查看: 1041|回复: 0
[软件与安装] 如何开发网页版CAD的样条曲线功能
发表于 2023-5-26 11:39:35 | 显示全部楼层 |阅读模式
以下是网页CAD使用 JavaScript HTML5 Canvas 绘制样条曲线的示例代码:
HTML 代码:
  1. <!DOCTYPE html>
  2. <html>
  3. <head>
  4. <title>Spline Curve</title>
  5. <meta charset="UTF-8">
  6. <style type="text/css">
  7.   canvas {
  8.    border: 1px solid black;
  9.   }
  10. </style>
  11. </head>
  12. <body>
  13. <canvas id="canvas" width="800" height="500"></canvas>
  14. <script src="spline.js"></script>
  15. <script>
  16.   // 绘制样条曲线
  17.   var canvas = document.getElementById('canvas');
  18.   if (canvas.getContext) {
  19.    var ctx = canvas.getContext('2d');
  20.    ctx.fillStyle = 'white';
  21.    ctx.fillRect(0, 0, canvas.width, canvas.height);
  22.    var points = [
  23.     { x: 50, y: 100 },
  24.     { x: 200, y: 150 },
  25.     { x: 300, y: 250 },
  26.     { x: 400, y: 200 },
  27.     { x: 500, y: 300 }
  28.    ];
  29.    var tension = 0.5;
  30.    var segments = 50;
  31.    var splinePoints = getSplinePoints(points, tension, segments);
  32.    drawCurve(ctx, splinePoints);
  33.   }
  34. </script>
  35. </body>
  36. </html>
  37. JavaScript 代码(spline.js):
  38. // 计算样条曲线上的点
  39. function getSplinePoints(points, tension, segments) {
  40. if (points.length < 2) return [];
  41. // 初始化矩阵
  42. var m = [];
  43. for (var i = 0; i < points.length; i++) {
  44.   m[i] = [1, points[i].x, points[i].x * points[i].x, points[i].x * points[i].x * points[i].x];
  45. }
  46. // 计算常数向量
  47. var b = [];
  48. for (var i = 0; i < points.length; i++) {
  49.   b[i] = [points[i].y];
  50. }
  51. // 计算系数矩阵
  52. var mt = math.transpose(m);
  53. var a = math.multiply(mt, m);
  54. var ai = math.inv(a);
  55. var x = math.multiply(ai, mt);
  56. x = math.multiply(x, b);
  57. // 计算曲线上的点
  58. var curve = [];
  59. for (var i = 0; i < (points.length - 1); i++) {
  60.   for (var j = 0; j < segments; j++) {
  61.    var t = j / segments;
  62.    var t2 = t * t;
  63.    var t3 = t2 * t;
  64.    var h00 = 2 * t3 - 3 * t2 + 1;
  65.    var h01 = -2 * t3 + 3 * t2;
  66.    var h10 = t3 - 2 * t2 + t;
  67.    var h11 = t3 - t2;
  68.    var px = h00 * points[i].x + h01 * points[i + 1].x + h10 * tension * (points[i + 1].x - points[i].x) + h11 * tension * (points[i + 2].x - points[i + 1].x);
  69.    var py = h00 * x[i][0] + h01 * x[i + 1][0] + h10 * tension * (x[i + 1][0] - x[i][0]) + h11 * tension * (x[i + 2][0] - x[i + 1][0]);
  70.    curve.push({ x: px, y: py });
  71.   }
  72. }
  73. return curve;
  74. }
  75. // 绘制曲线
  76. function drawCurve(ctx, points) {
  77. ctx.lineWidth = 2;
  78. ctx.strokeStyle = 'black';
  79. ctx.beginPath();
  80. ctx.moveTo(points[0].x, points[0].y);
  81. for (var i = 1; i < points.length; i++) {
  82.   ctx.lineTo(points[i].x, points[i].y);
  83. }
  84. ctx.stroke();
  85. }<span style="font-family: 宋体; font-size: 10.5pt; background-color: rgb(255, 255, 255);"> </span>
复制代码
使用这个代码,你可以在网页中绘制出指定点的样条曲线。代码中的 points 数组包含要绘制曲线的点,tension 参数控制曲线的平滑度,segments 参数控制曲线的精细度以上是在线CAD中样条曲线的开发思路,有其他问题可以到梦想CAD控件官网查看云图产品文档。
GMT+8, 2025-5-1 07:45 , Processed in 0.165892 second(s), 27 queries , Gzip On.
