查看: 1418|回复: 5
[提问] 请问各位高手:后置,前置,这个几个操作的lisp命令都是咋样的?
发表于 2023-3-14 15:34:38 | 显示全部楼层 |阅读模式
如题,由于经常用这几个命令。点来点去的很烦。所以我就想搞成lisp调用。
然后我再把一些其他操作再搞成lisp。这样手就不用这么累了。。。
哎,反正都是累。。。一天不知道点几千下。。。
 楼主| 发表于 2023-3-14 15:43:53 | 显示全部楼层
已经解决了。论坛有人问过了。
回复 支持 1 反对 1
发表于 2023-3-14 16:40:30 | 显示全部楼层
;;--------------------=={ Move to Top }==---------------------;;
;;  Moves a set of objects to the top of the draw order.      ;;
;;  Author: Lee Mac, Copyright ?2012 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  doc  - VLA Document Object                                ;;
;;  objs - Selection Set or List of Objects with same owner   ;;
;;  Returns: T if successful, else nil                        ;;
(defun LM:MovetoTop ( doc objs / tab )
    (if
        (and objs
            (or
                (listp objs)
                (setq objs (LM:ss->vla objs))
            (setq tab (LM:SortentsTable (LM:GetOwner doc (car objs))))
        (not (vla-movetotop tab (LM:SafearrayVariant vlax-vbobject objs)))
;;------------------=={ Move to Bottom }==--------------------;;
;;  Moves a set of objects to the bottom of the draw order.   ;;
;;  Arguments:                                                ;;
(defun LM:MovetoBottom ( doc objs / tab )
    (if
        (and objs
            (or
                (listp objs)
        (not (vla-movetobottom tab (LM:SafearrayVariant vlax-vbobject objs)))
;;---------------------=={ Move Above }==---------------------;;
;;  Moves a set of objects above a supplied object.           ;;
;;  Arguments:                                                ;;
;;  obj  - VLA Object above which to move objects             ;;
(defun LM:MoveAbove ( doc objs obj / tab )
    (if
        (and objs
            (or
                (listp objs)
        (not (vla-moveabove tab (LM:SafearrayVariant vlax-vbobject objs) obj))
;;---------------------=={ Move Below }==---------------------;;
;;  Moves a set of objects below a supplied object.           ;;
;;  Arguments:                                                ;;
;;  obj  - VLA Object below which to move objects.            ;;
(defun LM:MoveBelow ( doc objs obj / tab )
    (if
        (and objs
            (or
                (listp objs)
        (not (vla-movebelow tab (LM:SafearrayVariant vlax-vbobject objs) obj))
;;---------------------=={ Swap Order }==---------------------;;
;;  Swaps the draw order of two objects (may require regen).  ;;
;;  Arguments:                                                ;;
;;  obj1,obj2 - VLA Objects to swap                           ;;
(defun LM:SwapOrder ( doc obj1 obj2 / tab )
    (if (setq tab (LM:SortentsTable (LM:GetOwner doc obj1)))
        (not (vla-swaporder tab obj1 obj2))
;;---------------------=={ Get Owner }==----------------------;;
;;  Returns the Owner Object of the supplied VLA Object.      ;;
;;  Arguments:                                                ;;
;;  obj - VLA Object for which to return owner                ;;
;;  Returns: Owner Object of supplied VLA Object, else nil    ;;
(defun LM:GetOwner ( doc obj )
    (if
        (and
            (vlax-property-available-p obj 'ownerid32)
            (vlax-method-applicable-p  doc 'objectidtoobject32)
        (vla-objectidtoobject32 doc (vla-get-ownerid32 obj))
        (vla-objectidtoobject   doc (vla-get-ownerid   obj))
;;------------------=={ Sortents Table }==--------------------;;
;;  Retrieves the Sortents Table object.                      ;;
;;  Arguments:                                                ;;
;;  obj - VLA Block Container Object                          ;;
;;  Returns: Sortents Table Object, else nil                  ;;
(defun LM:SortentsTable ( obj / dic )
    (cond
        (   (LM:CatchApply 'vla-item
                (list (setq dic (vla-getextensiondictionary obj)) "ACAD_SORTENTS")
        (   (LM:CatchApply 'vla-addobject (list dic "ACAD_SORTENTS" "AcDbSortentsTable")))
;;-----------------=={ SelectionSet -> VLA }==----------------;;
;;  Converts a SelectionSet to a list of VLA Objects          ;;
;;  Arguments:                                                ;;
;;  ss - Valid SelectionSet (Pickset)                         ;;
;;  Returns:  List of VLA Objects                             ;;
(defun LM:ss->vla ( ss / i l )
    (if (eq 'pickset (type ss))
        (repeat (setq i (sslength ss))
            (setq l (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) l))
;;---------------------=={ Catch Apply }==--------------------;;
;;  Applies a function to a list of arguments and catches     ;;
;;  an exception.                                             ;;
;;  Arguments:                                                ;;
;;  _function  - function to be applied                       ;;
;;  _params    - list of arguments to be supplied to function ;;
;;  Returns:  Result of function, else nil if exception       ;;
(defun LM:CatchApply ( _function _params / result )
    (if (not (vl-catch-all-error-p (setq result (vl-catch-all-apply _function _params))))
        result
;;------------------=={ Safearray Variant }==-----------------;;
;;  Creates a Safearray Variant of a specified data type      ;;
;;  Arguments:                                                ;;
;;  datatype - variant type enum (eg vlax-vbDouble)           ;;
;;  data     - list of static type data                       ;;
;;  Returns:  VLA Variant Object of type specified            ;;
(defun LM:SafearrayVariant ( datatype data )
    (vlax-make-variant
        (vlax-safearray-fill
            (vlax-make-safearray datatype (cons 0 (1- (length data))))
            data
(vl-load-com)
;;The following program will move the selected objects to the top of the draw order.
(defun c:top (/)
  (LM:MovetoTop (cond (acdoc)
                      ((setq acdoc (vla-get-activedocument (vlax-get-acad-object))))
                (ssget
                  (list
                    (cons 410
                          (if (= 1 (getvar 'cvport))
                            (getvar 'ctab)
                            "Model"
;;The following program will move the selected objects to the bottom of the draw order.
(defun c:bottom (/)
  (LM:MovetoBottom (cond (acdoc)
                   (ssget
                     (list
                       (cons 410
                               (getvar 'ctab)
                               "Model"
;;The following program will move the selected objects above the draw order of the subsequently selected object.
(defun c:above (/ ss en)
  (if
    (and
      (setq ss
             (ssget
               (list
                 (cons 410
                         (getvar 'ctab)
                         "Model"
      (setq en (car (entsel "\nSelect Object to Move Selection Above: ")))
     (LM:MoveAbove
       (cond (acdoc)
       ss
       (vlax-ename->vla-object en)
;;The following program will move the selected objects below the draw order of the subsequently selected object.
(defun c:below (/ ss en)
  (if
    (and
      (setq ss
             (ssget
               (list
                 (cons 410
                         (getvar 'ctab)
                         "Model"
      (setq en (car (entsel "\nSelect Object to Move Selection Below: ")))
     (LM:MoveBelow
       (cond (acdoc)
       ss
;;The following program will swap the draw order of the two selected objects; this operation requires a regen to take effect.
(defun c:swap (/ e1 e2)
  (if
    (and
      (setq e1 (car (entsel "\nSelect First Object: ")))
      (setq e2 (car (entsel "\nSelect Object to Swap With: ")))
       (LM:SwapOrder
         (cond (acdoc)
         (vlax-ename->vla-object e1)
         (vlax-ename->vla-object e2)
       (vla-regen acdoc acactiveviewport)
;;The following program will move all objects residing on the layer of a selected object to the top of the draw order.
(defun c:layertop (/ en)
  (if (setq en (car (entsel "\nSelect Object on Layer to Move to Top: ")))
                  (ssget "_X"
                         (list
                           (assoc 8 (entget en))
                           (cons 410
                                   (getvar 'ctab)
                                   "Model"
;;The following program will move all Hatch objects to the bottom of the draw order.
(defun c:hatchbottom (/)
                   (ssget "_X"
                          (list
                            '(0 . "HATCH")
                            (cons 410
                                    (getvar 'ctab)
                                    "Model"
发表于 2023-3-14 16:33:37 | 显示全部楼层
这样就可以了
((if command-s command-s vl-cmdf) "_.DRAWORDER" SS "" "f")
 楼主| 发表于 2023-3-15 07:36:45 | 显示全部楼层
自贡黄明儒 发表于 2023-3-14 16:33
这样就可以了
谢谢黄大侠热心回复。
发表于 2024-7-18 16:28:29 | 显示全部楼层
取走了,感谢分享,今天也遇到这个问题了,点么多次好烦
GMT+8, 2025-4-30 11:13 , Processed in 0.183134 second(s), 26 queries , Gzip On.
