查看: 1487|回复: 7
求助ssget选择图元后 在筛选的问题
发表于 2023-2-21 21:27:27 | 显示全部楼层 |阅读模式
2明经币
求助ssget选择图元后  在筛选的问题:
选取图元后   筛选出18.0   20.0  22.0的圆  移动到图层7   颜色bylayer
                 然后再筛选出  8.0   10.0 的圆 移动到图层7     颜色bylayer
求助一下各位大师,这个怎么写呢?
最佳答案
查看完整内容
(defun c:test(/ ed obj ss st n1 n2) (setvar "cmdecho" 0) (if(setq ss(ssget '((0 . "circle")))) (progn (setq st -1 n1 0 n2 0) (repeat(sslength ss) (setq obj(vlax-ename->vla-object(ssname ss(setq st(1+ st)))) ed(vla-get-Diameter obj) ) (cond ((or(= ed 8.0)(= ed 8.01)(= ed 10.0)(= ed 10.01))(vla-put-layer obj "7")(s ...
发表于 2023-2-21 21:27:28 | 显示全部楼层
        (setq
        (cond
          ((or(= ed 8.0)(= ed 8.01)(= ed 10.0)(= ed 10.01))(vla-put-layer obj "7")(setq n1(1+ n1)))
          ((or(= ed 18.0)(= ed 20.0)(= ed 19.98)(= ed 20.02))(vla-put-layer obj "8")(setq n2(1+ n2)))
        (vla-put-color obj 256)
      (princ (strcat "\n成功执行: "(itoa n1)"个圆至7层,"(itoa n2)"个圆至8层"))
  (prin1)
 楼主| 发表于 2023-2-21 22:16:28 | 显示全部楼层
目前用的这个在输入命令后 要选择两次图元    要实现的效果是 只选择一次  自动分离图元
(defun CHmovelocation78  (/ lm_xiaoding lm_daozhu)
    (if (not (tblsearch "layer" "7"))(command "-layer" "n" "7" "c" "4" "7" ""));endif
    (if (not (tblsearch "layer" "8"))(command "-layer" "n" "8" "c" "2" "8" ""));endif
             (setq lm_xiaoding (ssget  '((0 . "circle")(-4 . "<or")(40 . 8)(40 . 8.01)(40 . 10)(40 . 10.01)(-4 . "or>")))
                   lm_daozhu   (ssget  '((0 . "circle")(-4 . "<or")(40 . 4)(40 . 19.98)(40 . 20.0)(40 . 20.02)(-4 . "or>"))));endsetq
    (if lm_xiaoding (command "chprop" lm_xiaoding "" "la" "7" "c" "bylayer" ""))
    (if lm_daozhu   (command "chprop" lm_daozhu   "" "la" "8" "c" "bylayer" ""))
    (princ"\n转换分类完成")  (princ)
);end defun
 楼主| 发表于 2023-2-22 21:32:46 | 显示全部楼层
  (if(setq ss(ssget '((0 . "circle")))) ...
谢谢,终于解决了问题。谢谢帮忙。
发表于 2023-3-5 23:29:58 | 显示全部楼层
大师,您帮我看下是不是红色的地方不对?谢谢
(defun c:CH(/ ed obj ss st n1 n2 n3 n4)
  (princ "转换图层")
  (if(setq ss(ssget))
      (setq st -1 n1 0 n2 0 n3 0 n4 0)
        (setq
          ed (vla-get-layer obj)
        (cond
          ((= ed 151)(vla-put-layer obj "MATER")(setq n1(1+ n1)))
          ((= ed 20) (vla-put-layer obj "MATER")(setq n2(1+ n2)))
          ((= ed 251)(vla-put-layer obj "A")(setq n3(1+ n3)))
          ((= ed 138)(vla-put-layer obj "A")(setq n4(1+ n4)))
  (prin1)
发表于 2023-3-6 07:45:19 | 显示全部楼层
  (princ "转 ...
图层名称属于字符串,(= ed "151")
发表于 2023-3-6 08:00:20 | 显示全部楼层
好的,谢谢!
发表于 2023-3-6 08:55:53 | 显示全部楼层
大师,我这样做不行呢?
……又弄了下,可以了
GMT+8, 2025-5-1 03:18 , Processed in 0.161279 second(s), 21 queries , Gzip On.
