楼主: kalong
[2024] 国外和谐!
发表于 2023-3-29 12:27:43 | 显示全部楼层
ReadMe - 机翻中文.txt
Autodesk License Patcher Is An Universal Patcher For All Autodesk Products.
This Tool Just Automates NLM Method. Everything is open sourced.
This Tool Will;
Place And Replace Necessary Files
Edit Hostname And MAC Address In License File
Create Task To Start Licensing Services At Boot
Block In And Out Internet Traffic To Autodesk Licensing Files
Restart Licensing Services In Correct Way
Start Network License Manager
How To;
1) Download And Install Any Autodesk Product
2) Run "Autodesk License Patcher" With Administrator Rights And UAC Disabled (Pause Security If Patcher Is Blocked)
3) Launch Any Installed Autodesk Product, And When Prompted Do; Select "Use A Network License"
Notes;
1) If you relaunch the tool, it will first uninstall previous version, then reinstall for a fresh install.
2) If you want to uninstall and revert all the changes that have been made by tool launch "Autodesk License Patcher Uninstaller".
3) Supports any autodesk product with any ADSK Licensing.
4) At every boot, automatic service will start and refresh the ADSKService + NLM to fix any possible issue. This would take 7-10 secconds, so wait 10 secconds before running any Autodesk application.
5) Patch will work in online/offline/virtual/real environments.
6) If you can't install or uninstall products, first use Autodesk License Patcher Uninstaller.
Bonus;
1) Internet Connection will allow you to block or unblock in and out internet connection to autodesk products by using windows firewall.
2) Bloatware CleanUp will cleanup genuine service, access service, single sign on component, network license manager, identitiy manager and digital signature icons, also blocks these softwares to run. Apply before Autodesk License Patcher Installer.
Warning;
This tools is just an automated repack, and it is for research purposes ONLY! DO NOT USE IT FOR PIRACY!
ALWAYS SUPPORT DEVELOPOERS, BUY IF YOU LIKE/USE IT.
Changelog;
-first release
Pass; "Autodesk"
Autodesk License Patcher 是适用于所有 Autodesk 产品的通用修补程序。
该工具只是自动化NLM方法。一切都是开源的。
此工具将;
放置和替换必要的文件
编辑许可证文件中的主机名和 MAC 地址
创建任务以在启动时启动许可服务
阻止进出到 Autodesk 许可文件的互联网流量
以正确的方式重新启动许可服务
启动网络许可管理器
如何;
1) 下载并安装任何欧特克产品
2) 在管理员权限和禁用 UAC 的情况下运行“Autodesk 许可修补程序”(如果修补程序被阻止,则暂停安全性)
3) 启动任何已安装的欧特克产品,并在出现提示时启动;选择“使用网络许可证”
注;
1) 如果重新启动该工具,它将首先卸载以前的版本,然后重新安装以进行全新安装。
2)如果要卸载并还原工具启动“Autodesk许可证补丁程序卸载程序”所做的所有更改。
3) 支持具有任何 ADSK 许可的任何欧特克产品。
4) 每次启动时,自动服务将启动并刷新 ADSKService + NLM 以修复任何可能的问题。这将需要 7-10 秒,因此在运行任何 Autodesk 应用程序之前等待 10 秒。
5)补丁将在在线/离线/虚拟/真实环境中工作。
6) 如果无法安装或卸载产品,请先使用 Autodesk 许可修补程序卸载程序。
附赠;
1)Internet Connection(互联网连接):将允许您使用 Windows 防火墙阻止或取消阻止与 Autodesk 产品的互联网连接。
2)Bloatware CleanUp(大软件清理):将清理正版服务,访问服务,单点登录组件,网络许可证管理器,身份管理器和数字签名图标,并阻止这些软件运行。在 Autodesk 许可修补程序安装程序之前申请。
警告;
该工具只是一个自动重新打包,仅用于研究目的!不要将其用于盗版!
始终支持开发人员,如果您喜欢/使用它,请购买。
更新日志;
-首次发布
通过;“欧特克”
发表于 2023-3-29 12:28:14 | 显示全部楼层
收藏了再试,谢谢楼主!
发表于 2023-3-29 12:36:25 | 显示全部楼层
先下载了~
谢谢楼主的分享!
电脑不知道还跑不跑的动这麽高的版本CAD
发表于 2023-3-29 12:38:30 | 显示全部楼层
1) Install Autodesk Application - Do Not Start it yet
2) Install the Autodesk network license manager (v11.18.0) from crack folder (NLM.msi Update 8)
    -Default install is "C:\Autodesk\Network License Manager"
    -Stop any running instance (lmgrd, adskflex) if you have one
    -Replace adskflex.exe by cracked one
3) Replace the version.dll - \Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\AdskLicensingAgent\
4) Edit lic.dat and change HOSTNAME and MAC to suit your configuration (if you are not sure start LMTOOLS Utility and go to
   System Settings, your HOSTNAME and MAC will be listed)
   You can change vendor port too and add your previous licenses of course :)
   Save lic.dat where you want (we suggest to "C:\Autodesk\Network License Manager" folder)
5) You have 2 options:
    1)Start Network License Manager manually :
    Run the license manager with "lmgrd.exe -z -c lic.dat" from "C:\Autodesk\Network License Manager" folder
    Or
    2)Create a Service: (suggested)
     Start LMTOOLS Utility (lmtools.exe GUI) from "C:\Autodesk\Network License Manager" folder
   - in 'config services', add a "Autodesk' service name
                           choose C:\Autodesk\Network License Manager\lmgrd.exe for path to lmgrd
                           choose X:\path\where\you\saved\lic.dat for path to license file
                           choose a empty file to have debug logs (optional)
                           tick 'start server at power up' and 'use services'
                           Click Save
   - in 'service/license file' choose configuration using services and tick 'ignore license file path env var" (dont click that if you
                               you wanna use a ditributed licensing .. or you will have to edit or create a Licpath.lic file)
   - in 'start/stop/read' click 'start server'
                          click 'rereadlicense file'
   - in 'server status' click 'perform status enquiry'
                        check that you have 'adskflex: UP v11.18.0'
                        check features are activated : Users of 87545ACD_2022_0F:  (Total of 100 licenses issued;  Total of 0 licenses in use) for example
   - in 'server diags' check all featured can be checked out
   - check logs also win 'config services' if you configured it
7) Start Your Autodesk Application
   - When prompted select "Use a network license"
   - Select "Single license server"
   - Use 127.0.0.1, localhost or where the flexlm daemon is installed (syntax could be port@server).
NOTE: in some cases after restart your computer still requires license path go in services.msc and make autodesk license server run automatic mode.
NOTE: This is mixed Magnitude - xforce i made so welcome use it as you like.
TOTAL domination again for your pleasure
Smoke it!
You Could also set a distributed license system, having one machine serving them all
For that matter
you need to Set the ADSKFLEX_LICENSE_FILE environment variable on the client machine (the procedure varies depending on the operating system).
To set the environment variable
Use the procedure described for your operating system to set the environment variable:
For Windows 7/8/10:
    Right-click Computer and click Properties, or, in the Control Panel select System and Maintenance > System
    Click Advanced system settings and select the Advanced tab.
    Click Environment Variables.
    In the Environment Variables dialog box, under System Variables, click New.
    In the New System Variable dialog box, enter ADSKFLEX_LICENSE_FILE in the Variable Name field.
    In the Variable Value field, enter an at sign (@) followed by the host name of each license server to which you want to point the client. Separate each server name with a semicolon (;). For example:
    @server1;@server2;@server3
Dont forget to open your firewall, you may also need to check the LICPATH.LIC file in root of the installed application in case you have issues
If you still want to use 2018-19-20-21 applications, simply add their features with the corrected signature into our new lic.dat license file.
SSQ-MIX-XFORCE
install - 机翻中文.txt
1) 安装欧特克应用程序 - 暂时不启动它
2) 从破解文件夹 (NLM.msi Update 8 ) 安装欧特克网络许可管理器 Autodesk network license manager(v11.18.0)
    -默认安装为“C:\Autodesk\Network License Manager”
    - 停止任何正在运行的实例(lmgrd,adskflex),如果你有一个
    -从破解的文件替换 adskflex.exe
3) 替换version.dll - \Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\AdskLicensingAgent\
4) 编辑 lic.dat 并更改主机名和 MAC 以适合您的配置(如果您不确定,请启动 LMTOOLS 实用程序并转到
   系统设置,您的主机名和MAC将被列出)
   您也可以更改供应商端口并添加以前的许可证:)
   将lic.dat保存在您想要的位置(我们建议使用“C:\Autodesk\Network License Manager”文件夹)
5)您有2个选择:
    1)手动启动网络许可证管理器:
    使用“C:\Autodesk\Network License Manager”文件夹中的“lmgrd.exe -z -c lic.dat”运行许可证管理器
    或
    2)创建服务:(建议)
     从“C:\Autodesk\Network License Manager”文件夹启动LMTOOLS实用程序(lmtools.exe GUI)
   - 在“配置服务”中,添加“Autodesk”服务名称
                           选择 C:\Autodesk\Network License Manager\lmgrd.exe作为 lmgrd 的路径
                           选择 X:\path\where\you\saved\lic.dat 作为许可证文件的路径
                           选择一个空文件以包含调试日志(可选)
                           勾选“开机时启动服务器”和“使用服务”
                           点击保存
   - 在“服务/许可证文件”中选择使用服务进行配置,然后勾选“忽略许可证文件路径 env var”(如果您,请不要单击它
                               您想使用分发许可..或者您必须编辑或创建一个 Licpath.lic 文件)
   - 在“启动/停止/读取”中,单击“启动服务器”
                          点击“重新读取许可证文件”
   - 在“服务器状态”中,单击“执行状态查询”
                        检查您是否有“adskflex: UP v11.18.0”
                        检查功能已激活: 87545ACD_2022_0F用户: (共颁发了 100 个许可证; 总共 0 个许可证正在使用中),例如
   - 在“服务器诊断”检查所有功能都可以签出
   - 检查日志也会赢得“配置服务”,如果你配置了它
7) 启动您的欧特克应用程序
   - 出现提示时,选择“使用网络许可证”
   - 选择“单一许可证服务器”
   - 使用 127.0.0.1、本地主机或安装 flexlm 守护程序的位置(语法可能port@server)。
注意:在某些情况下,重新启动计算机后,仍需要许可证路径进入 services.msc 并使 Autodesk 许可服务器自动运行模式。
注意:这是混合的幅度 - xforce我做了所以欢迎随心所欲地使用它。
再次完全统治您的乐趣
抽烟!
您还可以设置一个分布式许可证系统,让一台机器为它们提供服务
就此而言,就此而言,该
您需要在客户端计算机上设置ADSKFLEX_LICENSE_FILE环境变量(该过程因操作系统而异)。
设置环境变量
使用针对您的操作系统描述的过程设置环境变量:
对于 Windows 7/8/10:
    右键单击“计算机”,然后单击“属性”,或者在“控制面板”中选择“系统”和“系统维护”>
    单击高级系统设置,然后选择高级选项卡。
    单击环境变量。
    在“环境变量”对话框中的“系统变量”下,单击“新建”。
    在“新建系统变量”对话框中,在“变量名称”字段中输入ADSKFLEX_LICENSE_FILE。
    在变量值字段中,输入 at 符号 (@),后跟要将客户端指向的每个许可证服务器的主机名。用分号 (;)) 分隔每个服务器名称。例如:
不要忘记打开防火墙,您可能还需要检查 LICPATH。已安装应用程序的根目录中的 LIC 文件,以防出现问题
如果您仍想使用 2018-19-20-21 应用程序,只需将带有更正签名的功能添加到我们新的 lic.dat 许可证文件中即可。
发表于 2023-3-29 12:42:56 | 显示全部楼层
用文件中acad.exe在安装目录直接替换破解吗?
发表于 2023-3-29 13:27:53 | 显示全部楼层
编程小子 发表于 2023-3-29 11:56
回去摸个轴,应该能成刀
没有大佬的卸载免更新工具,我不敢用啊
自己又删不了
发表于 2023-3-29 13:37:44 | 显示全部楼层
gglili2010 发表于 2023-3-29 13:27
没有大佬的卸载免更新工具,我不敢用啊
自己又删不了
5.1.0.135版本的卸载补丁早在去年11月就出来了啊
6.0的今天回去下载分析
发表于 2023-3-29 15:10:08 | 显示全部楼层
6.0的今天回去下载分析
CAD2024有这么个玩意,能卸载掉吗
发表于 2023-3-29 15:30:17 | 显示全部楼层
xpzzj 发表于 2023-3-29 15:10
CAD2024有这么个玩意,能卸载掉吗
我觉得这个就是以前的Autodesk desktop app翻版,应该可以直接卸载。
不过这个版本我还没深入研究它。
发表于 2023-3-29 16:31:50 | 显示全部楼层
不过这个版本我还没深入研究它。
卸载程序里没有他
并且2024没有ADSSO了
GMT+8, 2025-7-9 10:46 , Processed in 0.158864 second(s), 18 queries , Gzip On.
