查看: 1193|回复: 3
重写 文本行距调整
发表于 2023-6-28 20:25:43 | 显示全部楼层 |阅读模式
起先发过一贴,发现使用中些问题,重写贴上,
一:增加首选调整间距相同后,再调整
二:增加中对齐,右对齐
http://bbs.mjtd.com/thread-188017-1-1.html
链接:https://pan.baidu.com/s/1DgiiVQD-lHsjmJZUY6mvAA
提取码:fuq6
  • ;文本间距调整c:m-text-ju
  • (defun c:tt (/ ss ss1 n e nam tp)
  •   (princ (slmsg "\n 请选取调整文字行距:" "\n 叫匡秸俱ゅ︽禯:" "\n Please select to adjust the text line spacing:"))
  •   (setq ss (ssget '((0 . "TEXT,TCH_TEXT,MTEXT,TCH_MTEXT"))) ss1 (ssadd))
  •   (repeat (setq n (sslength ss))
  •     (setq nam (ssname ss (setq n (1- n))) tp (dxf1 nam 0))
  •     (cond
  •       ((member tp '("MTEXT" "TCH_MTEXT"))
  •         (setq e (entlast))
  •         (expmtext nam)
  •         (setq ss1 (sl:pickset-join (last_ent e) ss1))
  •       (t
  •         (ssadd nam ss1)
  •   (ss-txt-ju ss1)
  • ;TEXT文字间距调整-----(一级)-------
  • ;ss TEXT选择集
  • (defun ss-txt-ju (ss / lst loop enam ang pt0 pt00 hi pt1 p0 p00 i ptlis p1 p11 p2 p22)
  •   (setq lst '())
  •   (repeat (setq i (sslength ss))
  •     (setq enam (ssname ss (setq i (1- i))))
  •     (entmod (emod (emod enam 72 0) 73 0)) ;先处理为左定位
  •     (setq lst (cons (list (dxf1 enam 10) enam) lst))
  •   (setq enam (cadr (nth 0 lst)) ptlis (ss9pt ss nil))
  •   (setq pt0 (dxf1 enam 10))
  •   (setq hi (dxf1 enam 40))
  •   (setq ang (dxf1 enam 50))
  •   (setq lst
  •     (vl-sort
  •       lst
  •       '(lambda (p1 p2)
  •          (if (or (equal ang pi2 0.01) (equal ang 3pi2 0.01))
  •            (cond
  •              ((< (caar p1) (caar p2)) T)
  •              ((and (= (caar p1) (caar p2)) (< (cadar p1) (cadar p2))) T)
  •            (cond
  •              ((> (cadar p1) (cadar p2)) T)
  •              ((and (= (cadar p1) (cadar p2)) (< (caar p1) (caar p2))) T)
  •   (setq pt00 (polar pt0 (- ang pi2) 300))
  •   (setq p1 (nth 8 ptlis)) ;右对齐
  •   (setq p11 (polar p1 (- ang pi2) 300))
  •   (setq p2 (cadr ptlis)) ;中对齐
  •   (setq p22 (polar p2 (- ang pi2) 300))
  •   (setq i 0 p00 (dxf1 (cadar lst) 10))
  •   (repeat (length lst);间距先调统一定值
  •     (setq enam (cadr (nth i lst)) pt1 (dxf1 enam 10))
  •     (setq p0 (polar p00 (- ang pi2) (* hi i 2.0)))
  •     (vla-move (en2obj enam) (vlax-3d-point pt1) (vlax-3d-point (pertolinecz pt1 p0 (polar p0 ang 300))))
  •     (setq i (1+ i))
  •   (setq loop T)
  •   (princ
  •     (slmsg
  •       "\n [行距+(1-or-左键)/行距-(2)/左对齐(Z)/右对齐(Y)/中对齐(M)][右键/回车/空格.退出]"
  •       "\n [︽禯+(1-or-オ龄)/︽禯-(2)/オ癸霍(Z)/癸霍(Y)/い癸霍(M)][龄/ó/.癶]"
  •       "\n [Line Dis+(1-or-left click)/Line Dis-(2)/Left alignment(Z)/Right alignment(Y)/Mid alignment(M)] [Right click/Enter/Space. Exit]"
  •   (while loop
  •     (setq bb (grread T 8))
  •     (cond
  •       ((or (= (car bb) 3) (equal bb '(2 49))) ;1键 左键
  •         (setq i 1)
  •         (repeat (- (length lst) 1)
  •           (setq pt1 (dxf1 (cadr (nth i lst)) 10))
  •           (setq p0 (polar pt1 (- ang pi2) (* hi i 0.05)))
  •           (entmod (emod (cadr (nth i lst)) 10 p0))
  •           (setq i (1+ i))
  •       ((equal bb '(2 50))  ;2
  •         (setq i 1)
  •           (setq p0 (polar pt1 (+ ang pi2) (* hi i 0.05)))
  •           (setq i (1+ i))
  •       ((member bb '((2 90) (2 122)))  ;;左对齐 Z z
  •         (setq i 0)
  •           (setq p0 (pertolinecz pt1 pt0 pt00))
  •           (setq i (1+ i))
  •       ((member bb '((2 89) (2 121)))  ;;右对齐 Y y
  •         (setq i 0)
  •           (setq pt1 (cadr (e-box4 (setq enam (cadr (nth i lst))) t)))
  •           (setq p0 (pertolinecz pt1 p1 p11))
  •           (vla-move (en2obj enam) (vlax-3d-point pt1) (vlax-3d-point p0))
  •           (setq i (1+ i))
  •       ((member bb '((2 77) (2 109)))  ;;中对齐 M m
  •         (setq i 0)
  •           (setq enam (cadr (nth i lst)) ptlis (e-box4 enam t))
  •           (setq pt1 (sl:mid (car ptlis) (cadr ptlis)))
  •           (setq p0 (pertolinecz pt1 p2 p22))
  •           (setq i (1+ i))
  •       ((or
  •          (member (car bb) '(11 25)) ;右键
  •          (member bb '((2 32))) ;空格键
  •          (member bb '((2 13))) ;;回车
  •         (setq loop nil)
  •   (princ)
参与人数 2明经币 +2 收起 理由
222808 + 1
cghdy + 1 赞一个!
发表于 2023-6-28 22:20:31 | 显示全部楼层
来坐沙发的...
发表于 2023-6-29 12:49:51 | 显示全部楼层
谢谢楼主分享
发表于 2023-6-30 11:35:35 | 显示全部楼层
缺少函数吗?
GMT+8, 2025-5-24 09:58 , Processed in 0.185888 second(s), 23 queries , Gzip On.
