查看: 1318|回复: 3
求助大神 把万新改成JR
发表于 2023-6-24 15:39:26 | 显示全部楼层 |阅读模式
(defun c:zdbh (/ oce1 qz n1 zn h1 sxh1 p1) ;自动编号
  (setq oce1 (getvar "cmdecho"))
  (setvar "cmdecho" 0)
                                        ;(command "-style" "BG_ST" "宋体" 0 0.8 0 "n" "n")
  (c:zt)
  (c:zg)
                                        ;(setq qz (getstring "\n请输入前缀相同的部分: "))
                                        ;(if (not (setq n1 (getint "\n请输入起始顺序号 <1>: ")))
  (setq n1 1)
  (setq qz "")
                                        ;(if (not (setq zn (getint "\n请输入增加或减少的序数 <+1>: ")))
  (setq zn 1)
                                        ;(if (not (setq h1 (getreal "\n请指定文字高度 <2.5>: ")))
                                        ;(setq h1 2.5)
  (setq h1 zigao)
  (setq
    sxh1 (strcat qz (itoa n1))
    p1         (getpoint "\n请指定点: ")
  (while (/= p1 nil)
    (command "text" "m" p1 h1 0 sxh1)
    (setq
      n1   (+ n1 zn)
      p1   (getpoint "\n请指定下一点: ")
  (setvar "cmdecho" oce1)
发表于 2023-6-24 17:47:29 | 显示全部楼层
  1. (defun c:zdbh (/ oce1 qz n1 zn h1 sxh1 p1) ;自动编号
  2.         (setq oce1 (getvar "cmdecho"))
  3.   (setvar "cmdecho" 0)
  4.         ;(command "-style" "BG_ST" "宋体" 0 0.8 0 "n" "n")
  5.   (c:zt)
  6.   (c:zg)
  7.         ;(setq qz (getstring "\n请输入前缀相同的部分: "))
  8.         ;(if (not (setq n1 (getint "\n请输入起始顺序号 <1>: ")))
  9.   (setq n1 1)
  10.   (setq qz "万新")
  11.         ;)
  12.         ;(if (not (setq zn (getint "\n请输入增加或减少的序数 <+1>: ")))
  13.   (setq zn 1)
  14.         ;)
  15.         ;(if (not (setq h1 (getreal "\n请指定文字高度 <2.5>: ")))
  16.         ;(setq h1 2.5)
  17.         ;)
  18.   (setq h1 zigao)
  19.   (setq
  20.     sxh1 (strcat qz (itoa n1))
  21.     p1         (getpoint "\n请指定点: ")
  22.   )
  23.   (while (/= p1 nil)
  24.     (command "text" "m" p1 h1 0 sxh1)
  25.     (setq
  26.       n1   (+ n1 zn)
  27.       sxh1 (strcat qz (itoa n1))
  28.       p1   (getpoint "\n请指定下一点: ")
  29.     )
  30.   )
  31.   (setvar "cmdecho" oce1)
  32.   (princ)
  33. )
发表于 2023-6-24 22:37:40 | 显示全部楼层
  1. (defun c:tt (/ oce1 qz n1 zn h1 sxh1 p1) ;自动编号
  4.   (setq n1 1)
  5.   (setq qz "JR")
  6.   (setq zn 1)
  7.   (setq h1 2.5)
  8.   (setq
  9.     sxh1 (strcat qz (itoa n1))
  10.     p1         (getpoint "\n请指定点: ")
  11.   )
  12.   (while (/= p1 nil)
  13.     (command "text" "j" "mc" p1 h1 0 sxh1)
  14.     (setq
  15.       n1   (+ n1 zn)
  16.       sxh1 (strcat qz (itoa n1))
  17.       p1   (getpoint "\n请指定下一点: ")
  18.     )
  19.   )
  20.   (setvar "cmdecho" oce1)
  21.   (princ)
  22. )
 楼主| 发表于 2023-6-25 08:18:32 | 显示全部楼层
大神,是不是把代码里的万新改成JR就可以了
GMT+8, 2025-5-1 17:35 , Processed in 0.174581 second(s), 24 queries , Gzip On.
