查看: 2244|回复: 5
Pycad 四叉树配合A*算法寻路
发表于 2023-6-3 18:20:34 | 显示全部楼层 |阅读模式
from Autodesk.AutoCAD.Runtime import *
from Autodesk.AutoCAD.ApplicationServices import *
from Autodesk.AutoCAD.EditorInput import *
from Autodesk.AutoCAD.DatabaseServices import *
from Autodesk.AutoCAD.Geometry import *
from System.Linq import Enumerable
from pycad.runtime import *
from pycad.system import *
from pycad.runtime.edx import *
from math import *
import re as re
from collections import defaultdict
from heapq import *
from Queue import PriorityQueue
from math import *
clr.ImportExtensions(System.Linq)
def ColsestPointByPt(pt,pts):
    return pts.OrderBy(lambda x: x.DistanceTo(pt)).First()
def round_point(pt):
        return Point3d(round(pt.X,5),round(pt.Y,5),0)
def LoopallChildren(parent):
    for child in parent.children:
        if child.children:
            for subchild in LoopallChildren(child):
                yield subchild
        yield child
#创建路径点对类
class Path:
    def __init__(self,pt1,pt2):
        self._pt1=pt1
        self._pt2=pt2
    @property
    def Length(self):
        return abs(self._pt1[0]-self._pt2[0])+abs(self._pt1[1]-self._pt2[1])
#创建四叉树节点
class QuadNode:
    def __init__(self, line):
        self._pt1 = line.StartPoint
        self._pt2 = line.EndPoint
        self._pair_tuple = (self._pt1, self._pt2)
        self._pair_set = {self._pt1, self._pt2}
        self.line = line
        self.bounds = self.line.GeometricExtents
        self.route_nodes = {round_point(self.line.StartPoint), round_point(self.line.EndPoint)}
    def __eq__(self, other):
        return self.bounds==other.bounds and self.line==other.line
    def __hash__(self):
        return hash(tuple(self._pair_set))
    def __contains__(self, pt):
        return pt in self._pair_set
    @property
    def paths(self):
        paths = set()
        pts = self.route_nodes
        pts = list(pts.OrderBy(lambda pt: pt.X).ThenBy(lambda pt: pt.Y))
        for i in range(len(pts) - 1):
            paths.add(Path(pts, pts[i + 1]))
        return paths
#创建四叉树
class QuadTree(object):
    def __init__(self,bounds,max_items, max_depth, depth=0):
        self.nodes = set()
        self.children = []
        self.bounds=bounds
        self.MaxPoint=bounds.MaxPoint
        self.MinPoint=bounds.MinPoint
        self.Center =self.MinPoint+(self.MaxPoint-self.MinPoint)/2
        self.max_items = max_items
        self.max_depth = max_depth
        self.depth = depth
    def GetLastTree(self):
        if self.children==[] and self.nodes != set():
            n +=1
            treeset.add(self.bounds)
        else:
            for child in self.children:
                child.GetLastTree()
        print(n)
        return treeset
    def get_generator(self):
        for child in LoopallChildren(self):
            yield child
    def insert(self, node):
        if len(self.children) == 0:
            self.nodes.add(node)
            if len(self.nodes) > self.max_items and self.depth < self.max_depth:
                self.Split()
        else:
            self.insert_into_children(node)
    def remove(self, ent):
            node = QuadNode(ent)
            self.nodes.remove(node)
        else:
            self.remove_from_children(node)
    def intersect(self, bounds=Extents3d, results=None, uniq=None):
        if results is None:
            results = set()
            uniq = set()
        if self.children:
            if MinPoint[0] <= self.Center[0]:
                if MinPoint[1] <= self.Center[1]:
                    self.children[0].intersect(bounds, results, uniq)
                if MaxPoint[1] >= self.Center[1]:
                    self.children[1].intersect(bounds, results, uniq)
            if MaxPoint[0] >= self.Center[0]:
                    self.children[2].intersect(bounds, results, uniq)
                    self.children[3].intersect(bounds, results, uniq)
        for node in self.nodes:
            NodeId = id(node)
            if (not (NodeId in uniq) and
                node.bounds.MaxPoint[0] >= MinPoint[0] and node.bounds.MinPoint[0] <= MaxPoint[0] and
                node.bounds.MaxPoint[1] >= MinPoint[1] and node.bounds.MinPoint[1] <= MaxPoint[1]):
                results.add(node)
                uniq.add(NodeId)
        return results
    def intersectwith(self, node):
        bounds=node.bounds
        bounds.ExpandBy(Vector3d(0.01,0.01,0))
        bounds.ExpandBy(Vector3d(-0.01,-0.01,0))
        results=self.intersect(bounds)
        for x in results:
            pts=QTIntersectWith(node.line,x.line)
            if pts != None:
                for x in pts:
                    node.route_nodes.add(round_point(x))
    def insert_into_children(self, node):
        bounds= node.bounds
        if (MinPoint[0]<= self.Center[0] and MaxPoint[0] >= self.Center[0] and
            MinPoint[1] <= self.Center[1] and MaxPoint[1] >= self.Center[1]):
        else:
            if MinPoint[0]<= self.Center[0]:
                    self.children[0].insert(node)
                    self.children[1].insert(node)
            if MaxPoint[0] > self.Center[0]:
                    self.children[2].insert(node)
                    self.children[3].insert(node)
    def remove_from_children(self, node):
        bounds=node.bounds
        if (MinPoint[0] <= self.Center[0] and MaxPoint[0] >= self.Center[0] and
        else:
                    self.children[0].remove(node)
                    self.children[1].remove(node)
                    self.children[2].remove(node)
                    self.children[3].remove(node)
    def Split(self):
        new_depth = self.depth + 1
        self.children = [QuadTree(Extents3d(self.MinPoint,self.Center),#左下
                                   self.max_items, self.max_depth, new_depth),
                         QuadTree(Extents3d(Point3d(self.MinPoint[0],self.Center[1],0),Point3d(self.Center[0],self.MaxPoint[1],0)),#左上
                         QuadTree(Extents3d(Point3d(self.Center[0],self.MinPoint[1],0),Point3d(self.MaxPoint[0],self.Center[1],0)),#右下
                         QuadTree(Extents3d(self.Center,self.MaxPoint),#右上
                                   self.max_items, self.max_depth, new_depth)]
        nodes = self.nodes
        self.nodes = set()
        for node in nodes:
    def __len__(self):
        size = 0
            size += len(child)
        size += len(self.nodes)
        return size
#全局函数,四叉树求交点
def QTIntersectWith(line1,line2):
    points=Point3dCollection()
    if line1==None:
        return None
    else:
        line1.IntersectWith(line2,Intersect.OnBothOperands,Plane(), points, 0, 0)
        if points.Count==0:
            return None
        else:
            return set(points)
#创建地图类
class Graphs:
    def __init__(self, paths):
        self.graph = defaultdict(set)
        for path in paths:
            self.graph[path._pt1].add((path._pt2, path.Length))
            self.graph[path._pt2].add((path._pt1, path.Length))
    @staticmethod
    def get_distance(pt1, pt2):
        return abs(pt1[0] - pt2[0]) + abs(pt1[1] - pt2[1])
    @staticmethod
    def num_turns(prev, next, end):
        if prev is None:
            return 0
        elif (prev[0] - next[0]) * (next[1] - end[1]) == (prev[1] - next[1]) * (next[0] - end[0]):
            return 0
        else:
            return 1
    def a_star_search(self, start, end):
        frontier = []
        heappush(frontier, (0, start))
        came_from = {}
        cost_so_far = {}
        num_turns_so_far = {}
        came_from[start] = None
        cost_so_far[start] = 0
        num_turns_so_far[start] = 0
        distance = self.get_distance(start, end)
        while frontier:
            current = heappop(frontier)[1]
            if current == end:
                break
            for next, cost in self.graph[current]:
                new_cost = cost_so_far[current] + cost
                num_turns_to_next = num_turns_so_far[current] + self.num_turns(current, next, end)
                priority = (new_cost + num_turns_to_next) * (1 + 1 / distance)
                if next not in cost_so_far or priority < cost_so_far[next] / distance:
                    cost_so_far[next] = new_cost
                    num_turns_so_far[next] = num_turns_to_next
                    heappush(frontier, (priority, next))
                    came_from[next] = current
        path = [end]
        while path[-1] != start:
            path.append(came_from[path[-1]])
        return list(reversed(path))
#初步封装
def MakeGraph(lines):
    nodes = set(map(lambda x: QuadNode(x),lines))
    bounds =Extents3d()
    for node in nodes:
        bounds.AddExtents(node.bounds)
        qtree =QuadTree(bounds,40,10,0)
    for node in nodes:
        qtree.insert(node)
    paths =set()
    for node in nodes:
        qtree.intersectwith(node)
        paths |= node.paths
        graph= Graphs(paths)
    pts = set()
    for node in nodes:
        pts |= node.route_nodes
    return pts,graph
##################以下为主程序
pts=None
graph = None
@command()
def CreatGraph(doc):
    global pts,graph
    with dbtrans(doc) as tr:
        res= ssget_x((conv.And,(0,"line,*polyline*"),(8,r'CableTray-Center')))
        if not res.ok() : return
        ids =tuple(res)
        lines = map(lambda x: x.GetObject(OpenMode.ForWrite),ids)
        linesset =set()
        for line in lines:
            if isinstance(line, (Polyline,Polyline3d,Polyline2d)):
                EntitySet=DBObjectCollection()
                Entity.Explode(line,EntitySet)
                linesset |=set(EntitySet)
            else :linesset.add(line)
        pts,graph=MakeGraph(linesset)
@command()
def graph1(doc):
    global pts,graph
        btr=tr.opencurrspace()
        if pts==graph==None:
            res= ssget(":A",(conv.And,(0,"*line"),(8,r'CableTray-Center')))
            ids =tuple(res)
            linesset =set()
            for line in lines:
        start = round_point(edx.getpoint("请输入起点").value)
        start=ColsestPointByPt(start,pts)
        colorindex=256
        end = round_point(edx.getpoint("请输入终点").value)
        end=ColsestPointByPt(end,pts)
        try:
            path_reasult=graph.a_star_search(start, end)
            newpath=AddPolyLine(path_reasult,colorindex)
            newpath.Layer="E-PL"
            tr.addentity(btr,newpath)
        except KeyError:
            print("未找{0}到{1}的路径\n".format(str(start),str(end)))
参与人数 2明经币 +2 收起 理由
gzxl + 1 很给力!
闻人南131 + 1 很给力!
发表于 2023-6-3 18:28:45 | 显示全部楼层
厉害厉害厉害&#128077;&#127995;
发表于 2023-6-4 07:41:26 | 显示全部楼层
很好奇 速度是咋样的。
 楼主| 发表于 2023-6-4 20:10:33 | 显示全部楼层
gzxl 发表于 2023-6-4 07:41
很好奇 速度是咋样的。
速度还可以,如果图形十分复杂,还是建议用其他方法
发表于 2023-6-4 23:50:42 来自手机 | 显示全部楼层
我已经用lisp实现了迪杰斯特拉算法,几十万条路径计算速度很快
发表于 2023-6-8 16:04:56 | 显示全部楼层
兄弟狠人啊,啥时候发个动图瞧一瞧.
GMT+8, 2025-5-1 07:57 , Processed in 0.195964 second(s), 26 queries , Gzip On.
