查看: 2741|回复: 20
论坛直接搜函数不能搜到相关用法贴一个vl-every函数用法
发表于 2023-9-12 09:50:02 | 显示全部楼层 |阅读模式
论坛直接搜函数貌似不能按内容检索,好像是按帖子主体关键字搜索的贴一个vl-every函数用法
(setq vl (list '(1 2 0 ) '(1 2 0 ) '(1 2 0 ) '(2 2 0 )))
(setq is (v-every '(lambda (x) (zerop (last x))) vL));判断是表最后元素是否为0
结果:T
(setq is (vl-every '(lambda (x) (= 1 (car x))) vL));判断是表第一个元素是否为1
结果:nil
(vl-every 'numberp '("h" 0.0 90.0 180.0 270.0 360.0));判断是否都为实数
结果:nil
(setq a (vl-remove-if '(lambda (x) (= 1 (car x)) ) vL));移除第一个元素是为1的表
结果:((2 2 0))
如判断用forach 或者mapcar 判断也行,但是感觉vl-every省事。
(setq lst (list '(1 2 3 4 5 6)  '(1 2 3 4 5 6) '(1 2 3 4 5 6) '(2 2 3 4 5 6)))
(setq fuz 1)
(setq a (car lst))
(vl-some
          (function (lambda ( x )
            (equal x a fuzz)
          (cdr lst)
结果:T
(setq lst (list '(1 2 3 4 5 6)    '(2 2 3 4 5 6) '(7 8 9 10 11)))
(setq fuzz 1)
(setq a (car lst))
(vl-some
            (equal x a fuzz)
          (cdr lst)
结果:nil
还有vl-some  这些用法大佬来贴码咯
;搬运的函数
;(uniquefuzz lst 1 )->((1 2 3 4 5 6) (2 2 3 4 5 6))
(defun uniquefuzz ( lst fuzz / a ll )
    (while (setq a (car lst))
      (if
        (vl-some
            (equal x a fuzz)
          (cdr lst)
          (setq ll (cons a ll))
          (setq lst
            (vl-remove-if
                (equal x a fuzz)
              (cdr lst)
          (setq lst (cdr lst))
    (reverse ll)
; Snaps a number to the closest ones in the list (if the num is equally between 2 vals, then it returns list of both values)
;将;http://www.lee-mac.com/uniqueduplicate.html
;; Unique-p  -  Lee Mac
;; Returns T if the supplied list contains distinct items.
;;如果提供的列表包含不同的项,则返回T。
(defun LM:Unique-p ( l )
    (vl-every (function (lambda ( x ) (not (member x (setq l (cdr l)))))) l)
_$ (LM:Unique-p '(1 2 3 4 5))
T
_$ (LM:Unique-p '(1 2 3 3 3 4 5))
nil
;; Unique with Fuzz  -  Lee Mac
;; Returns a list with all elements considered duplicate to
;;返回所有元素都被视为重复的列表
;; a given tolerance removed.
(defun LM:UniqueFuzz ( l f )
    (if l
        (cons (car l)
            (LM:UniqueFuzz
                (vl-remove-if
                    (function (lambda ( x ) (equal x (car l) f)))
                    (cdr l)
                f
(defun LM:UniqueFuzz ( l f / x r )
    (while l
        (setq x (car l)
              l (vl-remove-if (function (lambda ( y ) (equal x y f))) (cdr l))
              r (cons x r)
    (reverse r)
_$ (LM:UniqueFuzz '(1.0 1.1 2.0 2.01 2.2) 0.01)
(1.0 1.1 2.0 2.2)
_$ (LM:UniqueFuzz '(1.0 1.1 2.0 2.01 2.2) 0.15)
(1.0 2.0 2.2)
;; Unique-p with Fuzz  -  Lee Mac
;; Returns T if a list contains items considered distinct to
(defun LM:UniqueFuzz-p ( l f )
    (or (null l)
        (and (not (vl-some (function (lambda ( x ) (equal x (car l) f))) (cdr l)))
             (LM:UniqueFuzz-p (cdr l) f)
    (vl-every
        (function
            (lambda ( x )
                (not
                    (vl-some
                        (function
                        (setq l (cdr l))
        l
_$ (LM:UniqueFuzz-p '(1.0 1.1 2.0 2.01 2.2) 0.01)
nil
_$ (LM:UniqueFuzz-p '(1.0 1.1 2.0 2.01 2.2) 0.001)
T一个数字捕捉到列表中最接近的数字(如果数字在2个vals之间相等,则返回两个值的列表)
; _$ (SnapNumber2 5 '(0 2 4 6)) -> (4 6)
; _$ (SnapNumber2 5.2 '(0 2 4 6)) -> 6
; _$ (SnapNumber2 45 '(0.0 90.0 180.0 270.0 360.0)) -> (0.0 90.0)
(defun SnapNumber2 ( n Ln / _Positions Ld rtn )
  (defun _Positions ( x lst / p ) ; MP ;;  find all the positions of x in lst ;;  (_Positions 1 '(0 0 1 0 0 1)) >> (2 5)
    (if (setq p (vl-position x lst))
      ( (lambda ( lst result )
        (while (setq p (vl-position x lst)) (setq result (cons (+ 1 p (car result)) result) lst (cdr (member x lst)) ) )
        (reverse result)
      (cdr (member x lst)) (list p)
  ); defun _Positions
  (cond
    ( (or (not (numberp n)) (not (vl-every 'numberp Ln))) (princ "\nInvalid inputs.") nil )
    ( (setq Ld (mapcar '(lambda (x) (abs (- n x))) Ln))
      (setq rtn (mapcar '(lambda (x) (nth x Ln)) (_Positions (apply 'min Ld) Ld)))
  ); cond
  (cond ( (not rtn) nil) ( (= 1 (length rtn)) (car rtn) ) (rtn) )
发表于 2024-5-6 10:29:00 | 显示全部楼层
vitalgg 发表于 2023-9-12 10:36
vl-every 等同于
(apply 'and (mapcar '测试函数 lst))
学到了
检查A1中任意一个值在B1什么位置(从0开始,示例返回值为2),如果没有A1返回nil
(defun C:TT()
(setq a1 '(A B C D E))
(setq b1 '( 1 2 A 2 3 4 5 5 5 5 6 7 8 9  ))
(vl-some '(lambda(x)(vl-position x b1)) a1)
列表对比包含关系
(setq a1 '(9 7 6 A))
(setq b1 '(A 1 2  2 3 4 5 5 5 5 6 7 8 9  ))
怎么判断  B1已经全部含有A1列表,含有返回T  不然返回nil
(vl-every '(lambda(x)(vl-position x b1)) a1)
发表于 2023-9-12 10:58:18 | 显示全部楼层
jun353835273 发表于 2023-9-12 10:43
你这个就是函数手册上的,和翻手册差不多。
手册的解释就是用精准的语言表述函数的功能。如果能理解这个表述了,还需要看例子吗?
看例子的目的也是为了帮助理解函数函数的用法。
发表于 2023-9-12 11:45:39 | 显示全部楼层
应该返回 nil
发表于 2023-9-12 10:14:50 | 显示全部楼层
6666666666666666666
 楼主| 发表于 2023-9-12 10:18:29 | 显示全部楼层
来来来 贴一个
发表于 2023-9-12 10:36:17 | 显示全部楼层
vl-every 等同于
vl-some 等同于
(apply 'or (mapcar '测试函数 lst))
学到了 检查A1中任意一个值在B1什么位置(从0开始,示例返回值为2),如果没有A1返回nil (defun C:TT() (setq a1 '(A B C D E)) (setq b1 '( 1 2 A 2 3 4 5 5 5 5 6 7 8 9 )) (vl-some '(lambda(x)   发表于 2024-5-6 10:27
赞  发表于 2023-9-18 13:53
 楼主| 发表于 2023-9-12 10:43:29 | 显示全部楼层
vl-every 等同于
发表于 2023-9-12 10:58:51 | 显示全部楼层
看看楼主发帖内容
发表于 2023-9-12 12:20:09 | 显示全部楼层
6666666666666666666
GMT+8, 2025-5-21 04:37 , Processed in 0.214498 second(s), 30 queries , Gzip On.
