))
   (setq zwd1 (getpoint "注记范围第一点"))
   (setq zwd5 (getcorner zwd1 "注记范围第五点"))
   (setq  ss (ssget  "w" zwd1 zwd5  (list (cons 0 "LINE,POLYLINE,LWPOLYLINE") (cons 8 TUCHENG)) ) )
    (setq ZCD (sslength ss))
     (setq ZXH 0)
    (while (< ZXH ZCD)
      (setq NE (ssname ss ZXH))
      (setq ED (entget NE))
      (setq TJ (CDR (assoc 0 ED)))
       (if (= TJ "LINE")
                (setq kk2 (cdr (assoc 10 ED)))
                (setq kk3 (cdr (assoc 11 ED)))
                (setq dis (rtos (distance KK2 KK3) 2 zjws))
                (setq an (angle KK2 KK3))
                (setq kkm (polar KK2 an (/ (distance KK2 KK3) 2)))
                   (if (or (< (/ (* 3 pi) 4) an (/ (* 7 pi) 4)) (= an (/ (* 7 pi) 4)))
                       (COMMAND "text" "J" "BC" kkm hei KK2 dis)
                       (COMMAND "text" "J" "BC" kkm hei KK3 dis)
      (if (= TJ "POLYLINE")
              (setq pdtj (cdr (assoc 70 (entget NE))))
              (setq kxy (cdr (assoc 10 (entget (entnext NE)))))
                   (while (and (setq NE (entnext NE)) (setq ED (entget NE))(/= "SEQEND" (cdr (assoc 0 ED))) )
                         (if (= (setq kk3 (cdr (assoc 10 (entget (entnext NE))))) nil)
                             (setq kk3 kxy)
                     (setq dis (rtos (* (distance kk2 kk3) bilixishu) 2 zjws))
                     (setq an (angle kk2 kk3))
                     (setq kkm (polar kk2 an (/ (distance kk2 kk3) 2)))
                         (if (or (< (/ (* 3 pi) 4) an (/ (* 7 pi) 4)) (= an (/ (* 7 pi) 4))   )
                             (COMMAND "text" "J" "C" kkm hei kk2 dis)
                             (COMMAND "text" "J" "C" kkm hei kk3 dis)
              (setq YUbeishanchu (entlast))
                   (if (= (LOGAND pdtj 128) 128)
                       ( entdel YUbeishanchu)
    (if    (= TJ "LWPOLYLINE")
        (setq num (length ED))
        (setq i 0)
        (setq j 0)
             (while (< i num)
                  (setq ss1 (nth i ED))
                  (setq ss2 (car ss1))
                    (if (= ss2 10)
                              (if (> j 0)
                                         (setq ss3 ss4)
                                         (setq ss4 (cdr ss1))
                                         (setq dis (rtos (distance ss3 ss4) 2 zjws))
                                         (setq an (angle ss3 ss4))
                                         (setq kkm (polar ss3 an (/ (distance ss3 ss4) 2)))
                                            (COMMAND "text" "J" "BC" kkm hei ss3 dis)
                                            (COMMAND "text" "J" "BC" kkm hei ss4 dis)
                                      );progn
                             );if
                           (setq j (+ j 1))
                        );progn
                   );if
               (setq i (+ i 1))
  (  setq ZXH (+ ZXH 1))
   (COMMAND "REDRAW")
发表于 2024-1-26 15:20:23 | 显示全部楼层
感觉楼主没有详细表达出自己想要什么?
GMT+8, 2025-5-1 12:23 , Processed in 0.155265 second(s), 23 queries , Gzip On.
