查看: 1302|回复: 4
【K:GetPaperLst】获取打印机纸张
发表于 2023-3-12 02:34:47 | 显示全部楼层 |阅读模式
获取打印机的纸张,稍微梳理了一下,源码来自这里:
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=55949&highlight=%B4%F2%D3%A1%BB%FA%2B%D6%BD%D5%C5
  1. ;获取打印机纸张
  2. (defun K:GetPaperLst (PrintNam/ DOC Layout)
  3.   (vl-load-com)
  4.   (setq DOC    (vla-get-ActiveDocument (vlax-get-acad-object))
  5.         Layout (vla-get-activeLayout DOC)
  6.   )
  7.   (vla-put-configname layout PrintNam) ;设置当前打印机
  8.   (vla-RefreshPlotDeviceInfo Layout) ;更新打印机、规范介质和打印样式表信息
  9.   (mapcar
  10.     '(lambda (xx)
  11.        (vla-GetLocaleMediaName Layout xx)
  12.      )
  13.     (vlax-safearray->list (vlax-variant-value (vla-GetCanonicalMediaNames Layout)))
  14.   )
  15. )
如果你只想获取自定义的纸张,可以移除不含关键词"UserDefinedMetric"的元素
  1. (defun k:Remove-NoChar (Lst Char / item NewLst)
  2.   (setq NewLst '())
  3.   (foreach item Lst
  4.     (if (vl-string-search Char item)
  5.       (setq NewLst (cons item NewLst))
  6.     )
  7.   )
  8.   (reverse NewLst)
  9. )
 楼主| 发表于 2023-3-12 03:04:06 | 显示全部楼层
也可以这样改写:Flag为T时只获取自定义的纸张
  1. ;获取打印机纸张
  2. (defun K:GetPaperLst (PrintNam Flag / DOC Layout PaperLst)
  3.   (vl-load-com)
  4.   (defun k:Remove-NoChar (Lst Char / item NewLst)
  5.     (setq NewLst '())
  6.     (foreach item Lst
  7.       (if (vl-string-search Char item)
  8.         (setq NewLst (cons item NewLst))
  9.       )
  10.     )
  11.     (reverse NewLst)
  12.   )
  13.   (setq DOC    (vla-get-ActiveDocument (vlax-get-acad-object))
  14.         Layout (vla-get-activeLayout DOC)
  15.   )
  16.   (vla-put-configname layout PrintNam) ;设置当前打印机
  17.   (vla-RefreshPlotDeviceInfo Layout) ;更新打印机、规范介质和打印样式表信息
  18.   (setq PaperLst (vlax-safearray->list (vlax-variant-value (vla-GetCanonicalMediaNames Layout))))
  19.   (mapcar
  20.     '(lambda (xx)
  21.        (vla-GetLocaleMediaName Layout xx)
  22.      )
  23.     (if (= Flag T)
  24.       (k:Remove-NoChar PaperLst "UserDefinedMetric")
  25.       PaperLst
  26.     )
  27.   )
  28. )
发表于 2023-3-12 22:26:34 | 显示全部楼层
感觉离一个批打工具不远了。很6
 楼主| 发表于 2023-3-15 00:24:57 | 显示全部楼层
结合这个帖子调整成这样也许会好一点http://bbs.mjtd.com/thread-187356-1-1.html
  1. (defun K:GetPaperLst (PrintNam Flag / DOC Layout PaperLst xx)
  2.   (vl-load-com)
  5.   )
  9.   (if (= Flag T);只获取自定义纸张
  10.     (list
  11.       (mapcar
  12.         '(lambda (xx)
  13.           (vla-GetLocaleMediaName Layout xx)
  14.         )
  15.         (k:Remove-NoChar PaperLst "UserDefinedMetric")
  16.       )
  17.       (mapcar
  18.         '(lambda (XX)
  19.           (K:GetPaperType (car (K:Str2NumLst XX)) (cadr (K:Str2NumLst XX)))
  20.         )
  21.         (k:Remove-NoChar PaperLst "UserDefinedMetric")
  22.       )
  23.     )
  24.     (list
  25.       (mapcar
  26.         '(lambda (xx)
  27.           (vla-GetLocaleMediaName Layout xx)
  28.         )
  29.         PaperLst
  30.       )
  31.
  32.     )
  33.   )
  34. )
发表于 2024-2-24 11:55:32 | 显示全部楼层
这是干什么用的
GMT+8, 2025-5-1 04:04 , Processed in 0.132075 second(s), 23 queries , Gzip On.
