查看: 2947|回复: 18
Cad图块中线型比例修改
发表于 2023-4-17 20:20:35 | 显示全部楼层 |阅读模式
对图块进行操作时,在不炸开图块的情况下,如何修改图块内子图元的线型比例?;比如说:我在CAD图中插入一已经做好的图块,但由于绘图设置原因,在有的图中此图块中虚线比例太小,几乎看不清楚,想再编写一程序能修改图块中子图元的线型比例。就不知如何下手,折磨我好几天了?
谢谢你的帮助,从明经这几天的学习中,我自已慢慢摸索出如下方法,测试后能满足我工作的需要,但不知我这样编写的思路是不是太繁锁,希望论坛里的哪位大侠帮我再优化一下。万分感谢
(defun c:xg (/ ss sslen sname snlast n tk tl)
  (vl-load-com)
  (setq old_cm (getvar "cmdecho"))
  (setq old_os (getvar "osmode"))
  (setq old_bl (getvar "blipmode"))
  (setvar "cmdecho" 0)
  (setvar "osmode" 39)
  (setvar "blipmode" 0)
  (prompt "\n请选择要修改的图块...")
  (setq ss (ssget  (list '(0 . "INSERT"))))
  (if (null ss)
    (alert "\n没有选中任何要修改的图块...")
      (repeat (setq sslen (sslength ss))
        (setq sname (ssname ss (setq sslen (1- sslen))))
        (setq
          snlast (tblobjname "Block" (cdr (assoc 2 (entget sname))))
        (while
          (/= (cdr (assoc 6 (entget (setq snlast (entnext snlast)))))
              "DASHED"
        (setq n (getdist "\n请输入要修改的线型比例"))
        (setq
          tk (vla-put-linetypescale (vlax-ename->vla-object snlast) n)
        (setq tl (vla-put-color (vlax-ename->vla-object snlast) 40))
        (entmod (entget sname))
        (redraw sname 1)
  (setvar "cmdecho" old_cm)
  (setvar "osmode" old_os)
  (setvar "blipmode" old_bl)
为何总是报错?有大神能帮忙完善了此贴?
 楼主| 发表于 2023-4-20 14:01:22 | 显示全部楼层
感谢河流之王支持,帮忙调试好,无私奉献源码如下。
可修改单个线型改为设置输入的线型比例
另外大家有需求的,可以找河流大神定制。专业且态度好
(defun c:lts (/ lts:processed idx scl sel LINENAME)
  (initget 6)
  (if (not scl2)
    (setq scl2 20)
  (if (NOT (setq scl
                  (getreal (STRCAT "\n 请输入线性型比例<" (rtos scl2 2 0) ">")
    (SETQ SCL SCL2)
    (SETQ SCL2 SCL)
  (PRINC "\n 选择源线型和修改图形")
  (if (setq sel (ssget))
    (PROGN
      (repeat (setq idx (sslength sel))
        (SETQ E (ssname sel (setq idx (1- idx))))
        (IF (/= "INSERT" (CDR (ASSOC 0 (ENTGET E))))
          (PROGN
            (SETQ LINENAME
                   (vl-catch-all-apply
                     'vla-GEt-linetype
                     (LIST (vlax-ename->vla-object E))
            (IF        (= LINENAME "ByLayer")
              (SETQ LINENAME
                     (CDR (ASSOC
                            6
                            (tblsearch "LAYER"
                                       (CDR (ASSOC 8 (ENTGET E)))
        (lts:obj
          (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))
          scl
          LINENAME
  (vla-regen lts:acdoc acallviewports)
(defun lts:blk (obj scl / bln)
  (if (not (member (setq bln (vla-get-name obj)) lts:processed))
      (vlax-map-collection
        (vla-item lts:acblk bln)
        '(lambda (obj) (lts:obj obj scl LINENAME))
      (setq lts:processed (cons bln lts:processed))
(defun lts:obj (obj scl LINENAME / LINENAME1)
  (IF (= (vla-GEt-linetype obj) "ByLayer")
    (SETQ LINENAME1
           (CDR
             (ASSOC
               6
               (tblsearch "LAYER"
                          (CDR (ASSOC 8 (ENTGET (vlax-vla-object->ename obj))))
    (SETQ LINENAME1 (vla-GEt-linetype obj))
  (if (and (vlax-write-enabled-p obj)
           (vlax-property-available-p obj 'linetypescale t)
           (= LINENAME LINENAME1)
    (vla-put-linetypescale obj scl)
  (if (= "AcDbBlockReference" (vla-get-objectname obj))
    (lts:blk obj scl)
(setq lts:acdoc        (vla-get-activedocument (vlax-get-acad-object))
      lts:acblk        (vla-get-blocks lts:acdoc)
(vl-load-com)
发表于 2023-4-18 13:09:38 | 显示全部楼层
  1. (defun c:lts ( / lts:processed idx scl sel )
  2.     (initget 6)
  3.     (if (setq scl (getreal "\n 请输入线性型比例"))
  4.         (if (setq sel (ssget "_:L"))
  5.             (repeat (setq idx (sslength sel))
  6.                 (lts:obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))) scl)
  7.             )
  8.         )
  9.     )
  10.     (vla-regen lts:acdoc acallviewports)
  11.     (princ)
  12. )
  13. (defun lts:blk ( obj scl / bln )
  14.     (if (not (member (setq bln (vla-get-name obj)) lts:processed))
  15.         (progn
  16.             (vlax-map-collection (vla-item lts:acblk bln) '(lambda ( obj ) (lts:obj obj scl)))
  17.             (setq lts:processed (cons bln lts:processed))
  18.         )
  19.     )
  20. )
  21. (defun lts:obj ( obj scl )
  22.     (if (and (vlax-write-enabled-p obj) (vlax-property-available-p obj 'linetypescale t)(=  "DASHED"(vla-GEt-linetype obj )));;;;只更改"DASHED"的
  23.         (vla-put-linetypescale obj scl)
  24.     )
  25.     (if (= "AcDbBlockReference" (vla-get-objectname obj))
  26.         (lts:blk obj scl)
  27.     )
  28. )
  29. (setq lts:acdoc (vla-get-activedocument (vlax-get-acad-object))
  30.       lts:acblk (vla-get-blocks lts:acdoc)
  31. )
  32. (vl-load-com) (princ)
  33. ;;;;代码来至于LeeMac
关于 entmod 函数所作的修改有一些限制:
不能改变一个图元的类型和句柄。如果一定要这样做,只能先调用 entdel 函数删除它,然后调用 command 或 entmake 函数创建新图元。
entmod 函数不能修改内部域,如 SEQEND 图元的 -2 组中的图元名,如果试图作这样的修改,将会被系统忽略。
不能使用 entmod 函数修改视口图元。
可以将图元的空间可见性改为 0 或 1(视口对象除外)。如果用 entmod 函数修改了块定义中的图元,该修改会影响图形中该块的所有实例。
在用 entmod 函数修改顶点图元前,应先读出或写入多段线的头部。如果最近处理的多段线图元不是该顶点所在的多段线,可能会丢失宽度信息(40 和 41 组)。
警告! 可以用 entmod 函数修改块定义中的图元,但这样做可能会生成引用自身的块,导致 AutoCAD 系统崩溃。
(vla-Update lineObj)
 楼主| 发表于 2023-4-18 16:52:23 | 显示全部楼层
加班画图敲码必备解压经典世界名曲,自提不谢file:///C:\Users\Administrator\AppData\Roaming\Tencent\QQTempSys\G@YVKCPZR)X}3UKB(_VF`LW.gif
链接:file:///C:\Users\Administrator\AppData\Roaming\Tencent\QQTempSys\%W@GJ$ACOF(TYDYECOKVDYB.pnghttps://pan.baidu.com/s/1sABJ7kVlrzfVNOAo4XENBA
提取码:1111
发表于 2023-4-17 21:16:47 | 显示全部楼层
要学会自己搜索啊= =http://bbs.mjtd.com/thread-186469-1-1.html
 楼主| 发表于 2023-4-17 21:44:21 | 显示全部楼层
连接中LEE的源码复制,运行不了呢
 楼主| 发表于 2023-4-17 21:45:30 | 显示全部楼层
你的是修改过的吗?运行什么效果?没有GIF?
 楼主| 发表于 2023-4-17 21:47:59 | 显示全部楼层
是这个效果吗
发表于 2023-4-18 13:33:46 | 显示全部楼层
你的while  循环是没用的,你直接屏蔽掉就不报错了
 楼主| 发表于 2023-4-18 16:54:55 | 显示全部楼层
各位有幸到访者,请查看录制动态gif教程,方便注明插件功能!
GMT+8, 2025-5-20 10:04 , Processed in 0.166828 second(s), 25 queries , Gzip On.
