查看: 1279|回复: 2
[资源下载] Web端cad测量面积的示例代码(网页CAD测量面积功能开发)
发表于 2023-4-27 13:48:05 | 显示全部楼层 |阅读模式
以下是一个webcad测量面积的示例代码,基于Three.jsjQuery库实现:
HTML部分:
  1. <!DOCTYPE html>
  2. <html>
  3.   <head>
  4.     <meta charset="UTF-8">
  5.     <title>Web端CAD测量面积</title>
  6.     <style>
  7.       canvas {
  8.         width: 100%;
  9.         height: 100%;
  10.         display: block;
  11.       }
  12.     </style>
  13.   </head>
  14.   <body>
  15.     <div id="container"></div>
  16.     <div id="output">
  17.       <p>请点击屏幕选择点开始绘制,再次点击结束绘制并显示面积。</p >
  18.     </div>
  19.     <script src="https://cdn.bootcdn.net/ajax/libs/jquery/3.6.0/jquery.min.js"></script>
  20.     <script src="https://cdn.bootcdn.net/ajax/libs/three.js/r125/three.min.js"></script>
  21.     <script src="app.js"></script>
  22.   </body>
  23. </html>
  24. JavaScript部分(app.js):
  25. // 初始化Three.js场景、相机、渲染器
  26. var scene = new THREE.Scene();
  27. var camera = new THREE.PerspectiveCamera(
  28.   75, window.innerWidth/window.innerHeight, 0.1, 1000 );
  29. var renderer = new THREE.WebGLRenderer({ antialias: true });
  30. renderer.setSize( window.innerWidth, window.innerHeight );
  31. document.getElementById("container").appendChild(renderer.domElement);
  32. // 初始化画线的材质
  33. var material = new THREE.LineBasicMaterial( { color: 0x0000ff } );
  34. // 初始化测量变量
  35. var linePoints = [];
  36. var area = 0;
  37. // 监听鼠标点击事件,绘制线段并计算面积
  38. document.addEventListener( 'click', onClick, false );
  39. function onClick( event ) {
  40.   // 获取鼠标点击坐标
  41.   var mouse = new THREE.Vector2();
  42.   mouse.x = ( event.clientX / window.innerWidth ) * 2 - 1;
  43.   mouse.y = - ( event.clientY / window.innerHeight ) * 2 + 1;
  44.   // 创建射线
  45.   var raycaster = new THREE.Raycaster();
  46.   raycaster.setFromCamera( mouse, camera );
  47.   // 计算射线和平面的交点,并绘制线段
  48.   var plane = new THREE.Plane(new THREE.Vector3(0, 0, 1), 0);
  49.   var intersection = new THREE.Vector3();
  50.   raycaster.ray.intersectPlane(plane, intersection);
  51.   linePoints.push(intersection);
  52.   if (linePoints.length > 1) {
  53.     var geometry = new THREE.BufferGeometry().setFromPoints(linePoints);
  54.     var line = new THREE.Line(geometry, material);
  55.     scene.add(line);
  56.     // 计算面积
  57.     var v1 = linePoints[linePoints.length-2];
  58.     var v2 = linePoints[linePoints.length-1];
  59.     area += (v1.x * v2.y - v2.x * v1.y) / 2;
  60.     $("#output").html("<p>面积: " + Math.abs(area).toFixed(2) + "</p >");
  61.   }
  62. }
  63. // 渲染场景
  64. function animate() {
  65.   requestAnimationFrame( animate );
  66.   renderer.render( scene, camera );
  67. }
  68. animate();<span style="font-family: 宋体; font-size: 10.5pt; background-color: rgb(255, 255, 255);"> </span>
复制代码
这个示例代码可以在浏览器中运行,并实现了在Three.js场景中绘制线段、计算面积等功能在线CAD有很多其他功能,可以到梦想CAD控件官网查看。以上代码可以根据实际需求对代码进行修改和拓展。
发表于 2023-4-27 18:13:42 | 显示全部楼层
这个网页代码运行不了呢,看不到效果。
 楼主| 发表于 2023-5-4 11:57:42 | 显示全部楼层
Noangler 发表于 2023-4-27 18:13
这个网页代码运行不了呢,看不到效果。
联系q:1298095305
GMT+8, 2025-5-1 05:51 , Processed in 0.155413 second(s), 24 queries , Gzip On.
