查看: 1531|回复: 4
关于文本行距调整
发表于 2023-6-13 22:28:07 | 显示全部楼层 |阅读模式
http://bbs.mjtd.com/forum.php?mo ... hlight=%BC%E4%BE%E0
鉴于有人要这个功能,哪么本坛也有涉及,然而...
既然调整,要支持MTEXT,并且任意角度的文本都应该支持,为此,组织写下代码,
我自己写的代码也不喜欢写自己痕迹,涉及其他人的,没有注明,不接收辩驳
已集成《三领设计 V3.0》之内,关于这个问题,完善提高还是必要,空间还是很大...
链接:https://pan.baidu.com/s/1DgiiVQD-lHsjmJZUY6mvAA
提取码:fuq6
  • ;文本间距调整
  • (defun c:m-text-ju (/ ss ss1 n e nam tp)
  •   (princ (slmsg "\n 请选取调整文字行距:" "\n 叫匡秸俱ゅ︽禯:" "\n Please select to adjust the text line spacing:"))
  •   (setq ss (ssget '((0 . "TEXT,TCH_TEXT,MTEXT,TCH_MTEXT"))) ss1 (ssadd))
  •   (repeat (setq n (sslength ss))
  •     (setq nam (ssname ss (setq n (1- n))) tp (dxf1 nam 0))
  •     (cond
  •       ((member tp '("MTEXT" "TCH_MTEXT"))
  •         (setq e (entlast))
  •         (expmtext nam)
  •         (setq ss1 (sl:pickset-join (last_ent e) ss1))
  •       (t
  •         (ssadd nam ss1)
  •   (ss-txt-ju ss1)
  • ;TEXT文字间距调整-----(一级)-------
  • ;ss TEXT选择集
  • (defun ss-txt-ju (ss / lst loop enam ang pt0 pt00 hi pt1 pt1-1 n i)
  •   (setq lst '())
  •     (setq enam (ssname ss (setq n (1- n))))
  •     (entmod (emod (emod enam 72 0) 73 0)) ;先处理为左定位
  •     (setq lst (cons (list (dxf1 enam 10) enam) lst))
  •   (setq enam (cadr (nth 0 lst)))
  •   (setq pt0 (dxf1 enam 10))
  •   (setq hi (dxf1 enam 40))
  •   (setq ang (dxf1 enam 50))
  •   (setq pt00 (polar pt0 (- ang pi2) 300))
  •   (setq lst
  •     (vl-sort
  •       lst
  •       '(lambda (p1 p2)
  •          (if (or (equal ang pi2 0.01) (equal ang 3pi2 0.01))
  •            (cond
  •              ((< (caar p1) (caar p2)) T)
  •              ((and (= (caar p1) (caar p2)) (< (cadar p1) (cadar p2))) T)
  •            (cond
  •              ((> (cadar p1) (cadar p2)) T)
  •              ((and (= (cadar p1) (cadar p2)) (< (caar p1) (caar p2))) T)
  •   (setq loop T)
  •   (princ
  •     (slmsg
  •       "\n [行距+(1左键)/行距-(2)/左对齐(3)][右键/回车/空格.退出]"
  •       "\n [︽禯+(1オ龄)/︽禯-(2)/オ癸霍(3)][龄/ó/.癶]"
  •       "\n [Line spacing+(1 left click)/Line spacing - (2)/Left justified (3)] [Right click/Enter/Space. Exit]"
  •   (while loop
  •     (setq bb (grread T 8))
  •     (cond
  •       ((or (= (car bb) 3) (equal bb '(2 49))) ;1键 左键
  •         (setq i 1)
  •         (repeat (- (length lst) 1)
  •           (setq pt1 (dxf1 (cadr (nth i lst)) 10))
  •           (setq pt1-1 (polar pt1 (- ang pi2) (* hi i 0.05)))
  •           (vla-put-insertionpoint (en2obj (cadr (nth i lst))) (vlax-3d-point pt1-1))
  •           (setq i (1+ i))
  •       ((equal bb '(2 50))  ;2
  •         (setq i 1)
  •           (setq pt1-1 (polar pt1 (+ ang pi2) (* hi i 0.05)))
  •           (setq i (1+ i))
  •       ((equal bb '(2 51)) ;左对齐
  •         (setq i 1)
  •           (setq pt1-1 (pertolinecz pt1 pt0 pt00))
  •           (setq i (1+ i))
  •       ((or
  •          (member (car bb) '(11 25)) ;右键
  •          (member bb '((2 32))) ;空格键
  •          (member bb '((2 13))) ;;回车
  •         (setq loop nil)
  •   (princ)
1028695446 + 1 很给力!
发表于 2023-6-14 08:01:36 | 显示全部楼层
这个用途非常实用,感谢分享!
发表于 2023-6-14 09:31:06 | 显示全部楼层
很有用途的,谢谢分享
发表于 2023-6-14 10:23:38 | 显示全部楼层
缺少子函数
发表于 2023-6-16 18:12:23 | 显示全部楼层
能否将多行文字的字高快速调整到一个特定值,比如现在字高50  调到60 ?
GMT+8, 2025-5-24 10:06 , Processed in 0.179937 second(s), 24 queries , Gzip On.
