查看: 1394|回复: 3
Pycad ,使用定时器实现旋转圆
发表于 2023-7-21 20:08:02 | 显示全部楼层 |阅读模式
  1. from math import pi
  2. from time import time
  3. import System.Windows.Forms as Winforms
  4. def Polar(center: Point3d, angle: float, distance: float):
  5.     import math
  6.     v1 = Vector3d(distance, 0, 0)
  7.     v1 = v1.RotateBy(angle * math.pi / 180, Vector3d.ZAxis)  # 将角度转换为弧度
  8.     return center + v1
  9. def muti_polar (cir: Entity,center:Point3d,angle: float):
  10.     import math
  11.     matrix =Matrix3d.Rotation(angle=angle*180/math.pi,axis=Vector3d.ZAxis,center=center)
  12.     cir.TransformBy(matrix)
  13. @Command(lock= False)
  14. def ts01(doc:Document):
  15.     res = getpoint()
  16.     if not res.ok:
  17.         return
  18.     center = res.value
  19.     angle_list = [0, 120,240]
  20.     pts = [Polar(center,x,100) for x in angle_list]
  21.     cir_ids = []
  22.     color =1
  23.     with dbtrans(doc) as tr:
  24.         btr = tr.opencurrspace()
  25.         for x in pts :
  26.             cir:Entity =Circle()
  27.             cir.Center =x
  28.             cir.Radius =20
  29.             cir.ColorIndex =color
  30.             color +=1
  31.             tr.addentity(btr,cir)
  32.             tr.flush(cir)
  33.             cir_ids.append(cir.ObjectId)
  34.     T0 =time()
  35.     timer =Winforms.Timer()
  36.     def on_timer_tick(sender,event):
  37.         doc:Document =Application.DocumentManager.MdiActiveDocument
  38.         with doc.LockDocument():
  39.             with dbtrans (doc)as tr:
  40.                 try:
  41.                     T1 =time()
  42.                     if T1 -T0 >20:#5秒后结束定时器
  43.                         timer.Stop()
  44.                         timer.Dispose()
  45.                     for objid in cir_ids:
  46.                         cir = tr.getobject(objid,OpenMode.ForWrite)
  47.                         muti_polar(cir,center,10)
  48.                         tr.flush(cir)
  49.                 except Exception as ex:
  50.                     prinf (ex.Message)
  51.                     timer.Stop()
  52.                     timer.Dispose()
  53.     timer =Winforms.Timer()
  54.     timer.Interval =50
  55.     timer.Tick += System.EventHandler(on_timer_tick)
  56.     timer.Start()
复制代码
发表于 2023-7-24 14:16:39 | 显示全部楼层
枫哥搞个动图看看呀
GMT+8, 2025-5-1 07:42 , Processed in 0.156871 second(s), 22 queries , Gzip On.
