查看: 1388|回复: 6
[提问] 求助大佬们,调整标注尺寸公差精度的lsp该如何写?
发表于 2023-12-4 08:41:57 | 显示全部楼层 |阅读模式
程序构想:先选择该标注,然后程序变更该标注的公差精度
类似于这种调整标注精度的
(defun c:w2         (/ ss)(setq ss (ssget '((0 . "Dimension"  )))) (command "aidimprec" "2" ss "") (princ))
发表于 2023-12-4 14:19:58 | 显示全部楼层
可以试试下面的代码………………(defun c:ggcha (/ ss n cnt# enlst)
        (vl-load-com)
        (setq jidulst (list 'acDimPrecisionZero
                'acDimPrecisionOne
                'acDimPrecisionTwo
                'acDimPrecisionThree
                'acDimPrecisionFour
                'acDimPrecisionFive
                'acDimPrecisionSix
                'acDimPrecisionSeven
                'acDimPrecisionEight
        (initget 5 "0 1 2 3 4 5 6 7 8")
        (setq int# (getint "\n请输入精度<保留小数点的位数>[0位,1位,2位,3位,4位,5位,6位,7位,8位]"))
        (while (setq ss (ssget '((0 . "DIMENSION"))))
                (setq n (sslength  ss )
                      cnt# n
                (repeat n
                (setq ename^ (ssname ss (setq cnt# (1- cnt#))))
                (setq enameobj  (vlax-ename->vla-object ename^ ))
                (vlax-put-property enameobj 'TolerancePrecision (eval (nth int# jidulst))))
发表于 2023-12-4 09:42:07 | 显示全部楼层
应该是修改指定标注的DIMTDEC系统变量值。(COMMAND "_DIMOVERRIDE" "DIMTDEC" "3" ""),你试下
 楼主| 发表于 2023-12-4 10:02:21 | 显示全部楼层
感谢大佬,等会去试试
 楼主| 发表于 2023-12-5 07:55:41 | 显示全部楼层
        (vl-load-com)
        (setq jidu ...
感谢大佬,可以设置公差精度
 楼主| 发表于 2023-12-5 09:27:39 | 显示全部楼层
        (vl-load-com)
        (setq jidu ...
再次感谢大佬,完美解决
发表于 2025-4-10 10:16:59 | 显示全部楼层
        (vl-load-com)
        (setq jidu ...
怎么没反应
GMT+8, 2025-4-30 23:22 , Processed in 0.182075 second(s), 26 queries , Gzip On.
