查看: 1448|回复: 3
求大佬完善一下这个偏移
发表于 2023-5-25 23:07:24 | 显示全部楼层 |阅读模式
2明经币
求大佬帮忙完善一下,弄了一晚上,实在不会了
(defun c:KK (/ *error* en os p0)
        (setq oldlayer (getvar "clayer"));_记录当前图层
        (if (not (tblsearch "layer" "图层AA"))
                (command "layer" "m" "图层AA" "c" 2 "" "lt" "DASHDOT" "" "")  ;建立图层
        (setvar "clayer" "图层AA")
        (defun *error* (msg)
                (princ mag)
                (setvar "cmdecho" 1)
                (setvar "osmode" os)
        (setq os (getvar "osmode"))
        (mapcar 'setvar '("cmdecho" "osmode") '(0 0))
        (setq SS 50)
        (while (and (setq en (car (entsel))) (setq p0 (getpoint "\n偏移方向:")))
                (if (= SS 0)
                        (command "copy" en "" p0 p0)
                        (command "offset" SS en p0 "")
                (VLA-PUT-LAYER (VLAX-ENAME->VLA-OBJECT (ENTLAST))"图层AA")
                (setq ent (ssget "X" (list (cons 8 "图层A")(cons 410 (getvar 'ctab)))))
                (command "change" ent "" "p" "c" "bylayer" "")
        (setvar "clayer" OldLayer)
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
发表于 2023-5-25 23:07:25 | 显示全部楼层
  1. (defun c:KK (/ *error* en os p0)
  2.   (setq oldlayer (getvar "clayer")) ;_记录当前图层
  3.   (if (not (tblsearch "layer" "图层AA"))
  4.     (command "layer" "m" "图层AA" "c" 2 "" "lt" "DASHDOT" "" "")
  5.                                         ;建立图层
  6.   )
  7.   (setvar "clayer" "图层AA")
  8.   (defun *error* (msg)
  9.     (princ mag)
  10.     (setvar "cmdecho" 1)
  11.     (setvar "osmode" os)
  12.     (princ)
  13.   )
  14.   (setq os (getvar "osmode"))
  15.   (mapcar 'setvar '("cmdecho" "osmode") '(0 0))
  16.   (setq        SS   50
  17.         SS1  (SSADD)
  18.         LST  NIL
  19.         LST1 NIL
  20.         I    0
  21.   )
  22.   (SETQ SS1 (SSGET))
  23.   (setq p0 (getpoint "\n偏移方向:"))
  24.   (REPEAT (SSLENGTH SS1)
  25.     (SETQ E (SSNAME SS1 I))
  26.     (if        (= SS 0)
  27.       (command "copy" en "" p0 p0)
  28.       (command "offset" SS e p0 "")
  29.     )
  30.     (SETQ E1  (ENTLAST)
  31.           LST (CONS E1 LST)
  32.           I   (1+ I)
  33.     )
  34.     (VLA-PUT-LAYER (VLAX-ENAME->VLA-OBJECT (ENTLAST)) "图层AA")
  35.   )
  36.   (IF (> (LENGTH LST) 1)
  37.     (PROGN
  38.       (SETQ II 0
  39.             J (1+ II)
  40.       )
  41.       (REPEAT (1- (LENGTH LST))
  42.         (REPEAT        (- (LENGTH LST) J )
  43.           (SETQ        OBJ1 (vlax-ename->vla-object (NTH II LST))
  44.                 OBJ2 (vlax-ename->vla-object (NTH J LST))
  45.           )
  46.           (setq        ipts (vlax-variant-value
  47.                        (vla-intersectwith
  48.                          obj1
  49.                          obj2
  50.                          acExtendNone
  51.                        )
  52.                      )
  53.           )
  54.           (if (> (vlax-safearray-get-u-bound ipts 1) 0)
  55.             (progn
  56.               (setq ipts (vlax-safearray->list ipts)
  57.                                         ;将vla交点变体转化成表的形式
  58.                     lst1 '()
  59.               )
  60.               (if (> (length ipts) 3)        ;分离多个交点
  61.                 (repeat        (/ (length ipts) 3)
  62.                   (setq        lst1
  63.                              (cons (list (car ipts) (cadr ipts) (caddr ipts))
  64.                                    lst1
  65.                              )
  66.                         ipts (cdddr ipts)
  67.                   )
  68.                 )
  69.                 (SETQ LST1 (LIST ipts))
  70.               )
  71.               (FOREACH X (LIST (NTH II LST) (NTH J LST))
  72.                 (IF
  73.                   (> (DISTANCE (vlax-curve-getEndPoint X) (CAR LST1))
  74.                      (DISTANCE (vlax-curve-getStartPoint X) (CAR LST1))
  75.                   )
  76.                    (VLA-PUT-StartPoint
  77.                      (vlax-ename->vla-object X)
  78.                      (vlax-3D-point (CAR LST1))
  79.                    )
  80.                    (VLA-PUT-EndPoint
  81.                      (vlax-ename->vla-object X)
  82.                      (vlax-3D-point (CAR LST1))
  83.                    )
  84.                 )
  85.               )
  86.             )
  87.           )
  88.           (SETQ J (1+ J))
  89.         )
  90.         (SETQ II (1+ II))
  91.       )
  92.     )
  93.   )
  94.   (setq
  95.     ent        (ssget "X" (list (cons 8 "图层A") (cons 410 (getvar 'ctab))))
  96.   )
  97.   (command "change" ent "" "p" "c" "bylayer" "")
  98.   (setvar "clayer" OldLayer)
  99.   (setvar "cmdecho" 1)
  100.   (setvar "osmode" os)
  101.   (princ)
  102. )
_Levin + 1 很给力!
发表于 2023-5-28 09:30:25 | 显示全部楼层
来学习来学习来学习
 楼主| 发表于 2023-6-2 17:34:54 | 显示全部楼层
GMT+8, 2025-5-25 05:19 , Processed in 0.152334 second(s), 23 queries , Gzip On.
