查看: 1337|回复: 0
根据大于3点的三维多段线首尾高程分配给中间个点
发表于 2023-6-8 18:41:15 | 显示全部楼层 |阅读模式
  1. ;; 测量选定曲线上两点之间的距离
  2. (defun apkl (ENOBJ p1 p2 / DIST DIST1 DIST2 EN ENOBJ OSM P1 P2)
  3. ;;;来源:QQ群友:GreenWood(181976640)。属QQ群:SP编程,e派<a href="http://bbs.mjtd.com/forum-6-1.html" target="_blank" class="relatedlink">工具</a>箱,摄影  24942984
  4.
  5.
  6. ;(setq ENOBJ (CAR (ENTSEL)))
  7. ;(setq p1 (getpoint "\n选择曲线上的一点:"))
  8. ;(setq p2 (getpoint "\n选择曲线上的另一点:"))
  9. (setq dist1 (vlax-curve-getDistAtPoint enobj p1))
  10. (setq dist2 (vlax-curve-getDistAtPoint enobj p2))
  11. ;(print "\n测量段曲线长度:")
  12. (setq dist (abs (- dist1 dist2)))
  13. dist
  14. )
  15. (defun vxs (e / i v lst ppp)
  16.   (setq i 0)
  17.   (while
  18.     (setq v (vlax-curve-getpointatparam e (setq i (1+ i))))
  19.      (setq lst (cons v lst))
  20.   )
  21.   (setq ppp (reverse lst) )
  22. (append (list(vlax-curve-getpointatparam e 0)) ppp )
  23.
  24.   )
  25. ;;;;;;;;
  26. (defun  ddx ( Polyline  p1  gccc / x xdb xh coord temp0 temp1  PolylineObj aaa n)
  27.
  28. (setq PolylineObj (vlax-ename->vla-object Polyline ) )
  29.   (setq aaa (vxs Polyline) )     (setq n (length aaa))
  30.   (setq xdb (apply 'append (mapcar'(lambda(x)(setq aaa(cdr aaa))   (list(cons (- n (length aaa)) x))  )aaa))  )
  31. (foreach x  xdb
  32.
  33.       (if    (< (distance (list (nth 1 x) (nth 2 x) ) (list (car p1) (cadr p1)) )  0.0500)
  34. (setq xh (-(car x) 1))
  35.   ;(setq xh nil )
  36.   )
  37.
  38. );;;;;;
  39. ;; 找出第一个索引位置的坐标
  40.   (setq coord(vla-get-Coordinate PolylineObj  xh))
  41. ;;; 改变坐标
  42.   ;(setq temp(+ (vlax-safearray-get-element (vlax-variant-value coord) 0) 1))
  43. (setq temp0 (car p1)
  44.       temp1  (cadr p1)
  45.
  46.      )
  47.   (setq coord(vlax-variant-value coord))
  48.   (vlax-safearray-put-element coord 0 temp0)
  49. (vlax-safearray-put-element coord 1 temp1)
  50. (vlax-safearray-put-element coord 2 gccc)
  51.   (vla-put-Coordinate PolylineObj xh coord)
  52.   (vla-Update PolylineObj)
  53.
  54. ;;;;;;;
  55.   )
  56.
  57. ;;;;;;;
  58. (defun c:bg (  / ENOBJ p1 p2 s1 s2 p3  dist gcc bz dist1 xgc y)
  59. (setq ENOBJ (CAR (ENTSEL "\n请选择线段")))
  60. (setq p1 (getpoint "\n选择曲线上的一点:"))
  61.   (setq s1 (getreal "\n请输入该点标高:"))
  62. (setq p2 (getpoint "\n选择曲线上的另一点:"))
  63. (setq s2 (getreal "\n请输入该点标高:"))
  64.   (setq dist (apkl ENOBJ p1 p2 ))
  65. (setq gcc (- s1 s2))
  66.   (setq bz (/ gcc dist))
  67.   (foreach  y   (vl-remove  (last (cdr(vxs ENOBJ) ))  (cdr(vxs ENOBJ) ) )
  68.
  69.         (setq dist1 (apkl ENOBJ y p2 ) )
  70. (setq xgc (+ s2 (* dist1 bz )))
  71.    (ddx ENOBJ  y  xgc )
  72. (entmake (list '(0 . "TEXT") '(8 . "fgbj")(cons 1 (rtos xgc 2 3)) (cons 10 y ) (cons 40 1.0)))
  73.     )
  74.
  75. (ddx ENOBJ  p1  s1 )
  76.   (entmake (list '(0 . "TEXT") '(8 . "fgbj")(cons 1 (rtos s1 2 3)) (cons 10 p1 ) (cons 40 1.0)))
  77.   (ddx ENOBJ  p2  s2 )
  78.   (entmake (list '(0 . "TEXT") '(8 . "fgbj")(cons 1 (rtos s2 2 3)) (cons 10 p2 ) (cons 40 1.0)))
  79. (princ)
  80.       )
GMT+8, 2026-1-8 06:40 , Processed in 0.148264 second(s), 23 queries , Gzip On.
