查看: 1328|回复: 0
[软件与安装] 网页CAD开发引线标注的代码如何写?
发表于 2023-6-2 11:43:12 | 显示全部楼层 |阅读模式
以下是一个基本的WebCAD引线标注绘制代码的示例(使用了d3.jsSnap.svg库):
HTML
  1. <div id="canvas"></div>
复制代码
CSS
  1. #canvas {
  2.   width: 100%;
  3.   height: 100vh;
  4.   position: relative;
  5. }
  6. JavaScript:
  7. // 创建SVG画布
  8. var svg = Snap("#canvas");
  9. // 绘制两个点
  10. var point1 = svg.circle(50, 50, 5);
  11. var point2 = svg.circle(150, 150, 5);
  12. // 绘制引线
  13. var line = svg.line(point1.attr("cx"), point1.attr("cy"), point2.attr("cx"), point2.attr("cy")).attr({
  14.     stroke: "#000",
  15.     strokeWidth: 1,
  16. });
  17. // 绘制箭头
  18. var arrow = svg.polygon([-3, 0, 0, -6, 3, 0]).attr({
  19.     fill: "#000",
  20. });
  21. // 计算箭头位置和角度
  22. var dx = point2.attr("cx") - point1.attr("cx");
  23. var dy = point2.attr("cy") - point1.attr("cy");
  24. var angle = Math.atan2(dy, dx) * 180 / Math.PI;
  25. var x = point2.attr("cx") - Math.cos(angle * Math.PI / 180) * 10;
  26. var y = point2.attr("cy") - Math.sin(angle * Math.PI / 180) * 10;
  27. // 将箭头移动并旋转到正确位置
  28. arrow.transform("translate(" + x + "," + y + ") rotate(" + angle + ")");
  29. // 绘制文字
  30. var text = svg.text((point1.attr("cx") + point2.attr("cx")) / 2, (point1.attr("cy") + point2.attr("cy")) / 2, "10").attr({
  31.     "text-anchor": "middle",
  32. });
  33. // 计算文字位置
  34. var bbox = text.getBBox();
  35. var textX = bbox.x + bbox.width / 2;
  36. var textY = bbox.y + bbox.height / 2;
  37. // 将文字移动到正确位置
  38. text.attr({ x: textX, y: textY });
  39. // 绘制横线
  40. var line2 = svg.line(textX - 10, textY, textX + 10, textY).attr({
  41.     stroke: "#000",
  42.     strokeWidth: 1,
  43. });
  44. // 将箭头和文字移到最顶层
  45. arrow.appendTo(svg);
  46. text.appendTo(svg);
  47. // 给点添加拖拽事件
  48. point1.drag(function(dx, dy, x, y) {
  49.     this.attr({ cx: parseInt(this.ox) + dx, cy: parseInt(this.oy) + dy });
  50.     line.attr({ x1: this.attr("cx"), y1: this.attr("cy") });
  51.     updateArrow();
  52.     updateText();
  53.     updateLine2();
  54. }, function() {
  55.     this.ox = this.attr("cx");
  56.     this.oy = this.attr("cy");
  57. });
  58. point2.drag(function(dx, dy, x, y) {
  59.     this.attr({ cx: parseInt(this.ox) + dx, cy: parseInt(this.oy) + dy });
  60.     line.attr({ x2: this.attr("cx"), y2: this.attr("cy") });
  61.     updateArrow();
  62.     updateText();
  63.     updateLine2();
  64. }, function() {
  65.     this.ox = this.attr("cx");
  66.     this.oy = this.attr("cy");
  67. });
  68. // 更新箭头位置和角度
  69. function updateArrow() {
  70.     var dx = point2.attr("cx") - point1.attr("cx");
  71.     var dy = point2.attr("cy") - point1.attr("cy");
  72.     var angle = Math.atan2(dy, dx) * 180 / Math.PI;
  73.     var x = point2.attr("cx") - Math.cos(angle * Math.PI / 180) * 10;
  74.     var y = point2.attr("cy") - Math.sin(angle * Math.PI / 180) * 10;
  75.     arrow.transform("translate(" + x + "," + y + ") rotate(" + angle + ")");
  76. }
  77. // 更新文字位置
  78. function updateText() {
  79.     var bbox = text.getBBox();
  80.     var textX = bbox.x + bbox.width / 2;
  81.     var textY = bbox.y + bbox.height / 2;
  82.     text.attr({ x: textX, y: textY });
  83. }
  84. // 更新横线位置
  85. function updateLine2() {
  86.     var bbox = text.getBBox();
  87.     var textX = bbox.x + bbox.width / 2;
  88.     var textY = bbox.y + bbox.height / 2;
  89.     line2.attr({ x1: textX - 10, y1: textY, x2: textX + 10, y2: textY });
  90. }<span style="font-family: 宋体; font-size: 10.5pt; background-color: rgb(255, 255, 255);"> </span>
复制代码
这个示例代码演示了如何绘制一个简单的CAD引线标注,并实现拖拽修改点、自动计算箭头位置和角度、自动调整文字位置和水平线位置等功能。您可以根据需要对代码进行修改和调整。
GMT+8, 2025-5-1 06:17 , Processed in 0.145444 second(s), 27 queries , Gzip On.
