查看: 838|回复: 0
在线CAD SDK 集成后怎么实现参数化绘图(在线编辑CAD)
发表于 2023-11-6 14:04:17 | 显示全部楼层 |阅读模式
前言
MxCAD 的WEB CAD SDK提供了参数化绘图的功能, 我们可以通过查看继承自McDbEntity的类的所有实例,它们都可以进行参数化的绘图。
首先我们应该在页面上显示一张图纸, 请根据mxcad入门文档的说明或者通过查看 github| gitee存储的初始化各种示例项目查看代码来实现显示图纸的页面。
点的绘制
参数化绘制一个CAD中的点:
  1. import { MxCpp, McDbPoint, McCmColor } from "mxcad"
  2. const mxcad = MxCpp.App.getCurrentMxCAD()
  3. const point = new McDbPoint()
  4. const color = new McCmColor()
  5. color.setRGB(0, 255, 255)
  6. point.trueColor = color
  7. point.setPosition(200, 200)
  8. mxcad.drawEntity(point)
复制代码
效果图:
多行文字
绘制多行文字代码如下:
  1. import { MxCpp, McGePoint3d, McCmColor, McDb, McDbMText } from "mxcad"
  3. const mText = new McDbMText()
  4. const textId = mxcad.drawEntity(mText)
  5. const text = textId.getMcDbEntity() as McDbMText
  6. text.attachment = McDb.AttachmentPoint.kTopLeft
  7. text.contents = "内容 \\P 内容"
  8. text.location = new McGePoint3d(10, 20)
  9. text.trueColor = new McCmColor(255, 0, 255)
  10. text.textHeight = 10
  11. mxcad.updateDisplay()
复制代码
效果图:
单行文字
绘制单行文本代码如下:
  1. import { MxCpp, McGePoint3d, McCmColor, McDb, McDbText } from "mxcad"
  3. const text = new McDbText()
  4. text.widthFactor = 1
  5. text.horizontalMode = McDb.TextHorzMode.kTextCenter
  6. text.verticalMode = McDb.TextVertMode.kTextBottom
  7. text.textString = "内容"
  8. text.position = new McGePoint3d(-10, -20)
  10. text.height = 10
  11. mxcad.drawEntity(text)
  12. mxcad.updateDisplay()
复制代码
效果图:
对齐标注
绘制对齐标注尺寸代码如下:
  1. import { MxCpp, McGePoint3d, McCmColor, McDb, McDbAlignedDimension } from "mxcad"
  3. const mDimension = new McDbAlignedDimension()
  4. const dimensionId = mxcad.drawEntity(mDimension)
  5. const dimension = dimensionId.getMcDbEntity() as McDbAlignedDimension
  6. dimension.xLine1Point = new McGePoint3d(0, 255)
  7. dimension.xLine2Point = new McGePoint3d(30, 60)
  8. dimension.dimLinePoint = new McGePoint3d(88, 88)
  9. dimension.textAttachment = McDb.AttachmentPoint.kTopLeft
  10. dimension.trueColor = new McCmColor(200, 255, 0)
  11. dimension.oblique = 0
效果图:
旋转标注
绘制旋转标注尺寸代码如下:
  1. import { MxCpp, McGePoint3d, McCmColor, McDb, McDbRotatedDimension } from "mxcad"
  3. const mDimension = new McDbRotatedDimension()
  5. const dimension = dimensionId.getMcDbEntity() as McDbRotatedDimension
  6. dimension.xLine1Point = new McGePoint3d(100, -137)
  7. dimension.xLine2Point = new McGePoint3d(161,30)
  8. dimension.dimLinePoint = new McGePoint3d(80, -60)
  10. dimension.textRotation = 0.23
  11. dimension.trueColor = new McCmColor(200, 255, 0)
  12. dimension.oblique = 0
  13. dimension.rotation = 0
  14. mxcad.updateDisplay()
效果图:
绘制直线
绘制直线代码如下:
  1. import { MxCpp, McCmColor, McDbLine } from "mxcad"
  3. const line = new McDbLine(0, 0, 0, -80, -80, 0)
  4. line.trueColor = new McCmColor(255, 0, 0)
  5. mxcad.drawEntity(line)
复制代码
效果图:
绘制圆
绘制圆代码如下:
  1. import { MxCpp, McCmColor, McDbCircle } from "mxcad"
  3. const circle = new McDbCircle(-100, 300, 0, 20)
  4. circle.trueColor = new McCmColor(255, 0, 0)
  5. mxcad.drawEntity(circle)
复制代码
效果图:
绘制多义线
绘制多义线代码如下:
  1. import { MxCpp, McGePoint3d, McDbPolyline } from "mxcad"
  3. const polyline = new McDbPolyline()
  4. polyline.isClosed = false
  5. polyline.constantWidth = 10
  6. polyline.addVertexAt(new McGePoint3d(100, 100))
  7. polyline.addVertexAt(new McGePoint3d(200, 100), 0.2, 1, 5, 1)
  8. polyline.addVertexAt(new McGePoint3d(100, 200), 0.2, 5, 1, 2)
  9. mxcad.drawEntity(polyline)
复制代码
效果图:
绘制圆弧
绘制圆弧代码如下:
  1. import { MxCpp, McGePoint3d, McDbArc, McCmColor } from "mxcad"
  3. const arc = new McDbArc()
  4. arc.center = new McGePoint3d(-100, -100),
  5. arc.radius = 20
  6. arc.startAngle = Math.PI / 2
  7. arc.endAngle = Math.PI * 3 / 2
  8. arc.trueColor = new McCmColor(255, 233, 0)
  9. mxcad.drawEntity(arc)
复制代码
效果图:
绘制椭圆
绘制椭圆代码如下:
  1. import { MxCpp, McGePoint3d, McDbEllipse, McCmColor, McGeVector3d } from "mxcad"
  3. const ellipse = new McDbEllipse()
  4. ellipse.center = new McGePoint3d(-200, -200),
  5. ellipse.majorAxis = new McGeVector3d(0, 300, 0)
  6. ellipse.minorAxis = new McGeVector3d(33, 0, 0)
  7. ellipse.radiusRatio = 0.5
  8. ellipse.startAngle = Math.PI / 2
  9. ellipse.endAngle = Math.PI * 3 / 2
  10. ellipse.trueColor = new McCmColor(255, 233, 0)
  11. mxcad.drawEntity(ellipse)
复制代码
效果图:
交互绘制
如果上述位置属性是用户通过点击或者输入框输入,mxcad就提供了这样一套用于获取用户输入并在绘制中得到输入的机制,最频繁的应该是鼠标点击输入。
1、通过鼠标点击获取CAD图纸中的坐标位置,代码如下:
  1. import { MxCADUiPrPoint } from "mxcad"
  2. const getPoint = new MxCADUiPrPoint()
  3. const point = await getPoint.go()
  4. console.log(point)
复制代码
上述代码打印的就是一个坐标点了, 其坐标点是用户通过鼠标点击获取到的对应的图纸坐标位置
2、通过输入框输入值, 来确定除了坐标以外的其他参数,代码如下:
  1. const input = document.createElement("input")
  2. input.addEventListener("keydown", (e: KeyboardEvent) => {
  3.     // 设置传输命令行消息数据
  4.     MxFun.setCommandLineInputData((e.target as HTMLInputElement).value, e.keyCode);
  5. })
  6. document.body.appendChild(input)
复制代码
mxcad中引用了mxdraw 下载依赖时会自动下载, 所有我们只要安装了mxcad就可以使用mxdraw
如上代码所示, 我们传入用户输入的内容和对应按键的keyCode值
  1. const getInt = new MxCADUiPrInt()
  2. const getKey = new MxCADUiPrKeyWord
  3. const getStr = new MxCADUiPrString()
  4. getInt.setMessage("提示用户输入数字:")
  5. const intVal = await getInt.go()
  6. console.log(intVal)
  7. getKey.setMessage("提示用户关键词 A、 B、 C:")
  8. getKey.setKeyWords("A B C")
  9. const keyVal = await getKey.go()
  10. console.log(keyVal)
  11. getStr.setMessage("提示用户输入字符串:")
  12. const strVal = await getStr.go()
  13. console.log(strVal)
  14. 上述代码会在用户输入对应类型的数据后按下回车键(Enter或者Esc)才会往下执行, 通过setMessage设置提示,最终得到用户输入的数据, 通过这些数据进行参数化绘图。
  15. 最后这些设置的用户提示通过下面代码获得:
  16. import { MxFun } from "mxdraw"
  17. MxFun.listenForCommandLineInput(({ msCmdTip, msCmdDisplay, msCmdText }) => {
  18.     console.log(msCmdTip, msCmdDisplay, msCmdText)
  19. }
  20. );
复制代码
如果你无法理解上述某个函数的意思,可以在mxdraw API文档或者mxcad API文档中查看对应的APi说明
参数化绘制文字的完整流程
下面简单实现一个的参数化绘制文字的流程:
  1. import { MxFun } from "mxdraw"
  2. import { MxCADUiPrInt, MxCADUiPrKeyWord, MxCADUiPrString, MxCADUiPrPoint, McDbText, MxCpp } from "mxcad"
  3. MxFun.addCommand("Mx_draw_Text", async ()=> {
  4.     const getInt = new MxCADUiPrInt()
  5.     const getKey = new MxCADUiPrKeyWord()
  6.     const getStr = new MxCADUiPrString()
  7.     const getPoint = new MxCADUiPrPoint()
  8.     const text = new McDbText()
  9.     getPoint.setMessage("请点击确定文字位置")
  10.     const position = await getPoint.go()
  11.     if(!position) return
  12.     text.position = position
  13.     getInt.setMessage("请输入文字高度")
  14.     const height = await getInt.go()
  15.     if(!height) return
  16.     text.height = height
  17.     getKey.setMessage("选择水平对齐方式 快捷键 L: 左对齐 C: 居中对齐 R: 右对齐 A: 水平对齐 M: 垂直中间对齐 F: 自适应")
  18.     getKey.setKeyWords("L C R A M F")
  19.     await getKey.go()
  20.     if(getKey.isKeyWordPicked("L")) text.horizontalMode = McDb.TextHorzMode.kTextLeft
  21.     if(getKey.isKeyWordPicked("C")) text.horizontalMode = McDb.TextHorzMode.kTextCenter
  22.     if(getKey.isKeyWordPicked("R")) text.horizontalMode = McDb.TextHorzMode.kTextRight
  23.     if(getKey.isKeyWordPicked("A")) text.horizontalMode = McDb.TextHorzMode.kTextAlign
  24.     if(getKey.isKeyWordPicked("M")) text.horizontalMode = McDb.TextHorzMode.kTextMid
  25.     if(getKey.isKeyWordPicked("F")) text.horizontalMode = McDb.TextHorzMode.kTextFit
  26.     getStr.setMessage("请输入文字内容")
  27.     const str = await getStr.go()
  28.     if(!str) return
  29.     text.textString = str
  30.     const mxcad = MxCpp.App.getCurrentMxCAD()
  31.     mxcad.drawEntity(text)
  32. })
复制代码
演示Demo源码:
https://gitee.com/mxcadx/mxdraw-article/tree/master/mxcad参数化绘图/demo.zip
GMT+8, 2025-5-1 02:54 , Processed in 0.189096 second(s), 24 queries , Gzip On.
