查看: 1556|回复: 2
VBA CAD判断多段线顶点顺序的顺时针、逆时针
发表于 2023-7-15 20:01:48 | 显示全部楼层 |阅读模式
刚做一个小工具,判断多段线的顶点顺序方向(顺时针、逆时针)有需要的可自取。
  1. Sub 查多段线方向()
  2. '检查aen多段线是否为顶点顺时针的顺序,假设是2维lw多段线
  3. Dim objPolyline As AcadLWPolyline
  4. Dim ps1 As Variant
  5. Dim p1 As Variant, p2 As Variant, p3 As Variant
  6. Dim vc1 As Variant, vc2 As Variant
  7. Dim i As Long, j As Long, k As Long
  8. Dim m1 As Integer, m2 As Double
  9. Dim bBegin As Boolean
  10.     '处理多段线顶点坐标为数组
  11.     'Set objPolyline = aEn
  12.     ThisDrawing.Utility.GetEntity objPolyline, p1, "选择一个剪切框多段线:"
  13.     ps1 = objPolyline.Coordinates
  14.     For i = 0 To UBound(ps1) - 4 Step 2
  15.         '遍历多段线的边,找到其中一条边的方向,
  16.         '如所有顶点(不含该边)均在边的左边则逆时针
  17.         '均在右边则顺时针,转换边端点为p1,p2数组
  18.         p1 = Array(ps1(i), ps1(i + 1))
  19.         p2 = Array(ps1(i + 2), ps1(i + 3))
  20.         bBegin = True
  21.         For j = 0 To UBound(ps1) Step 2
  22.             '遍历其余点是否在边的某一边(左或右)
  23.             '当出现左右均有顶点时,放弃此边作为判断依据
  24.             If Not (j >= i And j <= i + 3) Then
  25.                 p3 = Array(ps1(j), ps1(j + 1))
  26.                 vc1 = c_Vectorize2P(p2, p1)
  27.                 vc2 = c_Vectorize2P(p3, p1)
  28.                 m2 = c_CrossProduct(vc1, vc2)
  29.                 If bBegin Then
  30.                     m1 = Sgn(m2)
  31.                     bBegin = False
  32.                 ElseIf Not m1 = Sgn(m2) Then
  33.                     j = 0
  34.                     Exit For
  35.                 End If
  36.             End If
  37.         Next
  38.         If j <> 0 Then Exit For
  39.     Next
  40.     If (m1 = -1) Then
  41.         MsgBox "多段线顶点顺序为顺时针方向。"
  42.     Else
  43.         MsgBox "多段线顶点顺序为逆时针方向。"
  44.     End If
  45. End Sub
  46. Private Function c_CrossProduct(vec1 As Variant, vec2 As Variant) As Double
  47. '求向量的差积
  48.     c_CrossProduct = vec1(0) * vec2(1) - vec1(1) * vec2(0)
  49. End Function
  50. Private Function c_Vectorize2P(p1 As Variant, p2 As Variant) As Variant
  51. '2点转化为P1->P2向量数组
  52.     c_Vectorize2P = Array(p1(0) - p2(0), p1(1) - p2(1))
  53. End Function
发表于 2023-7-15 23:17:54 | 显示全部楼层
明经有你更精彩
发表于 2023-7-16 23:02:47 | 显示全部楼层
给visualbasic点赞
GMT+8, 2025-5-1 00:52 , Processed in 0.160525 second(s), 22 queries , Gzip On.
