楼主: 664571221
[提问] 各位大神看下如何过滤选择块名中含有 灯 这个字的块
 楼主| 发表于 2023-5-8 15:11:12 | 显示全部楼层
xyp1964 发表于 2023-5-7 23:17
一共选择了个块名称含灯的块
派大上码..........
发表于 2023-5-8 19:52:28 | 显示全部楼层
664571221 发表于 2023-5-8 09:02
大神可以数出来了,是否可以吧文字插入cad呢
改了,再试试
发表于 2023-5-9 13:34:31 | 显示全部楼层
  1. (defun c:tt ()
  2.   "统计块名称含灯的块"
  3.   (if (setq ss (ssget "x" '((0 . "INSERT") (66 . 1))))
  4.     (progn
  5.       (setq lst(vl-remove-if-not  '(lambda (x) (setq a (mapcar 'last (xyp-Att2list x))) (vl-some '(lambda (x) (vl-string-search "灯" x)) a))(xyp-Ss2List ss)))
  6.       (princ (strcat "\n一共选择了< " (itoa (length lst)) " >个块名称含灯的块"))
  7.     )
  8.   )
  9.   (princ)
  10. )
 楼主| 发表于 2023-5-14 21:49:27 | 显示全部楼层
(defun c:tt(/ p s)
        (if (ssget ":S" '((0 . "insert")(2 . "$equip$*")))
                        (vlax-for e (vla-get-activeselectionset (vla-get-ActiveDocument (vlax-get-acad-object)))
                                (if        (vla-Get-HasAttributes e)
                                        (foreach x
                                                (vlax-safearray->list (vlax-variant-value (vla-GetAttributes e)))
                                                (if (and (= "A" (vla-Get-TagString x))
        (wcmatch (vla-Get-TextString x)"*灯*")
                                                        (setq s (cons e s))
                        (if (and  s (setq s (mapcar '(lambda(x)(vlax-get x 'insertionpoint)) s))
                                                (setq p (getpoint"\n大力出奇迹..."))
                                        (command "text" p 350 0 (strcat "选中了"(itoa (length s))"个含灯的块"))
                                        (foreach x s (command "line" "non" x "non" p ""))
 楼主| 发表于 2023-5-14 21:51:12 | 显示全部楼层
664571221 发表于 2023-5-14 21:49
(defun c:tt(/ p s)
楼上是波总的代码
发表于 2023-5-16 00:48:32 | 显示全部楼层
院长这个X用的好
GMT+8, 2025-10-23 09:55 , Processed in 0.159474 second(s), 20 queries , Gzip On.
