帖子
查看: 1160|回复: 3
请求将已有面积周长代码增加一个立面面积
发表于 2023-11-7 21:05:35 | 显示全部楼层 |阅读模式
1明经币
已有代码——面积周长
(defun C:MJZC (/  pt a b c s ss tt ttt )
(vl-load-com)
(setvar "cmdecho" 0)
(setq TTS1 (getvar "textsize"))
(setvar "textsize" 300)
(setvar "cecolor" "20")
(while
(setq pt (getpoint "\\n请点取要标注的范围内一点:"))
(command "-boundary" pt "" "")
(setq a (entlast))
(setq b (vlax-ename->vla-object a))
(setq s (vla-get-area b))
(setq ss (rtos (/ s 1000000)2 2))
(setq tt (vla-get-length b))
(setq ttt (rtos (/ tt 1000)2 2))
(command "mtext"  pt pt (strcat "面积=" ss "平米\n" "周长=" ttt "米") "")
(command "erase" a "")
(command "cecolor" "bylayer")
(setvar "textsize" TTS1)
(setvar "cmdecho" 1)
需求是增加一个功能,运行代码后首先让输入立面高度(单位为米),然后点取标注范围后,出来的文字增加一行立面面积,
变成:“面积=xxx,周长=xxx,立面=xxx”,也就是要用周长x输入的立面高度,并且输入的立面高度带记忆功能。
截图示意
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2023-11-7 21:05:36 | 显示全部楼层
yyz123121 发表于 2023-11-8 10:47
哪位帮忙看看哪里出错了,一运行就出现“错误: 参数类型错误: numberp:”
(defun C:MJZC (/  pt a b c s ...
  1. (defun C:MJZC (/  pt a b c s ss tt ttt )
  2. (vl-load-com)
  3. (setvar "cmdecho" 0)
  4. (setq TTS1 (getvar "textsize"))
  5. (setvar "textsize" 300)
  6. (setvar "cecolor" "20")
  7.         (if (not LMH)
  8.         (setq LMH (getstring "\n立面高度:"))
  9.         (setq LMH (if (/= "" (setq LMH_D (getstring (strcat "\n立面高度<" LMH ">:")))) LMH_D LMH))
  10. )
  11. (while
  12. (setq pt (getpoint "\\n请点取要标注的范围内一点:"))
  13. (command "-boundary" pt "" "")
  14. (setq a (entlast))
  15. (setq b (vlax-ename->vla-object a))
  16. (setq s (vla-get-area b))
  17. (setq ss (rtos (/ s 1000000)2 2))
  18. (setq tt (vla-get-length b))
  19. (setq ttt (rtos (/ tt 1000)2 2))
  20. (setq LMMJ (rtos (* (atof LMH) (atof  ttt)) 2 2))
  21. (command "mtext"  pt pt (strcat "面积=" ss "平米\n" "周长=" ttt "米\n" "立面=" LMMJ "平米") "")
  22. (command "erase" a "")
  23. )
  24. (command "cecolor" "bylayer")
  25. (setvar "textsize" TTS1)
  26. (setvar "cmdecho" 1)
  27. (princ)
  28. )
 楼主| 发表于 2023-11-8 10:47:14 | 显示全部楼层
(vl-load-com)
        (if (not LMH)
(while
(setq a (entlast))
(setq LMMJ (rtos (* LMH ttt)2 2))
 楼主| 发表于 2023-11-8 17:06:24 | 显示全部楼层
GMT+8, 2025-6-10 10:29 , Processed in 0.175850 second(s), 22 queries , Gzip On.
