楼主: 277283904
[基础] 新开一帖,谁能帮写一下,怎么能把拉伸命令和‘cal组合起来一起用呢?
发表于 2024-1-27 20:12:07 | 显示全部楼层
zhufeng1004 发表于 2024-1-26 23:06
加上记忆功能  记住上次拉伸距离就完美了
  1. (defun c:tt (/ ang dis pt1 pt2 ssls)
  2.         (if (null (type c:cal))
  3.     (cond
  4.                         ((findfile "GEOMCAL.CRX") (ARXLOAD "GEOMCAL.CRX"))
  5.                         ((findfile "GEOMCAL.ARX") (ARXLOAD "GEOMCAL.ARX"))
  6.                 )
  7.   )
  8.         (mapcar 'set '(ang dis) **stretch_dat**)
  9.         (or ang (setq ang 0))
  10.         (or dis (setq dis 100))
  11.         (setq pt2 nil)
  12.         (setq ssls (ssget))
  13.         (setq pt1 (getpoint (strcat "\n指定基点或默认相对基点位移量<" (rtos dis) ">: ")))
  14.         (if ssls
  15.                 (progn
  16.                         (if pt1
  17.                                 (progn
  18.                                         (command "_.stretch" ssls "" pt1 "non" (cal (getstring "\n输入相对基点位移量算式:")))
  19.                                         (setq pt2 (getvar "lastpoint"))
  20.                                 )
  21.                         )
  22.                         (if pt2
  23.                                 (setq **stretch_dat** (list (angle pt1 pt2) (distance pt1 pt2)))
  24.                                 (progn
  25.                                         (setq pt1 '(0 0 0) pt2 (polar pt1 ang dis))
  26.                                         (command "_.stretch" ssls "" "_non" pt1 "_non" pt2)
  27.                                 )
  28.                         )
  29.                 )
  30.         )
  31.         (princ)
  32. )
发表于 2024-1-27 21:24:24 | 显示全部楼层
下面这个程序的记忆功能比较好,就是没有计算功能》》》    你的试了一下好像和我想的不一样
(defun c:ss (/ s_dis)
  (command ".STRETCH" (ssget) "")
  (command (setq BasicPoint (getpoint "\n指定基点:")))
  (if (= nil s_dis_all)
      (setq s_dis_all (getreal "\n输入拉伸距离:"))
      (command s_dis_all)
      (setq
s_dis (getreal
  (strcat "\n输入拉伸距离<" (rtos s_dis_all 2 4) ">:")
      (if (= nil s_dis)
(setq s_dis s_dis_all)
      (command s_dis)
      (setq s_dis_all s_dis)
发表于 2024-1-27 21:26:27 | 显示全部楼层
能把CAL   jj加在我的下面这个程序里面吗
发表于 2024-1-27 22:01:43 | 显示全部楼层
  1. ;;修改了一下
  2. (defun c:tt (/ s_dis str)
  3.   (if (null (type c:cal))
  4.     (cond
  5.       ((findfile "GEOMCAL.CRX") (ARXLOAD "GEOMCAL.CRX"))
  6.       ((findfile "GEOMCAL.ARX") (ARXLOAD "GEOMCAL.ARX"))
  7.     )
  8.   )
  9.   (command ".STRETCH" (ssget) "")
  10.   (command (setq BasicPoint (getpoint "\n指定基点:")))
  11.   (if (= nil s_dis_all)
  12.     (progn
  13.       (setq s_dis_all (cal (getstring "\n输入拉伸距离<>:")))
  14.       (command "non" s_dis_all)
  15.     )
  16.     (progn
  17.       (setq str        (getstring
  18.                   (strcat "\n输入拉伸距离<" (rtos s_dis_all 2 4) ">:")
  19.                 )
  20.       )
  21.       (if (= str "")
  22.         (setq s_dis s_dis_all)
  23.         (setq s_dis (cal str))
  24.       )
  25.       (command "non" s_dis)
  26.       (setq s_dis_all s_dis)
  27.     )
  28.   )
  29.   (princ)
  30. )
zhufeng1004 + 1 赞一个!
发表于 2024-1-27 23:05:23 | 显示全部楼层
不错。多谢分享
发表于 2024-2-28 16:35:43 | 显示全部楼层
lingduwx 发表于 2024-1-17 13:25
只用了拉伸命令,中间没有输入其他的,然后就是输入长度
你这是用了插件吧,正常拉伸是输入多少拉多少,你这是直接输入得这个结果
发表于 2024-5-5 21:29:58 | 显示全部楼层
拉伸到,配合TK直接输入拉伸的目标长度。根本不需要CAL计算或写代码
发表于 5 天前 | 显示全部楼层
想请教个问题,我写的程序调用cal函数,但是打开cad第一次加载时,必然会出现cal函数错误。必须手动在命令栏输入cal,然后取消,再输入快捷键才可以继续运行。参照这个帖子的代码改了cal调用方式,还是会出现一样的问题。您知道这是怎么回事吗。GEOMCAL.ARX在手动命令栏输入cal之后才会显示加载成功。
GMT+8, 2025-7-5 01:29 , Processed in 0.216103 second(s), 20 queries , Gzip On.
