- 积分
- 8110
- 明经币
- 个
- 注册时间
- 2014-3-23
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - ;;对于R14
- ;;所选行的总长度
- ;;LL将选定图层上所有对象的长度求和。
- ;;OLL将所选对象的长度求和。
- ;;两者都将输出打印到命令行,给出不同的长度
- ;;层以及总数。
- (defun C:LL (/)
- (setq cmdecho (getvar 'cmdecho))
- (setvar 'cmdecho 0)
- (LL:OUTPUT "X" "\n在图层上选择对象以总计...")
- (setvar 'cmdecho cmdecho)
- (princ)
- (defun C:OLL (/)
- (LL:OUTPUT "P" "\n选择对象来总计...")
- (princ)
- (defun LL:OUTPUT (LL:SSTYPE LL:PROMPT /
- LL:SS I LL:ENAME
- LL:ELIST LL:LAYER LL:LAYERLIST
- LL:TOTALLENGTH LL:LAYERLENGTH LL:ARCDELTA
- LL:OBJLENGTH LL:SST LL:SSX
- (setq LL:LAYERLIST NIL)
- (if (setq LL:SS
- (ssget
- '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,REGION,SPLINE"))
- (progn
- (repeat (setq I (sslength LL:SS))
- (setq LL:ELIST (entget (ssname LL:SS (setq I (1- I)))))
- (if (not (member (setq LL:LAYER (cdr (assoc 8 LL:ELIST)))
- LL:LAYERLIST
- (setq LL:LAYERLIST (append LL:LAYERLIST (list LL:LAYER)))
- (setq LL:TOTALLENGTH 0)
- (setq LL:SST 0)
- (foreach X LL:LAYERLIST
- (setq LL:LAYERLENGTH 0)
- (setq LL:SS
- (ssget
- LL:SSTYPE
- (list
- (cons 0 "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,REGION,SPLINE")
- (cons 8 X)
- (setq LL:ENAME (ssname LL:SS (setq I (1- I))))
- (setq LL:ELIST (entget LL:ENAME))
- (cond
- ((eq (cdr (assoc 0 LL:ELIST)) "ARC")
- (if
- (> (cdr (assoc 50 LL:ELIST)) (cdr (assoc 51 LL:ELIST)))
- (setq LL:ARCDELTA
- (+ (abs (- (cdr (assoc 50 LL:ELIST))
- (* 2.0 pi)
- (cdr (assoc 51 LL:ELIST))
- (setq LL:ARCDELTA
- (- (cdr (assoc 51 LL:ELIST))
- (setq LL:OBJLENGTH
- (* (cdr (assoc 40 LL:ELIST)) LL:ARCDELTA)
- ((eq (cdr (assoc 0 LL:ELIST)) "LINE")
- (distance (cdr (assoc 10 LL:ELIST))
- (cdr (assoc 11 LL:ELIST))
- ((wcmatch (cdr (assoc 0 LL:ELIST))
- "*POLYLINE,CIRCLE,ELLIPSE,REGION,SPLINE"
- (vl-cmdf "._area" "o" LL:ENAME)
- (setq LL:OBJLENGTH (getvar "perimeter"))
- (setq LL:LAYERLENGTH (+ LL:LAYERLENGTH LL:OBJLENGTH))
- (setq LL:SSX (rtos (sslength LL:SS) 2 1))
- (setq LL:PROMPT (strcat "【" X "】" "图层中的线总长度: "
- (rtos (/ LL:LAYERLENGTH 1e3) 2 3)
- "m"
- (prompt (strcat "\n" "【" X "】" "图层中线的数量为: "
- LL:SSX
- "个"
- "\n" LL:PROMPT
- (setq LL:SST (+ LL:SST (atof LL:SSX)))
- (prompt "\n\r yuyuyu")
- (setq LL:TOTALLENGTH (+ LL:TOTALLENGTH LL:LAYERLENGTH))
- (prompt "\n\r ikikik")
- (setq LL:PROMPT (strcat "所有的线总长度: "
- (rtos (/ LL:TOTALLENGTH 1e3) 2 3)
- "m"
- (prompt (strcat "\n所有线的数量为: "
- (rtos LL:SST 2 1)
- "个"
- "\n" LL:PROMPT
代码来之明经后修改是用来给低版本CAD,计算线段总长,按图层分类统计,现在oll命令有点问题,只能统计最后选中的一个图层的线段长度
