查看: 1669|回复: 6
怎么做快速切换线型的控制面板?
发表于 2024-1-14 03:16:40 | 显示全部楼层 |阅读模式
类似这种图层切换面板,既可以在命令行选择,又可以在面板选择,可同时选多个对象,即选即改。
如何修改下面这些代码?要求默认保留上一次选择图层?
;;重画选择集中的对象-----(一级)-----
;;Sel为选择集或图元名; mode为方式码
;;mode 1 在屏幕重画该选择集对象
;;mode 2 隐藏该选择集对象
;;mode 3 <醒目显示> 该选择集对象
;;mode 4 取消<醒目显示>该选择集对象
(defun sl-sel-redrawsel (sel mode / n)
        (if sel
                (cond
                        ((= 'PICKSET (type sel))
                                (repeat (setq n (sslength sel))
                                        (redraw (ssname sel (setq n (1- n))) mode)
                        ((= 'ENAME (type sel))
                                (redraw sel mode)
        t
(defun C:W4 (/ key nm-gg ss)
        (defun nm-gg (ss tc co lt)
                (if (not (tblsearch "layer" tc))
                        (command "-layer" "m" tc "c" "3" "" "")
                (command "CHPROP" ss "" "la" tc "c" co "LT" lt "")
        (while (setq ss (ssget ":S"))
                (sl-sel-redrawsel ss 3) ;亮显
                (initget 1 "0 1 2 3 4 5")
                (setq key (getkword "\n 选择图层[0(0)/图层1(1)/图层2(2)/图层3(3)/图层4(4)/图层5(5)]"))
                (cond   ;;;(nm-gg ss "图层0" "COL" "LT")
                        ((= key "0")
                                (nm-gg ss "图层0" "bylayer" "bylayer")
                        ((= key "1")
                                (nm-gg ss "图层1" "1" "bylayer")
                        ((= key "2")
                                (nm-gg ss "图层2" "2" "bylayer")
                        ((= key "3")
                                (nm-gg ss "图层3" "3" "bylayer")
                        ((= key "4")
                                (nm-gg ss "图层4" "4" "bylayer")
                        ((= key "5")
                                (nm-gg ss "图层5" "5" "bylayer")
                (sssetfirst nil nil) ;取消亮显
(princ "\n****W4图层切换****") (princ)
发表于 2024-1-14 14:12:32 | 显示全部楼层
(defun C:NM (/ key nm-gg ss)
        (defun NM-GG (ss tc CO LT)
                (command "CHPROP" ss "" "la"  tc   "c" CO   "LT" LT  "")
        (setq ss(ssget))
        (setq key
                (getkword
        (cond   ;;;(NM-GG SS "图层0" "COL" "LT")
                ((= key "0")
                        (NM-GG SS "图层0" "bylayer" "bylayer")
                ((= key "1")
                        (NM-GG SS "图层1" "1" "bylayer")
                ((= key "2")
                        (NM-GG SS "图层2" "2" "bylayer")
                ((= key "3")
                        (NM-GG SS "图层3" "3" "bylayer")
                ((= key "4")
                        (NM-GG SS "图层4" "4" "bylayer")
                ((= key "5")
                        (NM-GG SS "图层5" "5" "bylayer")
发表于 2024-1-14 09:37:34 | 显示全部楼层
(defun C:NM (/ key ss)
        (setq ss(ssget))
        (setq key
                (getkword
        (cond
                ((= key "0")
                        (command  "CHPROP" ss "" "la" "图层0"  "")
                ((= key "1")
                        (command  "CHPROP" ss "" "la" "图层1"  "")
                ((= key "2")
                        (command  "CHPROP" ss "" "la" "图层2"  "")
                ((= key "3")
                        (command  "CHPROP" ss "" "la" "图层3"  "")
                ((= key "4")
                        (command  "CHPROP" ss "" "la" "图层4"  "")
                ((= key "5")
                        (command  "CHPROP" ss "" "la" "图层5"  "")
 楼主| 发表于 2024-1-14 13:35:57 | 显示全部楼层
        (setq ss(ssget))
这个只切换图中已存在的图层,能不能优化一下,原图中没的该图层的话就直接新建,有的话就直接切换?
还有颜色、线型也可以加上。
 楼主| 发表于 2024-1-14 14:57:07 | 显示全部楼层
你这个还是不能新建图层,只能改为原图纸中已存在的图层。
 楼主| 发表于 2024-1-14 21:57:22 | 显示全部楼层
                (if (not (tblsearc ...
恩,这个可以,能不能再加一个功能,默认保留上一次选择的图层?
发表于 2024-6-2 23:24:37 | 显示全部楼层
大神牛B,学习了
GMT+8, 2025-5-22 08:13 , Processed in 0.169580 second(s), 24 queries , Gzip On.
