查看: 1391|回复: 2
画斜坡 毫米单位图不支持圆弧
发表于 2023-6-27 15:40:28 | 显示全部楼层 |阅读模式
  1. (defun  mkxp ( pta jd /  )
  2. (defun emkblk ( pt name / pt1 pt2 pt3 )
  3.   (entmake (list '(0 . "block") (cons 2 name) '(70 . 0) (cons 10 pt)))
  4. (setq pt1(polar pt (* 1.5 pi )  750 ))  (setq pt2 (polar pt 0  750 )) (setq pt3 (polar pt2 (* 1.5 pi )  1500 ))
  5.   (entmake (list '(0 . "LINE") (cons 10 pt) (cons 11 pt1)))
  6.   (entmake (list '(0 . "LINE") (cons 10 pt2) (cons 11 pt3)))
  7.   (entmake '((0 . "ENDBLK")))
  8.
  9.   ;(entmake (list '(0 . "INSERT") (cons 2 name) (cons 10 pt)))
  10. )
  11. (emkblk '(0 0) "GCpzx")
  12.   (entmake (list '(0 . "INSERT") (cons 2 "GCpzx") (cons 10 pta)  (cons 50 jd)  ))
  13. )
  14. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  15. (defun vxs (e / i v lst ppp)
  16.   (setq i 0)
  17.   (while
  18.     (setq v (vlax-curve-getpointatparam e (setq i (1+ i))))
  19.      (setq lst (cons v lst))
  20.   )
  21.   (setq ppp (reverse lst) )
  22. (append (list(vlax-curve-getpointatparam e 0)) ppp )
  23.
  24.   )
  25. ;;;;;;;;;;;;;;;;;;;;;
  26. (defun c:hxp1000 ( /  p1 plst zbb juli jiaodu i )
  27. (vl-load-com)
  28. (setq plst (vxs(car(entsel "\n 请选择坡顶线:"))) )
  29. (setq p1 nil)
  30. (setq zbb (mapcar'list plst (cdr plst)) )
  31. (foreach x zbb
  32.      (setq juli (distance (car x) (cadr x)))
  33.      (setq jiaodu (angle (car x) (cadr x) ))
  34.     (mkxp  (car x) jiaodu )
  35. (setq i 0)
  36.   (repeat   (fix ( / juli 1500) )
  37.    (mkxp (polar (car x) jiaodu (* 1500 (1+ i) ))  jiaodu )
  38. (setq i (1+ i))
  39.     )
  40.
  41.   )
  42. (princ)
  43. )
USER2128 + 1 赞一个!
发表于 2024-5-30 18:52:32 | 显示全部楼层
收藏啦,感谢分享!
发表于 2024-6-13 16:44:41 | 显示全部楼层
还有缺陷(附图),另外每个线段都是单独的个体,不方便删除;
GMT+8, 2025-5-1 03:01 , Processed in 0.172007 second(s), 25 queries , Gzip On.
