查看: 2181|回复: 3
[求助][ARX]DAO数据库在ARX中使用的问题
发表于 2004-4-3 11:17:00 | 显示全部楼层 |阅读模式
本人开发环境为WIN2000AS,CAD2004中文版,VC.NET,ObjectARX2004,在开发市政软件中使用Access数据库,发生如下问题: 请各位高手、斑竹测试程序,赐教,万分感谢! 数据库“纵横断面测量数据表”表格的格式为: 编号 原地面桩号 原地面高程 程序如下: #include "StdAfx.h"
#include "arxHeaders.h"
#include "afxdao.h" //-----------------------------------------------------------------------------
#define szRDS _RXST("CHEN") //-----------------------------------------------------------------------------
CDaoDatabase DB; // ----- CHENArxProject19._C191 command (do not rename)
static void CHENArxProject19_C191(void)
// Add your code for command CHENArxProject19._C191 here
if (DB.IsOpen())
DB.Close();
acutPrintf("\nDB was closed!");
}else
acutPrintf("\nDB was already closed!");
} // ----- CHENArxProject19._C192 command (do not rename)
static void CHENArxProject19_C192(void)
// Add your code for command CHENArxProject19._C192 here
double XS = 1000.00;
double YS = 100.00; if (!DB.IsOpen())
CFileDialog Dg(TRUE,NULL,NULL,NULL,"道路工程数据库(*.MDB)|*.MDB|");
if (Dg.DoModal() != IDOK)
acutPrintf("\nC192 was cancelled!");
return;
} CString DBname;
DBname = Dg.GetPathName(); try
DB.Open(DBname,TRUE,FALSE,"");
catch (CDaoException* e)
e->ReportError();
e->Delete();
acutPrintf("\n DB open error!");
return;
} acutPrintf("\nDB was open!");
} CDaoTableDef ydm(&DB);
try
ydm.Open("纵横断面测量数据表");
e->ReportError();
e->Delete();
DB.Close();
acutPrintf("\n纵横断面测量数据表打开错误\n数据库已经关闭!");
return;
} CDaoRecordset rdydm(&DB);
rdydm.Open(&ydm,dbOpenTable,dbDenyRead); long num = rdydm.GetRecordCount();
if (num = 0)
acutPrintf("\n(纵横断面测量数据表)中没有数据!");
} rdydm.MoveFirst(); AcDbPolyline* retLightPoly = new AcDbPolyline();
AcGePoint2d pt;
double ptx, pty;
int i = 0; while (!rdydm.IsEOF())
COleVariant txt0 = rdydm.GetFieldValue(0);
COleVariant txt1 = rdydm.GetFieldValue(1);
COleVariant txt2 = rdydm.GetFieldValue(2); ptx = (double)txt1.dblVal * (1000.00/XS);
pty = (double)txt2.dblVal * (1000.00/YS);
pt.set(ptx, pty); retLightPoly->addVertexAt(i, pt);
i++; rdydm.MoveNext();
} retLightPoly->minimizeMemory(); AcDbObjectId id;
retLightPoly->setColorIndex(1);
AddEntToDB(retLightPoly, id); }
ACED_ARXCOMMAND_ENTRY_AUTO(CArxProject19App, CHENArxProject19, _C191, C191, ACRX_CMD_TRANSPARENT, NULL)
ACED_ARXCOMMAND_ENTRY_AUTO(CArxProject19App, CHENArxProject19, _C192, C192, ACRX_CMD_TRANSPARENT, NULL) 其中C192画出原地面线,C191关闭数据库。 在CAD中可以画出地面线,关闭数据库显示正常,但是在关闭CAD时,CAD崩溃,提示如下: FATAL ERROR:Unhandled Access Violation Reading 0x5f52527 Exception at 5f52527h 我试过在当前CAD中绘制一个填充图案之后再关闭CAD,CAD就不会发生任何问题正常退出,划线或其他图元CAD同样崩溃退出。 我以前用VBA开发CAD中的Access数据库程序时发现在打开数据库时可以看到同时产生一个Access数据库锁定文件,但是用ARX打开数据库时没有发现锁定文件产生,是否跟这有关?如何解决?是否数据库打开函数使用有问题?
发表于 2004-4-3 16:33:00 | 显示全部楼层
我想这样的错误编程的见的比较多,主要在内存上
 楼主| 发表于 2004-4-8 09:04:00 | 显示全部楼层
如何解决?
发表于 2004-4-12 10:27:00 | 显示全部楼层
CDaoRecordset rdydm(&DB); 二个不能同时打开!
GMT+8, 2025-5-11 11:46 , Processed in 0.156802 second(s), 23 queries , Gzip On.
