- 积分
- 30687
- 明经币
- 个
- 注册时间
- 2005-5-16
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
'线上加点
Sub Start_XianJiaDian()
'1、选线
Dim PolyXian As AcadLWPolyline 'AcadPolyline 'AcadEntity
Dim Dianwei As Variant
On Error Resume Next
AppActivate ThisDrawing.Application.Caption
ThisDrawing.Utility.GetEntity PolyXian, Dianwei, "选取线" '如何判断没选任何东西呢?
If Err.Number = -2147352567 Then
MsgBox "没有选取对象!"
Err.Clear
End
Else
If Err.Number = 13 Then
MsgBox "选取的对象不是多段线!"
Err.Clear
End
End If
Dim DianShu As Integer
DianShu = (UBound(PolyXian.Coordinates) + 1) / 2 '求出总点数
Dim i As Integer, j As Integer
Dim JieDian(0 To 2) As Double
Dim ZuobiaoJi As Variant
Dim Ang() As Double '直线的角度
ReDim Ang(DianShu)
ZuobiaoJi = PolyXian.Coordinates
Dim pLine As AcadLine
For i = 1 To DianShu
JieDian(0) = ZuobiaoJi(i * 2 - 2)
JieDian(1) = ZuobiaoJi(i * 2 - 1)
JieDian(2) = 0
Set pLine = ThisDrawing.ModelSpace.AddLine(Dianwei, JieDian)
Ang(i) = pLine.Angle ' 记录新建直线的角度,这个角度为弧度值。
' Debug.Print Ang(i)
pLine.Delete
Next i
Dim Qd As Integer '点序号
'通过直线夹角判断所选取点离线上的结点哪个最近,,夹角越小,离点越近
Dim JiaJiao() As Double
ReDim JiaJiao(DianShu - 1)
For i = 1 To DianShu - 1
JiaJiao(i) = Abs(Ang(i) - Ang(i + 1)) '夹角
Next i
JiaJiao(i) = JiaJiao(i) / 3.1415926 * 180 '夹角转成度
JiaJiao(i) = Abs(180 - JiaJiao(i))
' Debug.Print JiaJiao(i)
Next i
Dim jd As Double
jd = JiaJiao(1)
If JiaJiao(i) < jd Then
jd = JiaJiao(i) '找最小夹角和对应的序号
Qd = i
End If
Next i
Dim JiaDian As Variant
JiaDian = ThisDrawing.Utility.GetPoint(, vbCrLf & "请指定添加点的位置")
Dim tjdzb(0 To 1) As Double
tjdzb(0) = JiaDian(0)
tjdzb(1) = JiaDian(1)
PolyXian.AddVertex Qd, tjdzb
End If
End Sub
