查看: 2822|回复: 13
[选集] 框选的时候只选择边界线
发表于 2023-2-22 15:41:23 | 显示全部楼层 |阅读模式
选择的时候有没有办法选择最外的边界线,也就是图中所示的没有被其他闭合曲线包围的曲线,或者换个思路选择被包围的图元
 楼主| 发表于 2023-2-27 14:53:23 | 显示全部楼层
paulpipi 发表于 2023-2-27 08:53
大神,有试出来吗?
通过咨询上面的大佬
自己做了个勉强能用的,贴出来你看看
  1. /// <summary>
  2.     /// 判断两个曲线的包围关系,如果是被包围的曲线就改变颜色为黄色
  3.     /// </summary>
  4.     /// <param name="curve1">曲线1</param>
  5.     /// <param name="curve2">曲线2</param>
  6.     public static void IsPolygonInsideAnotherPolygon(Curve curve1, Curve curve2)
  7.     {
  8.
  9.         Point3d point1;
  10.         Point3d point2;
  11.         MPolygon mPolygon1 = new MPolygon();
  12.         MPolygon mPolygon2 = new MPolygon();
  13.         if (curve1.GetType() == typeof(Polyline))
  14.         {
  15.             Polyline polyline1 = (Polyline)curve1;
  16.             mPolygon1.AppendLoopFromBoundary(polyline1, false, Tolerance.Global.EqualPoint);
  17.
  18.             point1 = polyline1.GetPoints().ToList()[0];
  19.         }
  20.         else
  21.         {
  22.             Circle c1 = (Circle)curve1;
  23.             mPolygon1.AppendLoopFromBoundary(c1, false, Tolerance.Global.EqualPoint);
  24.             point1 = c1.StartPoint;
  25.         }
  26.         if (curve2.GetType() == typeof(Polyline))
  27.         {
  28.             Polyline polyline2 = (Polyline)curve2;
  29.             mPolygon2.AppendLoopFromBoundary(polyline2, false, Tolerance.Global.EqualPoint);
  30.
  31.             point2 = polyline2.GetPoints().ToList()[0];
  32.         }
  33.         else
  34.         {
  35.             Circle c2 = (Circle)curve2;
  36.             mPolygon2.AppendLoopFromBoundary(c2, false, Tolerance.Global.EqualPoint);
  37.             point2 = c2.StartPoint;
  38.         }
  39.
  40.
  41.         if (mPolygon1.IsPointInsideMPolygon(point2, Tolerance.Global.EqualPoint).Count == 1)
  42.         {
  43.
  44.             curve2.ForWrite(e => e.ColorIndex = 2);
  45.         }
  46.         else if (mPolygon2.IsPointInsideMPolygon(point1, Tolerance.Global.EqualPoint).Count == 1)
  47.         {
  48.
  49.             curve1.ForWrite(e => e.ColorIndex = 2);
  50.         }
  51.         else return;
复制代码
 楼主| 发表于 2023-2-28 11:29:07 | 显示全部楼层
paulpipi 发表于 2023-2-27 20:54
试了一下,出现:错误: no function definition: CURVE,大神能搞个完整的出来吗?谢谢分享!
这个要使用ifoxcad开发
  1. /// <summary>
  2.     /// 改变被包围的图元颜色为黄色
  3.     /// </summary>
  4.     [CommandMethod("wk")]
  5.     public void WaiKuang()
  6.     {
  7.         using DBTrans tr = new();
  8.         var ents = Env.Editor.SSGet().Value.GetEntities<Curve>().ToList();
  9.         //ents.ForEach(t=>t.ForWrite(e => e.CloseCurve(tr)));
  10.         for(var i = 0; i < ents.Count-1; i++)
  11.         {
  12.             for(var j = i+1;j<ents.Count;j++)
  13.             {
  14.                 Q_EntityEx.IsPolygonInsideAnotherPolygon(ents[i], ents[j]);
  15.             }
  16.         }
  17.     }
 楼主| 发表于 2023-2-27 14:54:43 | 显示全部楼层
qq25469005 发表于 2023-2-27 14:53
通过咨询
自己做了个勉强能用的,贴出来你看看
内部图元改为黄色后,选择的时候用选择过滤器过滤黄色的图元,大概就差不多实现了这个效果,就是图元太多的时候效率稍慢一点
发表于 2023-2-22 16:25:25 | 显示全部楼层
选择完再判断倒是可以,如果是要加选择过滤器感觉没法加
 楼主| 发表于 2023-2-22 16:27:00 | 显示全部楼层
也可以,本意就是想要区分开来,比如改变颜色之类的,能否请教一下
发表于 2023-2-22 16:40:22 | 显示全部楼层
Extents3d extents3D = polyline.Bounds.Value;
Extents3d 有左下角点和右上角点的属性
 楼主| 发表于 2023-2-22 17:02:31 | 显示全部楼层
像这种情况下就用这个无法判断吧
 楼主| 发表于 2023-2-22 17:04:25 | 显示全部楼层
qq25469005 发表于 2023-2-22 17:02
像这种情况下就用这个无法判断吧
发表于 2023-2-22 18:49:16 | 显示全部楼层
SelectWindowPolygon 的结果,就可以判断是否有内部对象
 楼主| 发表于 2023-2-22 22:33:03 | 显示全部楼层
好的,我试试
发表于 2023-2-23 13:57:16 来自手机 | 显示全部楼层
请高手帮忙写个码,这个很有用
发表于 2023-2-27 08:53:38 来自手机 | 显示全部楼层
qq25469005 发表于 2023-2-22 22:33
好的,我试试
大神,有试出来吗?
GMT+8, 2025-5-1 09:15 , Processed in 0.190148 second(s), 26 queries , Gzip On.
