查看: 1252|回复: 1
连续拾取点(提示点序号) 已解决
发表于 2023-6-28 08:44:50 | 显示全部楼层 |阅读模式
NativeMethods.SetFocus(Core.Application.DocumentManager.MdiActiveDocument.Window.Handle) 'CAD获得焦点
                            Dim pClt1 = New Point3dCollection()
                            Dim ppOpt = New PromptPointOptions("") With {
                                .AllowNone = True, '右键退出
                                .UseBasePoint = True,
                                .UseDashedLine = True,
                                .Message = vbLf & "右键退出 [指定第 " & js & " 点>]: "}
                            Dim ppRes As PromptPointResult = ed.GetPoint(vbLf & "指定开始点>")
                            While ppRes.Status = PromptStatus.OK
                                pClt1.Add(ppRes.Value)
                                ppOpt.BasePoint = ppRes.Value
                                ppRes = ed.GetPoint(ppOpt)
                                S &= js & " , " & js & " , " & ppRes.Value(1).ToString("0.000") & " , " & ppRes.Value(0).ToString("0.000") & " , " & ppRes.Value(2).ToString("0.000") & vbCrLf
                                js += 1
                            End While
怎样使得上面的 js 的值也跟随变
 楼主| 发表于 2023-6-28 08:53:02 | 显示全部楼层
                                js += 1
                            End While
GMT+8, 2025-5-1 08:05 , Processed in 0.201521 second(s), 22 queries , Gzip On.
