查看: 2893|回复: 6
返回二次三次拟合线控制点坐标
发表于 2023-6-12 22:14:59 | 显示全部楼层 |阅读模式
返回二次三次拟合线控制点坐标
  1. (defun vxs ( ent / PLTYPE obj vtx vtxlst n ptlst)  ;提取多段线顶点坐标
  2.     (vl-load-com)
  3.    ; (setq ent (entsel "\n选取多线:\n"))
  4.     (if ent
  5.         (progn
  6.           (setq PLTYPE (cdr (assoc 0 (entget (car ent)))))
  7.           (if (or (= "POLYLINE" PLTYPE) (= "LWPOLYLINE" PLTYPE))
  8.               (progn
  9.                  (setq obj (vlax-ename->vla-object (car ent)))
  10.                  (setq vtx (vla-get-Coordinates obj))
  11.                  (setq vtxlst (vlax-safearray->list (vlax-variant-value vtx)))
  12.                  (setq n 0)
  13.                  (setq ptlst nil)
  14.                  (repeat (/ (length vtxlst) 3)
  15.                          (setq ptlst (append ptlst (list (list (nth n vtxlst) (nth (1+ n) vtxlst)(nth (+ n 2) vtxlst)   ))))
  16.                          (setq n (+ n 3))
  17.                  )
  18.                  (if ptlst ptlst nil)
  19.              )
  20.              (prompt "\n选取实体不是多义线!")
  21.           );if
  22.        )
  23.      )
  24.    ;if
  25.    ptlst
  26.   );;;;;;;-------------------
  27. (setq e (entsel "\n选择多段线:"))
  28. (entmake (append    (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length (vxs e  ))))
  29.       (mapcar '(lambda (pt)(cons 10 pt)) (vxs e  ) ))
  30.   )
  31. ;;;(vlax-safearray->list (vlax-variant-value (vla-get-Coordinates (vlax-ename->vla-object (car (entsel))))))
USER2128 + 1 赞一个!
 楼主| 发表于 2023-6-22 19:34:05 | 显示全部楼层
  1. 命令: (VL-LOAD-COM)
  2. 命令: (vlax-safearray->list (vlax-variant-value (vlax-get-property
  3. (vlax-ename->vla-object  (car(entsel)) ) 'Coordinates) ))
  4. 选择对象: (1258.43 660.372 0.0 1719.35 558.429 0.0 2087.03 1041.78 0.0)
 楼主| 发表于 2023-6-22 19:35:44 | 显示全部楼层
  1. (setq en1 (car(entsel "\n please select lwpoliline")) )
  2. (setq en (entget en1 '("*") ))
  3. (setq  en (vl-remove-if '(LAMBDA (x) (= (car x) 10))  en ))
  4. (setq en (subst '(0 . "POLYLINE") '(0 . "LWPOLYLINE") en))
  5. (setq en (subst '(100 . "AcDb2dPolyline") '(100 . "AcDbPolyline") en))
  6. (setq en (append en (list '(66 . 1))))  (setq en (append en (list '(10 0.0 0.0 0.0))))
  7. (setq en (append en (list '(71 . 0))))
  8. (setq en (append en (list '(72 . 0))))
  9. (setq en (append en (list '(73 . 0))))
  10. (setq en (append en (list '(74 . 0))))
  11. (setq en (append en (list '(75 . 0))))
  12. (entmod en )
  13. (vlax-ename->vla-object  (car(entsel)) )
  14. (entget(car(entsel))'("*"))
发表于 2023-12-10 12:29:41 | 显示全部楼层
不错的帖子 顶一下
发表于 2024-2-2 17:30:51 | 显示全部楼层
标记 备用 会用到
 楼主| 发表于 2024-2-22 22:58:23 | 显示全部楼层
  1. (vl-load-com)
  2. ;(vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object  (car(entsel)) ) 'Coordinates) ))
  3. (defun vxs (e /   )
  4. (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object  e ) 'Coordinates) ))
  5. ;;;;;;;;;;;;;;;
  6. )
  7.   (defun c:tt11 ( / lst ent pts pt demj zmj ffn ff i) ;生成CASS三角网文件SJW
  8.   (setq lst (ssget '( (0 . "*polyline,3dface") (8 . "SW-自然地表模型")) ) )
  9. (setq i 0)
  10. (setq ffn (getfiled "选取/建立数据导出文件" "" "sjw" 1))
  11.   (setq ff (open ffn "w"))
  12.
  13. (while  (< i (sslength lst))
  14. (setq ent (ssname lst i))
  15. (setq pts (vxs ent)); 3DFACE本来应该去除第四点,但本程序未去除
  16.   (foreach x pts
  17. (princ  (strcat (rtos x 2 3) "\n" ) ff)
  18.     )
  19.
  20. (setq i (+ i 1))
  21.   )
  22. (close ff)
  23.   (princ)
  24.     )
发表于 2024-9-22 11:06:19 | 显示全部楼层
朴大侠的“二次三次拟合线控制点坐标”经过优化→辛苦把优化后的文件文件发上来好吧?
GMT+8, 2025-5-1 02:55 , Processed in 0.180792 second(s), 25 queries , Gzip On.
