查看: 762|回复: 0
等高线计算土方,必须封闭
发表于 2023-6-4 20:44:15 | 显示全部楼层 |阅读模式
等高线计算土方,必须封闭
  1. ( defun c:dgxtf (  / lst lst1 dgj pt pzx pzx1 mj mj1 tj   )
  2. (vl-load-com)
  3. (alert "本图按照毫米为单位计算等高线土方")
  4. (setq dgj (getreal "\n请输入等高距毫米:"))
  5. (prompt "\n请选择低的一组等高线")
  6. (setq lst (ssget '((0 . "LWPOLYLINE,SPLINE")    )   )  )
  7. (prompt "\n请选择高的一组等高线")
  8. (setq lst1 (ssget '((0 . "LWPOLYLINE,SPLINE")    )   )  )
  9. (setq pt(getpoint "\n请点击体积标注位置:"))
  10. ;选择集与对象名表互转
  11. (defun cx-ss2en
  12.   (ss / enlst)
  13.   (cond
  14.     ((= (type ss) 'PICKSET)
  15.       (vl-remove-if-not '(lambda (x) (= (type x) 'ENAME)) (mapcar 'cadr (ssnamex SS)))
  16.     )
  17.     ((= (type ss) 'LIST)
  18.       (setq enlst (ssadd))
  19.       (last (mapcar '(lambda (x) (ssadd x enlst)) ss))
  20.     )
  21.     ((='ename(type ss))
  22.       (ssadd ss)
  23.     )
  24.   )
  25. )
  26. ;(entget(car(entsel))'("*"))
  27. (setq pzx 0)
  28. (foreach x (cx-ss2en lst)
  29.       (setq mj (vlax-curve-getArea (vlax-ename->vla-object x)) ) ;;;;
  30.     (setq pzx (+ mj pzx))
  31.   (vla-put-color (vlax-ename->vla-object x) 20)
  32.   )
  33. (setq pzx1 0)
  34. (foreach y (cx-ss2en lst1)
  35.       (setq mj1 (vlax-curve-getArea (vlax-ename->vla-object y)) ) ;;;;
  36.     (setq pzx1 (+ mj1 pzx1))
  37.   (vla-put-color (vlax-ename->vla-object y) 223)
  38.   )
  39. (setq tj (/(*  (/ (+(expt (* pzx pzx1) 0.5) pzx pzx1 ) 3.0000)      dgj) 1000000000.0000) )
  40.   ; 6、单行文本
  41. (entmake (list '(0 . "TEXT") (cons 1 (rtos tj 2 3)) (cons 10 pt)(cons 62 3) (cons 40 1000)))
  42. (princ)
  43. )
  44. ;;;;;;;;;;;;;;;;;;;;;;;
  45. ( defun c:dgxtf1 (  / lst lst1 dgj pt pzx pzx1 mj mj1 tj  i )
  46. (vl-load-com)
  47. (alert "本图按照毫米为单位计算等高线土方")
  48. (setq dgj (getreal "\n请输入等高距毫米:"))
  49. (prompt "\n请选择一组等高线")
  50. (setq lst (ssget '((0 . "LWPOLYLINE,SPLINE")    )   )  )
  51. (setq pt(getpoint "\n请点击体积标注位置:"))
  52. (setq pzx '())
  53.   (foreach x (cx-ss2en lst)
  54.     (setq mj (vlax-curve-getArea (vlax-ename->vla-object x)) ) ;;;;
  55.     (setq pzx (append (list mj) pzx))
  56.
  57.     (vla-put-color (vlax-ename->vla-object x) 20)
  58.      ) (setq pzx (vl-sort pzx '>) )
  59.   (setq i 0)
  60.   (setq pzx1 0)
  61. (repeat   (-(length pzx) 1)
  62.     (setq tj (/(*  (/ (+(expt (* (nth i pzx)  (nth (+ i 1) pzx) ) 0.5) (nth i pzx) (nth (+ i 1) pzx)  ) 3.0000) dgj) 1000000000.0000) )
  63.      (setq pzx1 (+ tj pzx1))
  64. (setq i (1+ i))
  65.   )
  66.   (entmake (list '(0 . "TEXT") '(8 . "zxtj")(cons 1 (rtos pzx1 2 3)) (cons 10 pt)(cons 62 3) (cons 40 1000)))
  67. (princ )
  68.   )
GMT+8, 2025-5-1 04:29 , Processed in 0.134604 second(s), 24 queries , Gzip On.
