- 积分
- 1729
- 明经币
- 个
- 注册时间
- 2011-10-24
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
- //定义被积函数
- static double IntegrandCos(double l, double A)
- { return Math.Cos(Math.Pow(l, 2) / (2 * A * A)); }
- static double IntegrandSin(double l, double A)
- { return Math.Sin(Math.Pow(l, 2) / (2 * A * A)); }
- // 梯形法则进行数值积分
- static double TrapezoidalRule(Func<double, double, double> integrand, double a, double b, int n, double A)
- double h = (b - a) / n;
- double sum = 0.5 * (integrand(a, A) + integrand(b, A));
- for (int i = 1; i < n; i++)
- { sum += integrand(a + i * h, A); }
- return sum * h;
- /// <summary>
- /// 使用高斯-克朗罗德法则进行积分计算切线支距坐标
- /// </summary>
- /// <param name="l">缓和曲线长度</param>
- /// <param name="A">缓和曲线参数</param>
- /// <param name="n">分割的数量,越大计算越精确但是计算量越大</param>
- /// <param name="x">切线支距X坐标</param>
- /// <param name="y">切线支距Y坐标</param>
- public void QXZJZBjifenX(double l, double A, int n, out double x, out double y)
- x = 0;
- y = 0;
- // 使用高斯-克朗罗德法则进行积分计算
- x = TrapezoidalRule(IntegrandCos, 0, l, n, A);
- y = TrapezoidalRule(IntegrandSin, 0, l, n, A);
- /// <summary>
- /// 根据缓和曲线长度和缓和曲线参数求缓和曲线的坐标增量
- /// </summary>
- /// <param name="X">X方向坐标增量</param>
- /// <param name="Y">Y方向坐标增量</param>
- public void Qzjzb(double l, double A, out double X, out double Y)
- //X = l - Math.Pow(l, 5) / (40 * Math.Pow(A, 4)) + Math.Pow(l, 9) / (3456 * Math.Pow(A, 8)) - Math.Pow(l, 13) / (599040 * Math.Pow(A, 12));
- // Y = Math.Pow(l, 3) / (6 * Math.Pow(A, 2)) - Math.Pow(l, 7) / (336 * Math.Pow(A, 6)) + Math.Pow(l, 11) / (42240 * Math.Pow(A, 10)) - Math.Pow(l, 15) / (9676800 * Math.Pow(A, 14));
- QXZJZBjifenX(l, A, 10000, out X, out Y);
复制代码
